3rd Gen Mods & Tips
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tcBob, Apr 24, 2016.
  1. Apr 24, 2016 at 1:34 PM
    tcBob
    tcBob [OP] Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
  2. Apr 24, 2016 at 1:46 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Thanks as I am possibly 3rd Gen bound
    shakerhood, TacoKimo, Cavedog and 3 others like this.
  3. Apr 24, 2016 at 8:05 PM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
  4. May 10, 2016 at 8:14 PM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
  5. May 10, 2016 at 10:07 PM
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    You should link to the 2nd gen ac condensate drain thread. Also rear diff breather mod. Same as 2nd gen but both still good mods. The pop and lock thread is pretty interesting too because it discusses both commercial and diy versions of the same mod.
    tcBob[OP] likes this.
  6. Jul 14, 2016 at 7:27 PM
    tcBob
    Bob
    Added the just released transmission TSB to the list
    pngo121 and nevadabugle like this.
  7. Jul 17, 2016 at 5:40 PM
    tcBob
    Bob
  8. Jul 23, 2016 at 3:43 PM
    Wanderm
    Wanderm Member
    Matthew
    Pittsburgh, PA
    2016 SR 2.7L 4x4 5 Speed MGM
    NO MODS YET
    Where is the AC evap hose outlet located? I can't find it and I want to add the extension so it doesn't drip on the frame
    EDIT:
    nevermind. I found it and added 2feet of 5/8" ID hose to it and ran it through the cross member
  9. Aug 17, 2016 at 11:25 AM
    tcBob
    Bob
  10. Sep 26, 2016 at 9:44 AM
    jehlinger06
    jehlinger06 Well-Known Member
    Houston, TX
    2016 TRD Off Road
    Bone Stock!
    Does anyone know if there is a write up on 2016 hood swap? (Sport to Offroad or vice-versa)
  11. Oct 5, 2016 at 10:01 AM
    tcBob
    Bob
  12. Nov 1, 2016 at 11:13 AM
    tcBob
    Bob
  13. Nov 14, 2016 at 1:51 PM
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    Any mod for DRL LED HI on all the time?
  14. Nov 14, 2016 at 2:08 PM
    turbosmitty
    turbosmitty Well-Known Member
    Vegas
    2017 Tacoma TRD OR
  15. Dec 17, 2016 at 8:23 PM
    Greenbergler
    Greenbergler Well-Known Member
    Corey
    Orange County, CA
    2017 trd sport DCLB 4x4
    Anyone know if a cai and exhaust from a second gen will fit a 3rd gen?
  16. Dec 22, 2016 at 6:38 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Thinking of buying a third gen. How often should I rotate the air in my tires?
  17. Dec 22, 2016 at 6:48 AM
    dusman
    dusman Well-Known Member
    Dustin
    Windsor, Maine
    2017 TRD ORDC MGM
    I just rotate my air when I do my Halogen fluid change
  18. Dec 22, 2016 at 7:38 AM
    tcBob
    Bob
  19. Dec 22, 2016 at 6:15 PM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Thanks for the add.
    Storman and tcBob[OP] like this.
  20. Jan 8, 2017 at 3:26 PM
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    Things to consider if you want to lift your truck.
    This is not meant as a discouragement to lifting your vehicle. Please note: this is just to inform you.
    If you are not willing to spend thousands of dollars, don't mess with your suspension's ride height.
    Here is the scoop. If you change your ride height, you need to fix all of the suspension and driveline geometry you just threw out of whack. Non-negotiable.
    Let's start with the front... Raising the front requires you to correct the roll center, camber gain, bump steer, Ackerman steering, and then an front end alignment. The first 4 cost a lot of money. Don't forget: if you have a 4wd, then you need to correct the driveline geometry you just messed up. Again, money.
    Now for the rear... Raising the rear cause less trouble than the front, but you need to be diligent none the less. The most important thing you need to correct is driveline geometry. With a 2 piece driveshaft, there are a lot of angles to be mindful off. These must be corrected when lifting a vehicle. Roll center needs to be considered as well, but this is very minor. Last, a front end alignment to correct the faster you just through out. Finally, you need to test for vibrations in the driveline and correct as needed.
    Failing to correct the geometry after a lift results in a realization that you paid money to make your vehicle worse. Though, to be fair, it may look a little nicer.
