Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Mar 20, 2017 at 11:57 AM
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Didn't know where to put this and since there isn't a BS thread for turbos I figured I'd take a crack at it. Just put a tank of e85 in my truck at 12 psi and gawd dayum it feels like a completely different truck. Pulls harder at 85F ambient now than it did at 30F in the winter. Mpg's are moot since 91 costs around 30% more. Idles smoother, runs quieter. The only thing I can say bad about it is I'll need a bigger tank if I want to run it regularly and also that smell though.
    @Torspd @j0shu4 @Brice @GioGuitarDude @boostedka @StAndrew @MrCrowntown @yota243
    Sorry if I left you out, let's talk shop!
  2. Mar 20, 2017 at 11:59 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    About time a thread like this was made! Bravo, Clay. Bravo.
    j0shu4 and Clay_916[OP] like this.
  3. Mar 20, 2017 at 12:01 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  4. Mar 20, 2017 at 12:01 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  5. Mar 20, 2017 at 12:02 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Do you have a ethanol content analyzer, Clay?
  6. Mar 20, 2017 at 12:02 PM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
  7. Mar 20, 2017 at 12:03 PM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    No but it's definitely on the list. I typically have a laptop with me so I can make on the fly adjustments. Are they inexpensive? and it just sits in your tank?
  8. Mar 20, 2017 at 12:04 PM
    yota243
    E.J.
    north Alabama
  9. Mar 20, 2017 at 12:04 PM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
  10. Mar 20, 2017 at 12:07 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Externally. The fuel line or line are routed through it. Depending on the aftermarket ecu's capability, it could be wired into it, and then the laptop could do on the fly map adjustments.
    The price is around the $200 something realm.
  11. Mar 20, 2017 at 12:08 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Oh man a Turbo BS thread. We gonna get crazy in here.
  12. Mar 20, 2017 at 12:10 PM
    yota243
    E.J.
    north Alabama
    I know its a little early, but I would be ok with this being thread of the year
    j0shu4 and MrCrowntown like this.
  13. Mar 20, 2017 at 12:14 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Party animals have arrived. Going downhill from here. :cheers: :rasta:
    DefinitelyThor and MadTaco461 like this.
  14. Mar 20, 2017 at 12:15 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :laugh: :pray:
    Clay_916[OP] and yota243[QUOTED] like this.
  15. Mar 20, 2017 at 12:16 PM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Sounds reasonable, I don't think the fic6 can do anything like that sadly. It can store 2 maps which can be wired to a switch :rofl:. I'd like to be able to have some type of auxiliary device that can do exactly that though. The stock ecu in combo with the fic6 is pretty lousy at air temp adjustments (or my tune isn't good enough). I've been making different maps for 15-20 degree brackets as the temps have been rising. It would be pretty sick if I could have some device/storage unit inline with the fic that would intercept an air temp signal and also the ethanol content signal and load maps based on them. Doesn't sound like too much to ask :notsure:
    jubei likes this.
  16. Mar 20, 2017 at 12:19 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  17. Mar 20, 2017 at 12:21 PM
    MadTaco461
    CA
    Kinda stock
    Air temps mess up my tune also. I need to put a resistor to hold my intake air temp constant.
  18. Mar 20, 2017 at 12:23 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    e85??? shit man. i hope you swapped all your fuel lines and rubber connections out. That shit eats that stuff away.
    I bet it pulls good!
    StAndrew likes this.
  19. Mar 20, 2017 at 12:28 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You cannot install GM air temp sensor, or AEM air temp sensor (same thing), instead of using the oem air temp sensor?
  20. Mar 20, 2017 at 12:31 PM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Yeah I'm kinda crossing my fingers with the lines. I've read that "around" 2000 manufacturers started using ethanol resistant rubbers for e10 and that these newer components are more resistant to higher concentrations as well but they are also 20 years old so I expect to be upgrading them at some point. It feels like a completely different engine. Hits way harder initially and holds smoother throughout the power band. My 91 tune was probably on the rich side just to avoid detonation at 9.6 static CR and 12 psi so I wasn't exactly maxing out the tune initially but yeah it feels so much better now, 11.8-12 afr which I think is still considered at the very far end of the safe spectrum and it just spins up so smooth now.
