What psi should i run?
Discussion in 'Wheels & Tires' started by TacoTRD420, Sep 10, 2009.
  1. Sep 10, 2009 at 11:37 AM
    TacoTRD420
    TacoTRD420 [OP] ( . Y . ) = :)
    Jake
    Kaplan,La.
    2011 FJ T.T.
    Toyota FJ TT...Pretty much stock.
    I have some 285/60/18 Nitto terra grapplers, i wanted to know what tire pressure yall would run in them. i got around 35psi in them at the time. thanks.
  2. Sep 10, 2009 at 11:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Im running the same tires on my truck, and have found a 34 psi front, and 32 psi back gives the best wear.
    TRDSport10, patkap41, ARCHIVE and 3 others like this.
  3. Sep 10, 2009 at 11:47 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    When you get in jake swing by the house again and i'll show you the technique I use. I'm pretty sure chris used it to get his numbers. Chalk method.
    ddbrown likes this.
  4. Sep 10, 2009 at 11:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Bingo!
  5. Sep 10, 2009 at 2:07 PM
    TacoTRD420
    Jake
    Kaplan,La.
    2011 FJ T.T.
    k luke...
  6. Sep 10, 2009 at 2:27 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I run 34 all around cause chris said but I might lower the back to 32psi if chris found a better way to run them?!?!:D
    TRDSport10 likes this.
  7. Sep 10, 2009 at 2:31 PM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Chris has got all the answers....another reason I wish he where my neighbor!!:laugh: How about it Chris, free beer of your choice for a year!!!
    Dalegribble02 likes this.
  8. Sep 10, 2009 at 2:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I told ya to run that psi, 'cause I know you arnt gonna use the chalk method. ;)
    VERY tempting......How close to the water are ya? :D
  9. Sep 10, 2009 at 2:50 PM
    rob1
    Robert
    South Texas
    South Padre Island....45 min away:D
  10. Sep 10, 2009 at 2:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmm.......:p
  11. Sep 10, 2009 at 2:52 PM
    rob1
    Robert
    South Texas
    :laugh:...laters man
  12. Sep 10, 2009 at 2:54 PM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    what's the Chalk Method?
  13. Sep 10, 2009 at 2:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    e's06taco likes this.
  14. Sep 10, 2009 at 2:56 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Draw a line with chalk across the tires, drive 100 yards and see the wear pattern on the tires. Then adjust inflation until it is spot on
    TRDSport10 and TiComa_316 like this.
  15. Sep 10, 2009 at 2:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Optimizing Tire Pressure
    Proper inflation puts the most rubber on the road
    Jimmy Nylund / autoMedia.com
    About the only positive result from the current Ford/Firestone situation is that more people are now aware that proper tire inflation pressures can be crucial. Luckily, running the correct pressure is relatively easy—but how do you know what it is? That depends on a number of factors, including vehicle weight, tire specs, air temperature and even personal preference. Newer vehicles have the manufacturer's recommended pressures on a decal in the door jam or glovebox, but those numbers are for a stock vehicle with a full load.
    Air Apparent Running the correct pressure is relatively easy—but how do you know what it is?
    Tires lose pressure over time, so checking the inflation at least every couple of weeks is important. While you have your tire gauge out, you might as well set them at a correct pressure for your vehicle/tire/load combination.
    One simple method for finding the right pressure for your vehicle is to draw a chalk line across the tread, then drive a bit and check the line. Even wear is good, while the line fading in the center indicates over-inflation. Worst is when the chalk mark wears off at the outer edges (shoulders) first, meaning that the pressure is too low. Under-inflation lessens the tire's load capacity, can make for squirrelly handling and, most importantly, makes the tire run hotter. Hot tires tend to disintegrate, regardless of who made them. Consequently, it's better to err on the high side, even if ride quality may suffer and the tire wear pattern could be less than optimal. However, do not exceed the maximum pressure as stated on the sidewall—there can indeed be too much of a good thing.
    Once the lines wear off evenly, note those pressures for future reference. While the inflation must be identical for both ends of an axle, the front tires will often require a slightly higher pressure since they usually carry more of the weight of an unladen vehicle (most engines are up front).
    Gauging Pressure
    It doesn't really matter how accurate your tire gauge is as long as it's consistent and you use that same one every time. Also important for repeatability is to measure the tires either cold or warm, then stick with that measurement method since tire pressure vary quite a bit with temperature. Last, but not the least, if adding load to the vehicle, don't forget to add to the tire pressures accordingly.
    You'll need a piece of chalk, a tire gauge, a pen and a note pad. Make a chalk mark across the tread as pictured, on one front and one rear tire, and then drive a quarter mile or so in a straight line. Stop and study the chalk marks and note the pressure readings on the gauge. [​IMG]
    This tire shows over-inflation, having relatively intact marks at the shoulders while the center of the line is more worn. Ideally, the chalk would have faded evenly across the tread surface. Let out some air and try again.
  16. Sep 10, 2009 at 3:00 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    just hold on chris is comeing to N.J to work for me 1st
    and the water is right down the street :D
  17. Sep 10, 2009 at 3:02 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Darn straight I aint going to use the chalk method cause I don't know how to do it!!!!:eek::D
  18. Sep 10, 2009 at 3:04 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    Thanks Chris! I'm deffinetly going to have to do it if I get new tires
  19. Sep 10, 2009 at 4:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :woot:
    LMAO!!!
  20. Sep 10, 2009 at 6:00 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Thanks for picking up my slack chris.
