Zero Point Calibration 3rd Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Aedz, Mar 5, 2019.
  1. Mar 5, 2019 at 6:14 PM
    Aedz
    Aedz [OP] Member
    Aedan
    2016 Trd Sport
    Hey everyone,
    Wondering if anyone has experience manually doing a zero point calibration on their 3rd gen? I’ve read up on it and it seems simple with a paper clip, but all the forums are about 2nd gen Tacos. Anyone done it on their 3rd gen? Does it work the same way? Just don’t want to do more damage.
    Thanks!
    Kyebasse likes this.
  2. Mar 5, 2019 at 6:22 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    From the 3rd gen fsm...
    I've done it; it works.
    wahoobie, scocar, hrivera007 and 5 others like this.
  3. Mar 5, 2019 at 6:35 PM
    Aedz
    Aedz [OP] Member
    Aedan
    2016 Trd Sport
    Don’t know how I missed that when I was looking. Thanks for the reply!!
  4. Mar 5, 2019 at 7:09 PM
    xxtavixx
    xxtavixx Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    Ignorant...wasdis do?
    IEsurfer likes this.
  5. Mar 5, 2019 at 8:42 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    VSC (vehicle stability control) uses vehicle speed, yaw rate sensor in an ecu, and steering wheel angle to calculate if the vehicle is going where the driver intends or is skidding. If detected, the truck will try to correct it.
    So if truck detects the steering wheel is turned (measure angle), and truck is moving (measure wheel speed), ECU will expect to see a yaw rate (turn rate assuming no slipping). If ecu doesnt detect the expected yaw rate within some error, it will fire brakes on one side of the truck thru abs system to try to obtain the expected yaw rate. This has the effect of reducing skidding out of control.
    So truck needs to know where straight ahead is on steering wheel so it can measure how many degrees of turn are currently commanded. It uses a sensor in the steering wheel to measure that angle. ECU will check to see if its 0 calibration on steering wheel correlates to zero yaw enough of the time (in certain conditions, etc). If it detects zero yaw isnt at zero steering angle, will give an error.
    To fix, need to reset the zero point at the steering wheel in the ECU. This can get out of whack after curbing, or lifting, or suspension work, alignments etc.
    musicisevil, SR-71A, scocar and 9 others like this.
  6. Mar 6, 2019 at 2:09 AM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Thanks!
  7. Mar 29, 2019 at 7:18 AM
    c00lm0n
    c00lm0n Taco Mainiac
    Maine
    2017 SR5 DBCB 4x4 V6
    Exterior: Bilstein 5100s x4, OME 887s, ICON AAL, SPC UCAs, 265/75R16 Falken Wildpeaks A/T3W, Camper top w/ Yakima racks, tube steps, OEM bed mat Interior: Kenwood DMX7704S w/ 6" Kicker speakers and tweeters, all weather mats
    So I just lifted my 3rd gen with 5100s, OME 887s and and an AAL plus some slightly bigger tires, about 2.5" total. I'm noticing some floating or wandering at higher speeds. Would resetting the the zero point in the ECU help fix this? Thanks for any info in advance.
  8. Mar 29, 2019 at 8:28 AM
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    What you’re describing is either an alignment issue (i.e. add more caster) or just a function of a lifted truck.
    ZPC would be a fix if, for example, your Stability control system kicked in during regular driving (typically on or off ramps or turning from a stop) after your lift.
    OA
    Gingerbeard Man and splitbolt like this.
  9. Mar 28, 2020 at 3:22 AM
    Jbain
    Jbain Member
    2020 Off Road
    I have a 2020 Tacoma and my pinout is different, any chance someone has access to the location of the 2 pins required on this port? Thanks in advance.
  10. Mar 28, 2020 at 5:23 AM
    Beancooker
    Beancooker Alea iacta est
    The middle of Arizona
    2021 Jeep Wrangler Rubicon
    Lots, straight from the factory.
    @Jbain, yours looks the same as the guide. Both have 16 pins.
  11. Mar 28, 2020 at 6:02 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Do the look at the number of pin openings, look at the pin openings that are populated.
  12. Mar 28, 2020 at 6:08 AM
    Beancooker
    Ahhh, now I see. Had to blow up the photo a lot to see that detail.
    Skydvrr likes this.
  13. Mar 28, 2020 at 6:17 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    This is an OBD II that does have some requirements to meet standards. Unfortunately the port 12 is not one of the standard ports, it is an option for the manufacturer. Chances are they would be the same to reduce the need for different interface adapters, but stranger things happen.
    tonered likes this.
  14. Mar 28, 2020 at 8:39 AM
    TacoTime850
    TacoTime850 Always Maybe Sometimes Never
    Everywhere and Nowhere
    2019 DCSB 4x4
    2.5” lift, Fox 2.5 ext tvl adjustable w/ DSC, SPC adjustable UCAs, Icon RXT leaf pack, Superbump stops, 17x9 Fuel Podium Bronze wheels, 285/70/17 Cooper STT Pro
    The beat answer for this question is simply, no
  15. Mar 28, 2020 at 1:39 PM
    Jbain
    Jbain Member
    2020 Off Road
    Any Toyota Techs have access to the new pinout for the 2020's?
  16. Mar 28, 2020 at 2:45 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    2016-2019 DLC3 has the following pins:
    4 - CG
    5 - SG
    6 - CANH
    7 - SIL
    9 - TAC
    12 - TS
    13 - TC
    14 - CANL
    16 - BAT
    2020 DLC3 has the following pins:
    5 - SG
    6 - CANH
    7 - SIL
    13 - TC
    14 - CANL
    16 - BAT
    Toyota removed the wire running from the ABS ECU to the DLC3 connector. Interesting fact though is that the ABS ECU itself is the same for 2020, so I suspect if you wanted to be able to do the same thing, you could just add a terminal and tire to Pin 24 of the ABS ECU connector and ground it to the vehicle's chassis and it would be the same as jumping 4-12 on a 2016-2019.
    Vacuum-Type Brake Booster:
    82998-24420 - Terminal W/Wire, Connector (Alternate: 82998-12780, 82998-12790)
    Hydraulic-Type Brake Booster:
    82998-24250 - Terminal W/Wire, Connector (Alternate: 82998-74030, 82998-74040, 82998-24260)
    Jeff
    wahoobie and tonered like this.
  17. Mar 28, 2020 at 3:03 PM
    Jbain
    Jbain Member
    2020 Off Road
    Thank you so much Keff, seems Toyota got wise to it.
  18. Aug 24, 2020 at 1:59 PM
    BudLoomis
    BudLoomis Well-Known Member
    Colorado
    2018 TRD Off-road
    Toytec Aluma Series 2.0 (2.5" x 3.5" lift), JBA UCA, Deaver stage 3 Leaf pack, CMC, Viair OBA set-up, KBVOODOO mid rack, Roofnest Condor RTT, CaliRaised Premium Roof Rack w/ 360 lighting, Custom Bed box w/ camp stove built in
    Hey, I just tried this on my 2018 TRD OR and can't really tell if it worked... The only lights that would flash we're we' TPMS and airbag lights. Any advice?
  19. Aug 24, 2020 at 2:57 PM
    splitbolt
    NW Arkansas
    Are you sure you're jumping pins 4 and 12; and not 5 and 13?
    Is your connector wide side up or down?
  20. Aug 26, 2020 at 4:58 PM
    BudLoomis
    Colorado
    2018 TRD Off-road
    You're right I was doing it upside down, but even when I do it the right direction, it does not do anything. Anyone else having trouble on 2018 with push start ignition?
