Start-X Remote starter
Discussion in 'Product Reviews' started by Yoda_Mike, Apr 4, 2023.
  1. Apr 4, 2023 at 6:28 PM
    Yoda_Mike
    Yoda_Mike [OP] YotaWerx Authorized Tuner
    Michael
    South Glens Falls, NY
    2019 Tacoma TRD Sport
    YotaWerx Blackhawk 2.0 tuned. Typer Auto tail light guards. Rough Country tri-fold tonneau cover. Start-X remote starter. Injen CAI. MBPR Armor Plus high clearance exhaust.
    I thought I’d share my experience with the Start-X remote starter kit, since I couldn’t find an instance where anyone else had done so. For those of us not lucky enough to have Toyota Connect, or a dealer installed remote start, this is a great option!
    The kit, as advertised, is completely plug and play. No cutting or splicing was necessary. Installation was a breeze too, only requiring removal of the LF door sill cover, kick plate, lower dash cover, and lower steering column cover. The whole process took only 15 minutes, and the company provides an easy to follow video detailing the process.
    Once installed and configured, the remote start is activated using the OEM key fob by pressing the lock button 3 times. This will start the truck and it run for 10 minutes before shutting off. This can be extended another 10 minutes once by pressing the lock button on the fob during the run cycle.
    Like the dealer installed option, the vehicle will shut off when a door is opened. Unfortunately, this behavior cannot be disabled (at least in any manner I know of or that Toyota supports…if anyone knows of a trick here, please share!). Additionally, range is limited to the same as that imposed by the fob, which admittedly is not great! Line of sight is required and distance is definitely a limiting factor, but this is equally true with the OEM option.
    However, a range extending antenna, fully supported by the manufacturer, can be added that will improve this considerably. If you’re really feeling froggy, the manufacturer also supports integration with the CarLink module, which allows the truck to be started using a mobile app from anywhere with cell service. It will also lock and unlock the doors. The first year of service for this device is included in the purchase, and costs $40/yr thereafter.
    I did not add the CarLink module in my use case, as it wasn’t needed. However, research does suggest it works well with this system.
    The only caveat, other than the range and shut off on door open mentioned above I would point out is Start-X will only provide support (which is generally very good) for units purchased new from an authorized reseller like Amazon or EBay. They absolutely will not provide any support for units purchased used, as you would not be able to produce the purchase order number they demand when requesting support.
    Overall, my experience with the device has been great. It does take a little practice to get the timing right on the button presses to start the truck, but once that is learned, it does its job very well! It’s definitely something I have recommended to others, and their kits are available for many other manufacturers and models as well.
    Hope this helps someone on the fence about one of these systems! Thanks for tuning in!
  2. Apr 4, 2023 at 6:38 PM
    jrgrieve
    jrgrieve Well-Known Member
    Justin
    2022 Tacoma SR
    I appreciate the write up.
    Yoda_Mike[QUOTED][OP] likes this.
  3. Apr 4, 2023 at 6:39 PM
    Yoda_Mike
    Michael
    Happy help! :bananadance:
  4. Apr 8, 2023 at 11:06 AM
    RickTacoma2023
    RickTacoma2023 New Member
    Rick
    2023 Tacoma
    I had luck so far. I installed in my 2023 Tacoma sr5 that didn’t come factory
  5. Jun 15, 2023 at 8:06 PM
    TacomaMike25
    TacomaMike25 Well-Known Member
    2012 Tacoma SR5 4cyl 4x4
    2 inch lift, Level 8 Mk6 wheels 16x8 with a 275/85r16, Aftermarket fogs with yellow bulbs, AVS bug deflector, Weather Rain guards, secondary air filter delete. PIAA halogen bulbs
    Installed this on my tacoma and our rav4. Simple install and its not horribly priced. Had it for a year now no issues
  6. Jun 15, 2023 at 8:07 PM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    Did one in our 4runner, was a pretty straightforward easy instal.
  7. Sep 28, 2023 at 8:48 PM
    OvrlndBigAl
    OvrlndBigAl Well-Known Member
    Alex
    Some where in Idaho!
