Are Iridium spark plugs worth it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by devin.d88, Oct 8, 2021.
  1. Oct 8, 2021 at 8:42 AM
    devin.d88
    devin.d88 [OP] Member
    Devin
    Black 2005 Toyota Tacoma prerunner
    Tuff country front and rear shocks bf Goodrich all terrain tires
    I’m replacing my spark plugs and i was wondering if getting iridium spark plugs is worth the few extra bucks. I heard some good things about the NGK laser iridium spark plugs.
  2. Oct 8, 2021 at 8:50 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Just get OEM plugs. No need for anything else.
    Micbt25, tacoman45, Knute and 5 others like this.
  3. Oct 8, 2021 at 8:53 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Nothing beats OEM. Keep in mind how many miles the OEM have lasted until most here have changed them even with zero issues. Get Densos and be done with it.
  4. Oct 8, 2021 at 8:53 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Iridium plugs are not worth it nor recommended for use on these trucks unless you are boosted.
  5. Oct 8, 2021 at 8:56 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    This. OEM Denso standard plugs only.
    And the ONLY reason why Iridium are recommended on the boosted trucks is, unless you get VERY crafty with the perfect socket, extensions etc, the driver side plugs require the supercharger to be removed to get to them.
  6. Oct 8, 2021 at 8:56 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Denso K20HRU11. I installed iridiums for a friend against my recommendations and it idled and ran terribly. It may have been his setup but I always recommend copper/nickel for v6
  7. Oct 8, 2021 at 8:57 AM
    iblis01
    iblis01 Well-Known Member
    Austin
    2020 TRD ordcsb
    Lots
    Denso for sure. I might also use NGK if for some reason i cant find Denso. But I would definitely check the gap on the NGK.
  8. Oct 8, 2021 at 9:04 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Densooooooooooo the cheap ones
  9. Oct 8, 2021 at 9:24 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Or go factory- NGK on one side, Denso on the other. :crazy: No idea if they're still doing that but mine came that way as did a lot of others from what I've read here.
    Toms2Yotas, tcjacado and eherlihy like this.
  10. Oct 8, 2021 at 11:00 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Contrary to other opinions, I've been on denso iridium plugs since I bought my truck in 2014. Changed them at 90k miles because I decided I'd replace my coils. No issues with them at all. Get the correct heat range and they will be fine. Anyone who gets the wrong heat range will have issues. People say to use the cheaper plugs and that's fine, but I skip replacing them at 30k/60k intervals, so I save lots of time, labor, and I come out ahead by not having to spend on new plugs for those intervals.
    Denso (4704) IKH20TT
  11. Oct 8, 2021 at 11:07 AM
    3JOH22A
    3JOH22A Toyota Gigolo
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If you're lazy (like me) and don't want to change plugs every 30k, get iridium plugs. I ran Denso Iridium Long Life 3421 with no issues. That was before TT plugs that @Revelations linked came to market.
    Makanahi, jsi and Revelations like this.
  12. Oct 8, 2021 at 11:10 AM
    Revelations
    2014 MGM DCSB
    Also, iridiums are pre-gapped, but always check with a tool in case something got missed.
  13. Oct 8, 2021 at 11:27 AM
    jsi
    jsi Well-Known Member
    native earthling
    How much is your time worth? How much do you like dicking around under the hood? If your time is worth anything at all and you have better things to do, get the iridium plugs.
    I'm pushing 80K on my iridium plugs. I checked them at 30K and for all intents and purposes they were still new. I'll check again when they hit 100K. Bottom line iridium plugs last longer because of a tiny little piece of iridium. Other than that they are identical to the "regular" plugs.
    Makanahi and Revelations like this.
  14. Oct 8, 2021 at 2:56 PM
    vtdog
    vtdog Well-Known Member
    NH
    I changed out to Irridium a few years and over 30k miles ago. If I remember correctly, they were only a couple of dollars more per plug. Plug change was a pain in the rear for my 6 cyl, so the minimal cost which was fine with me. Even if they don't last 100k, I am ok with the cost/benefit ratio to save doing the plugs more often
  15. Oct 8, 2021 at 3:06 PM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I went Irridium because I didn't want to have to replace plugs as often either. Has been 100% fine/normal. But I recently learned that there are a lot of fake Irridiam plugs being made/sold. I would assume that most of the people who have had bad experiences with Irridium plugs probably had the fake/non authentic ones.
    Read this post:
    https://www.tacomaworld.com/threads/decreased-power.737963/#post-26271254
    Makanahi likes this.
  16. Oct 8, 2021 at 3:51 PM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    Go iridiums to avoid changing the plugs often? I think my OEM almost hit 90k before I swapped them, not knowing if the PO replaced them. Ill go another 90k before the next interval. That's how much I believe in the cheap Densos.
    Makanahi, tacoman45 and winkel like this.
  17. Oct 8, 2021 at 8:35 PM
    TacoTuesday1
    SoCal
    option 1: OEM
    option 2: misfire
    iblis01 and Fullboogie like this.
  18. Oct 8, 2021 at 8:40 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Iridium are fantastic. However I've heard some guys have issues with them in the 2nd gens and I don't remember why. Best to stick with OEM.
  19. Oct 9, 2021 at 7:58 AM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I think its because there are a lot of fake/counterfeit Iridium plugs being sold which would be a pretty good reason for having issues!
    RedWings44[QUOTED] likes this.
  20. Oct 9, 2021 at 8:06 AM
    jacpa
    jacpa Well-Known Member
    Jim
    2021 4Runner TRD ORP
    copper plugs every 30k miles for correct firing on the 4.0L
