Zerex red with OEM Toyota coolant
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoTaco02, May 23, 2021.
  1. May 23, 2021 at 3:06 PM
    TacoTaco02
    TacoTaco02 [OP] Well-Known Member
    Illinois
    02 Ext Cab SR5 TRD 4x4 V6
    Has anyone had any issues mixing Zerex Red Asian vehicle coolant with oem pink? I am assuming oem Toyota coolant is in the truck since it is pink/red and I saw a service record for coolant flush from the dealer a few years back.
    Anyways, in going on a long drive with the truck and noticed some drips that I presume are coolant since it wasn't oil and my power steering and brake fluid were at the max. My level in the overflow tank with a cold engine (ran for 60 seconds to move the truck) was the same level as the photo in this thread. https://www.tacomaworld.com/threads/coolant-leak-found-it.293356/ I am assuming the coolant should be at the F mark when cold. Based on the drops it seems like the leak is from the rear right of the engine. Any ideas what may be leaking from that general area?
    I'm going to get back under it tomorrow and poke around.
  2. May 23, 2021 at 4:40 PM
    Taco_Chad
    Taco_Chad Active Member
    Chad
    1998 Toyota Tacoma SR5
    coolants are generally compatible, but mixing may decrease the lifetime, depending on what is mixed with what
    Once you track down your leak, it's a good time to do a flush anyway
  3. May 23, 2021 at 5:26 PM
    slodoug
    slodoug Well-Known Member
    flushed mine yesterday, filled back with zerex pre-mix. Used coolant was a little weak but still pink, no signs of oil or that much dirt.
  4. May 24, 2021 at 5:42 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Since My Coolant seldom stays in longer then 2 years I mix it with any but Green which makes a Horrid Brown Color.
    A cooling system pressure tester is great for finding leaks removes much of the guess work.
    Xbeaus likes this.
  5. May 24, 2021 at 8:09 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    In a pinch you can just use water. Truck won't explode if you don't use 100% OEM coolant.
    If you happen to mix coolants, but flush it as soon as you can and run all the same stuff. Doesn't really matter what stuff you use, though.
    Running Board Man likes this.
  6. May 24, 2021 at 8:33 AM
    TacoTaco02
    Illinois
    Alright, crisis averted. I park my vehicle on the street and my driveway has a steep angle to it. What happened was the the frame had water and dripped diluted Fluid Film on the driveway leaving a very fluid substance with a mild greasiness to it.
    I was able to clean the overflow tank and can now clearly see the L and F marks so I'll be adding some Toyota or Zerex fluid to it.
    Thanks everyone!
    jbrandt likes this.
  7. May 24, 2021 at 8:52 AM
    TacoTaco02
    Illinois
    I checked the coolant and it is clean with a really good freeze point.
    Again, before I purchased it 2 years ago it had a coolant flush at the dealership. I'm looking to top it off and noticed:
    Zerex Asian = HOAT
    Peak Asian = POAT
    Prestone Asian = POAT
    I hear Zerex is a great coolant but seeing it is listed as a HOAT vs the POAT of the other two are there any concerns or recommendations between them when topping off the coolant?
    I'm used to using the old universal green Prestone so this new stuff is new to me!
  8. May 24, 2021 at 9:05 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    During the summer you can add distilled water but need to flush it before winter weather to ensure proper winter mix ratio. You can by Pentosin, I was told that's who Toyota buys their coolants from.
  9. May 24, 2021 at 9:12 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    HOAT contains Silicates which Toyota specifies not to use.
    PHOAT contains phosphate and Silicates. Double No No
    POAT is the recommended coolant for Toyota and is what they use.
    Add distilled water and test again or drain, flush with distilled untill clear.
    Drain from radiator untill empty.
    Add 1 gal Red full strength and distilled water till full.
    You end up with 50/50 mix if you don't drain the block because 1.3 gal. of distilled remains in the block.
    stevesnj likes this.
  10. May 24, 2021 at 9:17 AM
    Running Board Man
    Running Board Man Well-Known Member
    Doesn't matter what you use as long as it isn't mixed
  11. May 24, 2021 at 3:05 PM
    Running Board Man
    Any time I mess with coolant I always take out the t stat and flow a garden hose through the upper rad hose through the rad through the block and out the tstat housing
    To get rid of any old coolant not drained from the plug in the radiator
    Than I blow compressed air in the same way to evacuate as much water as I can
    Than fill with equal parts concentrate and water
  12. May 24, 2021 at 5:14 PM
    stevesnj
    The Toyota engineers know best. Distilled water is best not hose water.
  13. May 24, 2021 at 5:16 PM
    Running Board Man
    I'm sure they do, doesnt mean universal green doesn't work fine
  14. May 24, 2021 at 5:19 PM
    stevesnj
    That's why to use exactly to put in what you take out. I want what works right, not fine.
  15. May 24, 2021 at 5:38 PM
    Running Board Man
    I'm fine using it because tap water local to me is just filtered sewage so it's pretty deposit free, not going to say it's 100% but it did fine on my truck for literal decades, cooling passages still looked new when I opened them up for the final time after I wrecked it
    stevesnj[QUOTED] likes this.
  16. May 24, 2021 at 5:40 PM
    Running Board Man
    Green works right, doesn't freeze, doesn't corrode metals or degrade rubbers and raises the boiling point of water, you're just being anal which there's nothing wrong with
  17. May 24, 2021 at 5:44 PM
    stevesnj
    Yeh it's wrong, but you do you.
    Wulf likes this.
  18. May 24, 2021 at 6:48 PM
    Running Board Man
    I guess me and my vehicles' cooling systems will be wrong the 7 days a week I drive them and none of the times they've overheated despite towing ~6k lbs or driving flat out on the highway till I hit speed limiter and stay there till I get to the exit before my departure off the expressway
  19. May 25, 2021 at 5:36 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    It protects against Freezing it raises the boiling point .
    All the other crap is for people that never open the hood the only time they see coolant is when it is dripping on the ground.
    It is the fact coolant is not changed in the life of the vehicle in some cases why coolant has become so brand specific.
    If my coolant sees 20,000 miles before being changed it is a long time.It is long periods of not changing that can cause damage to the cooling system internals.
    I mix everything but red and Green once was enough
    One failure after soldering a Radiator I took water out of the creek beside the road. Better then an Expensive towing Bill or very long walk.