    Cement 2019 TRD OR DCSB
    Just a Snug Top with Sportsman’s package 1 inch lift and 265/75-16 Duratracs.
    Any updates on this kit? Has it worked well or have you had any issues?
  8. Sep 29, 2023 at 3:43 AM
    Yoda_Mike
    Michael
    I’ve had no issues with it thus far. Starts my truck as expected every time.
  9. Oct 22, 2023 at 8:09 PM
    cnelson3225
    cnelson3225 Member
    Christian
    2011 Tacoma TRD Off Road
    Nice write-up.
    Didn't know it would shut off when the door opens... Personally I don't think that's worth the benefit of using the factory fob, I think I'd rather have a separate fob and it stay running when the doors get opened.
  10. Dec 15, 2023 at 7:02 PM
    Tan Ten Ten
    Tan Ten Ten Member
    2018 SR5
  11. Dec 26, 2023 at 7:06 AM
    TacomaTRD2020
    TacomaTRD2020 Member
    Hi,
    I decided to instal this system to my 2020 Tacoma TRD off road. Easy installation.
    The only one problem is lack of option to unlock door with use of smart app module.
    I can start, stop, lock , and check gps location of my truck, but door unlock will not work. You can still unlock door with use of oem remote, but not with use of app.
    I am wondering if it is possible to change. Otherwise I will need to return this system and buy something else.
  12. Dec 26, 2023 at 7:27 AM
    BkerChuck
    BkerChuck Well-Known Member
    Chuck
    Etters, PA
    2017 Tacoma TRD Sport Blazing Blue Pearl
    Just installed one of these a few weeks ago and loving it. No more going out to an ice cold vehicle and having to scrape windows and wait for it to warm up. Best mod yet.
  13. Dec 26, 2023 at 9:19 AM
    TacomaTRD2020
    Do you have smart app module for it to start your truck with use of phone?
  14. Dec 26, 2023 at 9:25 AM
    BkerChuck
    Chuck
    Etters, PA
    I don't. For me I didn't feel it would be worth it. My use is almost exclusively within the range of the fob.
  15. Dec 26, 2023 at 11:01 AM
    TacomaTRD2020
    Thanx. Even without smart app module it works great.
  16. Jan 4, 2024 at 7:26 AM
    skyitalia5
    skyitalia5 Well-Known Member
    Joe
    Seymour, CT
    2017 TRD Sport DCLB BBP
    TRD Pro Skid Plate TRD Pro Grille TRD Pro 17" SEMA Wheels Kicker Tweeter, Front/Rear Door Speakers
    this is great to know! Thanks for sharing!
    Yoda_Mike[OP] likes this.
  17. Jan 8, 2024 at 11:38 AM
    jlcalbre
    jlcalbre New Member
    Jeremy
    2023 Tacoma SR5 4x4
    Start-X, CarLink,
    I just installed this in in my 2023 SR5 with the CarLink kit. Works great. Super easy install. The app does not unlock the doors, which is a little annoying but overall not a big deal. I'm much more interested in locking my doors and starting the vehicle from a distance (Like when I'm at work or the gym). I can always unlock it when I walk up to it. Car Link also has an Apple Watch app so you can lock/start/stop from your watch as well which is pretty cool
  18. Jan 9, 2024 at 5:32 PM
    TacomaTRD2020
    I think app is giving a command to unlock door, but remote start harness has no wire for unlocking. I see leds in remote starter module are changing when I am pressing unlock in app, but nothing happens. In my opinion it is locked in settings or no cable for door unlock in T-harness.
  19. Jan 9, 2024 at 5:35 PM
    jlcalbre
    jlcalbre New Member
    Jeremy
    2023 Tacoma SR5 4x4
    Start-X, CarLink,
    I reached out to Startx customer service and they said the unlock feature is not available on the Tacoma. Whether it’s in the unit, the wiring, or the truck itself, seems the lack of unlocking is the correct behavior.
  20. Jan 9, 2024 at 5:41 PM
    TacomaTRD2020
    Correct.
    They sent the same information to me as well.
    Somebody told me that he can unlock truck via app with N2 Design starter.
