Ziebart Undercoating?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Norsk, Feb 22, 2020.
  1. Feb 22, 2020 at 3:55 AM
    Norsk
    Norsk [OP] Well-Known Member
    2024 Underground Gray Tacoma TRDOR Premium
  2. Feb 22, 2020 at 4:00 AM
    Tacoma Mike
    Southern Maine
  3. Feb 22, 2020 at 4:02 AM
    Norsk
    Really? I didn't know.
  4. Feb 22, 2020 at 4:03 AM
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    If you live in the Rust Belt states where they are doing the CRC treatments on frames I would go that route first or see if Toyota will cover yours. Defiantly do something though if you plan to keep your Tacoma long term and you live in rust prone areas.
    Tacoma Mike likes this.
  5. Feb 22, 2020 at 4:03 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Find someone local that does Fluid Film and do it every year from now on. This has been fluid filmed since new in 2015.
    birdbrooks likes this.
  6. Feb 22, 2020 at 4:05 AM
    Tacoma Mike
    Southern Maine
    It looks great on the outside.
    However if the salt creeps into a area it sits there.
    I found one by accident.
    It looked great then i stuck my finger right through the frame. Would have never known..
    Kolunatic likes this.
  7. Feb 22, 2020 at 4:08 AM
    Norsk
    Wow, guess ill use my money to get tonneau cover!
    Okay, how much does the fluid film cost? Where can I find the shop that does it? I am in Delaware.
  8. Feb 22, 2020 at 4:10 AM
    RLMoody
    Ziebart didnt fail the frames.
    Toyota did when they used cheap metal and we aloud them to get away with it by continuing to buy these trucks knowing the frames are crap. We failed ourselves and only have ourselves to blame for letting Toyota get away with this. Stop buying these trucks and then Toyota may do something about it.
    Im about ready to replace my wifes 13 Sienna and we have only bought Toyotas since 1992. Not sure what I will buy next but I do know it wont be another Toyota. Im leaning towards Honda or Mazda right now.
    Putzcommander likes this.
  9. Feb 22, 2020 at 4:10 AM
    Norsk
  10. Feb 22, 2020 at 4:22 AM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Ziebart will ruin your vehicle. Some mechanics will even refuse service for it. Stick with yearly oil sprays if you’d like to keep it more than 10 years.
  11. Feb 22, 2020 at 4:26 AM
    Loaded NightraiN
    Loaded NightraiN Well-Known Member
    17 TRD Off Road
    Got ziebart done the week I bought my truck. Just got my 3rd annual touch up done this week. Guess we'll see in the long run :notsure:
  12. Feb 22, 2020 at 4:30 AM
    Fire Arrow
    Fire Arrow Hanging out at work
    Jim
    MD
    2016 Black DCSB SR sold, 21 Tundra Limited MGM
    Care to elaborate on how it was ruined? Why did the mechanic refuse to work on the truck?
    cwdog likes this.
  13. Feb 22, 2020 at 4:36 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    I am in Florida so I don't know a thing about coatings, other than observation. My brother-in-law lives in Maryland and owning a landscape business he has many vehicles that he has had coated over the years. I will never do Ziebart on any of my vehicles no matter where I live. The Fluid Film seems like a better option. I can't see how anyone can do any maintenance on a vehicle wit Ziebart coating.
  14. Feb 22, 2020 at 4:48 AM
    Eddie1958
    Eddie1958 Well-Known Member
    ED
  15. Feb 22, 2020 at 5:08 AM
    Eddie1958
    ED
    In addition to the above TST treatment under the hood. Those of you that keep it spotless in the engine dept. Dust sticks like fluid film and if you look its sort of like a sticky film. I have removed it from most of the painted surfaces trunk lid, radiator supports ect.. using 303. Jet. I did all of this before i discovered this place. Looking back I think I did the correct thing because I am old and it will be a battle to see who goes first. And when I am 70 I may not want to be crawling under my equipment any more.
  16. Feb 22, 2020 at 5:23 AM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    I got the kit a few years ago on Amazon.
    For 150 bucks, it comes with everything you need.
    All you need is an air compressor and a set of ramps. Easy-peasy.
  17. Feb 22, 2020 at 5:49 AM
    TRDCal
    TRDCal Well-Known Member
    Canada
    2018 DCSB Sport MT
    I wouldnt recommend any rubberized undercoating....they all provide protection for a while but then once moisture gets behind coating, it accelerates rust.
    I DO however go to Zeibart annually for the a wax style rust protection treatment. I prefer it over Krown, seems to stick better and by spring my frame etc is still completely coated where with Krown it would seem to also wash off after a couple months.
  18. Feb 22, 2020 at 6:29 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    No Ziebart and nothing like Ziebart. Never Ziebart anything. Honestly promotes vehicle corrosion in all cases, no exceptions. Traps moisture and salt against the frame.
    Shellshock and Tacoma Mike like this.
  19. Feb 22, 2020 at 6:44 AM
    Shellshock
    Iowa
    I’ll stick to fluid film
  20. Feb 22, 2020 at 6:45 AM
    Rising Eagle
    Rising Eagle Well-Known Member
    Berkshires MA
    2020 DCSB OR
    OP, Fluid Film and Krown are the best products to use. Many in the North Country rust belt swear by Krown. I use fluid film on my Jet Skis when I winterize them but use Krown on my vehicles.
    The problem with Ziebart is moisture and salt always manages to find it's way between the sealant and the frame. It sits there because there is alack of air to dry it out and the chemical reaction begins (rust). The thing is you can't see it.
    As for mechanics, I personally know 2 mechanics in the Watertown, NY (Fort Drum) area that will not touch an older vehicle that has been undercoated. Why? 1. responsibility. 2. it opens up a rats nest of rot and cascading problems when all they want is to complete the job, get paid and get the vehicle out of their garage.
