Soft/Deep Sand Driving Tips
Discussion in 'Off-Roading & Trails' started by Rhaven44, Apr 2, 2024.
  1. Apr 2, 2024 at 7:36 PM
    Rhaven44
    Rhaven44 [OP] Member
    Rhaven
    2023 Tacoma SR
    Just got stuck big time in some soft and deep sand the other week. Was stuck for 6 hours and had to be winched out.
    Any tips to keep me out of trouble next time? Also, any upgrades I should do to ride on sand better?
    edit: truck is 2023 Tacoma SR on 265/70/17 Goodyear Wrangler MT’s, and I just got some kinetic ropes, shackles, and a set of MaxTrax.
  2. Apr 5, 2024 at 9:15 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Looks like you dug yourself in. When you feel the tires start digging in, stop and do something else. Did you air down? Dropping your tire pressure to 10-15 pounds will help a lot. Of course you'll want to air back up soon after hitting pavement again so you should add a pump to your stuff.
    Kinetic ropes and traction boards would have helped, but you need to know how to use them.
    If you can have more than one vehicle or a group helps a whole lot. Certainly if they are experienced.
    Frog4aday likes this.
  3. Apr 5, 2024 at 9:23 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Airing down as said above will be the best advantage.
    My truck is 2wd and I’ll go most anywhere in sand aired down to 10-12psi. Just gotta drive smart.
    Stop pointed down hills, carry momentum, and when starting to get stuck, straighten your wheel if possible. Don’t floor into it like said above. From your picture, that looks exactly like what happened there.
    expect to get stuck. Use maxtrax for easy self recovery if not dug in too deep. If you do dig down by accident, use a shovel or the boards themselves to dig out a mellow “ramp” on each tire back to level ground.
    you live and learn, and get better every time. I’ve been driving dune and beach sand for about 6 years, and still get stuck once a trip to pismo.
    ridefreak likes this.
  4. Apr 5, 2024 at 9:42 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    10-12 PSI is all you need.
    100% stock, I promise. I was just running in 2wd to do some roosters up hills.
  5. Apr 5, 2024 at 11:41 PM
    Rhaven44
    Rhaven
    2023 Tacoma SR
    Was at 15psi, which worked well enough for the beginning section of the beach. Went out on a little adventure, got stuck and floored it. First time, lol (yikes). Lucky enough to live in Hawaii, had 3 cool braddahs help me get unstuck but to no avail. Had to wait for the 4th to winch me out. Great experience, learned lots! Got some brand new max trax, kinetic ropes, and an assortment of shackles.
    wish me luck next time lol
    Sterling_vH111 likes this.
  6. Apr 6, 2024 at 9:33 AM
    Sterling_vH111
    Sterling
    socal
    As I said live and learn bro !
    Sand is great fun.
    Having the recovery equipment to either help your self, or have others help you is very valuable
  7. Apr 18, 2024 at 6:24 PM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
  8. Apr 18, 2024 at 6:45 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    That's pretty impressive, that truck was buried in blow sand (the worst kind).
    Marc70[QUOTED] likes this.
  9. Apr 18, 2024 at 11:52 PM
    BKinzey
    Beauford
    Hollywierd, CA
    I learned that from Matt's OffRoad Recovery videos! To continue with a subtle biased old white man comment:
    "Nice sandals. I wonder if they come in a men's style?"
  10. Apr 19, 2024 at 12:45 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    07 Double Cab
    Biggest tip is don't go alone. Especially on the beach. Trucks are prone to getting stuck in our nice powdery sand
