Alaska remote trip Prep
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GeneralChingon, Apr 25, 2024.
  1. Apr 25, 2024 at 10:34 AM
    GeneralChingon
    GeneralChingon [OP] Member
    Ron
    '23 Tacoma 4WD TRD Off-road ACLB
    Hello all,
    I'm currently building out my '23 for a long trip to Alaska. I expect to put about 12k miles in about a month's time. When I head out for my trip, my truck will only be about 1 yr old, and have about 10k miles on it. Other than a camper-build out, the truck will be mostly stock. The trip will include many miles "off-pavement" but not any technical trails.
    My current plan is to bring an Oil filters/Oil, because I will probably do at least one oil change along the trip, but I am open to suggestions about what else I should bring along in terms of possible issues/repairs. I don't expect to do hard wheeling on this trip, so I am not concerned with suspension or drivetrain parts.
    I have the full size spare, and I have tire repair kit as well. I'm considering getting an additional spare, but I think that may be overkill.
    Any recommendations for things that you have experienced in the first couple years of owning it, that I should prepare for? My only concern is getting stranded somewhere, or having to wait a significant time for parts to be delivered.
    Thanks.
    PS: I'll share pics as I build out my setup.
    tcBob, AK Dudeman and inwood customs like this.
  2. Apr 25, 2024 at 10:40 AM
    boston23
    boston23 Well-Known Member
    Adam
    NM
    2019 SR5 DCSB 4x4
    Okay get ready for the “experts” to give you a huge shopping list.
    I would say from experience, camper plus gear on a tacoma = sagging stock leaf springs so may want to upgrade those if possible but not necessary, just expect some squat.
    As for gear if you dont plan to offroad,
    I would recommend:
    -a reliable battery jumper like the Noco
    -air compressor for tires, Viair 88p has served me well
    also bring a folding shovel, hose clamps, zip ties, a few adjustable wrenches
    edit: make sure you deflate your tires a bit for those “many miles” of unpaved roads. Will significantly reduce vibrations and risk of getting a flat
  3. Apr 25, 2024 at 10:41 AM
    Tallgrass05
    Tallgrass05 Well-Known Member
    Satellite phone.
    hr206, Tacosha, RIX TUX and 4 others like this.
  4. Apr 25, 2024 at 11:24 AM
    M85
    M85 Active Member
    Colorado
    2019 SR ACLB
    Maybe a gas tank upgrade? Gas is super expensive in remote areas, so you can fill up in population centers and make it farther. I doubt you'll save enough to offset the cost of the upgrade, but it's nice to have either way.
    Some basic spare parts like a serpentine belt (if it breaks you're stuck because you have no water pump). Maybe air filters (engine and cabin) if you expect the roads to be really dusty and you don't have a desert snorkel. Adding to your tire repair kit, there are replacement valve stems you can install from the outside. Probably overkill if you're not rock crawling, but they are small enough.
    A took kit, obviously.
    I bet you'll pass an oil change place at least once in those 12k miles. It sounds like you're driving up from the lower 48. You'll probably at least pass through Anchorage or Fairbanks. I like to do my own oil changes, but doing it on a trip seems kind of crazy.
  5. Apr 25, 2024 at 11:30 AM
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) 265/75 AT3W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters
    I'd really consider getting better (and more ply#) all terrains. If you can swing a 17" wheel then get something C rated. If you're sticking with 16's then you'll need to go E.
    Very excited for you, your trip has been on my bucket list for years.
    TACOTU3, Chew and doublethebass like this.
  6. Apr 25, 2024 at 11:33 AM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    If you are doing the dalton expect to replace your windshield
  7. Apr 25, 2024 at 11:51 AM
    GeneralChingon
    Ron
    I plan to bring 10gallons in Scepter cans. It's not worth it for this trip alone to upgrade the tank, but maybe down the road I may consider it. I was thinking about the Serpentine belt, so I'll add that to the list. I think I have the valve replacement stems already in my kit.
    I've considered this, but since I am not doing anything harsh, I'll just wear these tires out and get a new set this fall.
    I'm considering getting the battery jumper as a fail safe. I'll have dual battery/solar setup, so I am not too worried. I have a compressor, and I'll consider the leaf spring after I build out the bed system, once I see how it sags/drives.
    I'm going to get a Garmin with Spot/limited text messaging.
    For the oil change, I plan to get it done in Anchorage/Fairbanks or some other big city. I'll just have the filter, etc just in case they don't have them in stock. I'll have a new cabin/air filter before the trip, so I think I can get buy just blowing through them with the air compressor if they get rough.
    Keep the suggestions coming, I have several months to prepare, so no rush. I'll have a tools, recovery gear, etc that I didn't mention, as well as shovel, ax, saw and other normal tools that are not vehicle specific. I'm considering carrying some additional replacement bulbs for brakes/headlights etc as well.
  8. Apr 25, 2024 at 11:53 AM
    GeneralChingon
    Ron
    Yes, I plan to do the Dalton. I already have one crack, I'll replace it when I get back, unless it is just unbearable, then I'll check in one of the big cities on the way.
    Toy_Runner likes this.
  9. Apr 25, 2024 at 3:34 PM
    Ejctt
    Ejctt Well-Known Member
    2023 White Tacoma Off-road
    Camera items (cameras, storage cards, batteries, etc.), music for the long parts, protection of your choice, ground cover for repairs, and survival gear just in case.
    boston23 and GeneralChingon[OP] like this.
