Zerex( valvoline) vs Toyota Red antifreeze
Discussion in 'New Members' started by taco1genlover, Sep 30, 2020.
  1. Sep 30, 2020 at 8:40 PM
    taco1genlover
    taco1genlover [OP] New Member
    IMG_0117.HEIC.jpg Hello,
    Im a new member, very glad to join the Tacoma community. Recently bought a 2003 prerunner with 184,000 miles. I have serviced the rear differential oil with STP 80w-90.The tranny with valvoline Maxlife. Greased the U-joints. Cleaned the power steering reservoir and put new fluid(maxlife also).Have I done wrong using non-toyota ATF?
    I realize that Toyota OEM fluids are better but has anyone used Zerex that can recommend it?, I want this truck to last me at least until 300K, any advice will be appreciated.
    Thank you
  2. Sep 30, 2020 at 9:19 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
  3. Oct 1, 2020 at 5:15 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
    Follow manufacturer recommendations.
    taco1genlover[OP] likes this.
  4. Oct 1, 2020 at 6:12 AM
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    El Paso, Texas
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    Fantastic looking truck! Welcome to Tacoma World!
    Of course, if you can get the OEM Toyota fluids I would say go for that. Dollar for dollar you're not looking at much price difference. If you buy it online that is, the dealership will shaft you.
    However,
    Lots of people run Non-Toyota fluids, Issues cropping up due to different brands are far and few between. Of course there are exceptions and someone will probably chime in here to say that. Each vehicle is going to be different, a list of the variables between vehicles that were fine without OEM fluid and those that were not would be insane to compile.
    If you want to keep it all Valvoline (I understand that urge) I do not see any problems with using Zerex, for what my opinion is worth that is. I have not heard of crazy issues because of it. Just do a solid, full system flush beforehand. Get enough distilled water (more than you think you'll need) to run through the system until it comes out crystal clear.
    You'll probably hear about how your service interval will be shorter than if you had just gone OEM or something to that effect. Even if it only lasts three years instead of five, at an estimated 100$ a flush, that's only 133$ more over a ten year period. Everybody is different on what they prefer.
    Good luck!
  5. Oct 2, 2020 at 9:53 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  6. Oct 2, 2020 at 9:57 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    TBD
    Welcome! I think the main issue is mixing coolant types. I also will only use Toyota coolant in all of my Toyotas. YMMV
