Zerks & Grease
Discussion in '1st Gen. Tacomas (1995-2004)' started by gonathan85, May 11, 2010.
  1. May 11, 2010 at 3:45 PM
    gonathan85
    gonathan85 [OP] Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Question regarding zerk fittings, and grease....and yes...I used the "SEARCH" function...but didn't find relevant info for my truck.
    I have a 1998 4x4 2.7l tacoma that I need to put a grease gun to...anyone have a .pdf manual that shows the locations of these? What type of grease should I use?
    Help me stay out of the "stealership" scam =).
    Thanks,
    Nate
  2. May 11, 2010 at 4:02 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Assuming everything is still stock, the only thing greasable is the drive shaft. There are 8 grease fittings on my 02 4x4 on the 3 sections of drive shaft (3 on the front drive and 5 on the rear drive). I seem to remember it was the same for my 98 also.
    I use white lithium grease.
  3. May 11, 2010 at 4:08 PM
    gonathan85
    Nate
    Central California
    Alrighty sounds good. Thanks for the reply. I'm assuming you don't use the aerosol can stuff...was trying to find some white lithium grease that would fit inside a grease gun...or am I "doing this wrong?" haha
    Edit: found it in the tube....and this stuff is EXPENSIVE.
  4. May 11, 2010 at 5:53 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    I read a real detailed write up, either on here or the TTORA forums, I can't remember, but yeah, all you have to grease is the drive-shaft.
  5. May 11, 2010 at 6:28 PM
    Skolfoppa
    Skolfoppa Member
    MN
    Black 3.4 TRD
    BFG TAKOs, Deck Plate, k&n, Bullie w/ PIAA 520s, Alpined w/ 8" sub, All Mobil 1 synthetic.
    Check the FSM. You don't want to overgrease the shafts. The spiders can take a few squeezes. FSM for 5vz, 4x4 calls for 2 different grease applications. Spiders take lithium #2. Slip yoke and cardan get Moly. Skol.
  6. May 11, 2010 at 7:53 PM
    gonathan85
    Nate
    Central California
    Would be nice if I had a copy of this...is there a .pdf of the FSM floating around?
  7. May 11, 2010 at 8:26 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
  8. May 11, 2010 at 9:02 PM
    gonathan85
    Nate
    Central California
  9. May 11, 2010 at 10:00 PM
    scocar
    scocar hypotenoper
    You do not want to use white lithium grease. That is completely the wrong lubricant. Don't confuse "lithium" with "white lithium." You need an NLGI 2 grade grease.
    All the drive shaft yokes and the double-cardan joint take molybdenum disulfide NLGI 2, and the U-joints (spiders) take lithium disulfide NLGI 2, I think. It's in the FSM. It should also be in the back of your owner's manual.
    All the auto stores have it. And you will find that it is far cheaper.
  10. May 11, 2010 at 10:04 PM
    gonathan85
    Nate
    Central California
    Ok. Thanks for clearing that up. Good stuff.
  11. May 12, 2010 at 7:01 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Overgrease :confused:
  12. May 12, 2010 at 7:03 AM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    I have 9 zerks on my taco...Just use "Lucas Red N' Tacky #2" all around"...Great Product!!! :D
  13. May 12, 2010 at 7:33 AM
    strongwxnc
    strongwxnc Well-Known Member
    Bostic, NC
    2002 Xtra Cab SR5 2.7L 4WD
    Bushwacker bed rail caps
    Try here <--- This is a must have link. Man I glad I found it!!!!
    This link is found within this site...
  14. May 12, 2010 at 8:35 AM
    gonathan85
    Nate
    Central California
    solid! thanks.
  15. May 12, 2010 at 8:55 AM
    gonathan85
    Nate
    Central California
    It almost seems like this is one of those "grey" areas. I'm curious if there is a definite way this service NEEDS to be done. I suppose it could be said that the actual "Factory Service Manual" is what is best for the truck, but people have been doing things different than the original manufacturer for their vehicle for who knows how long...hmm.
  16. May 12, 2010 at 10:23 AM
    Skolfoppa
    Skolfoppa Member
    MN
    Black 3.4 TRD
    If the driveshaft takes in too much grease it can "hydrolock" and damage the T-case. Skol.
  17. May 12, 2010 at 10:43 AM
    strongwxnc
    Bostic, NC
    Thanks skol. I was unaware of that. I hope I did not overgrease. I put it in until I could see some come out.
  18. May 12, 2010 at 11:32 AM
    Skolfoppa
    Skolfoppa Member
    MN
    Black 3.4 TRD
    On the shaft you will see more of the piston(shiny metal surface) as more grease is applied. You can always back out the zerk bolt and back up on a curb to compress the shaft and squeeze out the excess grease. Not a big concern on the spiders except they tend to fling the grease all over the undercarriage. Skol.
  19. May 12, 2010 at 11:45 AM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
  20. May 12, 2010 at 11:46 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you referring to the slip yoke? And when you say spiders, don't you mean U-joints?
    But yeah, if there's too much grease in the slip yoke, it can't compress properly during suspension travel. When you're greasing it, as soon as you see it moving outwards, that's a good time to 'stop' greasing.