  10. Apr 25, 2024 at 3:41 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    Ham radio
    RIX TUX and GeneralChingon[OP] like this.
  11. Apr 25, 2024 at 3:57 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    Color me green with envy!!!!!!!!!!! :D
    One thing struck me right away. 12k miles in 30 days is a lot statistically at ~400 miles per day. Anyone can drive 400 miles in a day. But 30 days in a row is another thing unless you're an OTR trucker. Plan for fatigue, especially if travelling alone. Time is always the most precious commodity. You may have family or job vacation limits to work around, but just a concern to share in that regard.
    Assuming you are going to be sleeping in your camper most of the journey, make certain your "sleep system" is dialed in before you leave. Being able to "black out" the interior of your camper and regulate interior temp so you can get quality sleep is a must.
    BEST WISHES!!!!!!!!!!!!
  12. Apr 25, 2024 at 4:01 PM
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
    Sounds like fun to drive your Tacoma!
    I'm flying into Anchorage in July, and I've rented a lifted Tundra with a Alucab for two weeks. I'm as well driving the Dalton. The farthest north I'm driving is Atikin Pass (have to see it... ever since watching Ice Road Truckers). The rental has an option of windshield insurance, which I'm taking. :thumbsup: I've routed the trip on both a Garmin and Gaia, marking gas stations, sites to see, and places to camp (2189 miles). I don't know that I'll ever go back, so I'm trying to see it all. But it would fun to drive up there... when I have six weeks!
    How many weeks is your trip?
  13. Apr 25, 2024 at 5:59 PM
    wfo479
    NE Ohio
    2020 TRD Pro
    The dalton is kinda a dead end where you cannot get to the coast. Maybe consider the Dempster highway in the yukon better end result
    MR E30, Okierut and 0xDEADBEEF like this.
  14. Apr 25, 2024 at 6:01 PM
    0xDEADBEEF
    0xDEADBEEF Trash Aficionado
    2000 reg cab 4x4 flatbed MT
    The dempster is awesome, I received this same advice as well from someone who had done both. Did not regret doing it and hanging out in Tuk for a couple days.
  15. Apr 25, 2024 at 6:08 PM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Heard thos before also. Are you going up the ALCAN. Get familiar with firearms regs if you plan to go thru Canada (shotguns and a rifle). No pistols or those infamous assault rifles.
  16. Apr 25, 2024 at 6:51 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Even if you don't plan to do much night driving, I'd look at adding some driving lights and maybe a-pillar floods as well for those backroads and twisties you might hit. Having done quite a bit of cross country drives (back and forth across the lower 48 a few different ways in about a dozen trips), you'll never regret more light, even at normal traffic speeds. In the lighting subforum, there's two good stickies at the top, the SAE J583 fog lamo thread and the SAE J581 driving light thread. Lots of very good pics and test data from the thread author. Fog lamps (real fogs) may not be the most useful upgrade, but adding some effective forward lighting will be a godsend for spotting wildlife.
    My old 4runner, I ran the 100/99w Osram superbright H4's, and had a set of LED Cibie Super Oscars wired to the highbeam circuit. I never thought I needed more light till the night I drove through Big Sky montana on a cloudy night at dark of the moon.
    I see you have a plan for fuel.
    Shotgun. Slugs. And full size shovel.
    Gps unit that's not phone based.
    PACE plan your route and commo plans. Primary - Alternate - Contingency - Emergency
    Get a 2m/70cm 50w ham radio setup. And cb. Never a waste of time to be scanning the local airwaves for traffic. Satellite messenger/locator
    Edit (again, lol) Not sure where you're at with maintenance, but maybe change your diff fluids and transfer case fluid before the trip.
  17. Apr 25, 2024 at 7:00 PM
    GeneralChingon
    Ron
    I'll be gone for at least 4 weeks.
    I'm going to go up the Dempster, but only up to Tombstone Territorial park. I do plan to go all the way to Deadhorse on the Dalton.
    No plan to carry firearms, I don't want to deal with the hassle. I'll have plenty of bear spray though.
    I'm probably way over estimating the amount of driving, but there will be days where we will just put miles on. My son will be with me. I am keeping a very loose itinerary.
    As far as sleeping, I just picked up a Harker EXO, and I'll be building out the bed system over the next several months, with several shake down trips planned. For comms, I will have Ham, it's been the standard for our group for a long time, and also a CB, because it's popular on the Dalton.
  18. Apr 25, 2024 at 7:00 PM
    reddawg661
    reddawg661 Well-Known Member
    Palmdale, CA
    This sounds like a dream dude haha. experiencing all of that would be amazing. Envious to say the least brotha!
  19. Apr 25, 2024 at 7:04 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Even though people like to imagine Alaska as the Wild West it’s really not. You will be able to get replacement parts easily in Fairbanks or Anchorage. You will see people on every road you go on because they are the roads people drive who live and work there as well as the other tourists.
    Good quality tires, a gas can or two for just in case, basic tools and whatever camping supplies you want to bring are all you need.
  20. Apr 25, 2024 at 7:11 PM
    GeneralChingon
    Ron
    Yeah, I know people do these in their cars, so that's why I'm not too worried. I saw a video of someone in Volkswagen GTI making the trip to Deadhorse.
