You ever have an Oil filter gasket blow out ?
Discussion in 'Technical Chat' started by markwnc, Oct 20, 2008.
  1. Oct 20, 2008 at 6:05 PM
    markwnc
    markwnc [OP] New Member
    After it blowed out it immediatly emptied all the oil out and shut the engine off.
    I removed the filter and the DOUBLE gasket, put on a new filter and filled with oil.
    When I started the engine it has a slightly noticable whine like timing gears or chain maybe.
    I was traveling and have drove the truck about 600 miles thus far.
    This is a 2005 v6 .
    You guys ever have this happen to you or ever hear of someone that
    this has hppened to?
    I was wondering if this will effect my engine in a bad way and if it will
    what do I need to do about it?
    Thanks from the newbie in advance.
  2. Oct 20, 2008 at 6:14 PM
    Taco's for All
    Taco's for All Well-Known Member
    Lake George, NY
    2019 Tacoma TRD Off Road Double Cab
    Nothing at the moment
    Did you notice it blew out before or after you lost all of your oil? How long did you run your motor without oil?
  3. Oct 20, 2008 at 6:35 PM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    how does it blow out? u mean the gasket on the oil filter leaked? please explain so i can do it myself if shit hits the fan? what kind of oil filter did u use?
    thx
  4. Oct 20, 2008 at 6:59 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Did this once on a Bronco II I had. Second time I'd ever done an oil change. I didn't notice that the gasket from the old filter was still on the engine. When I started the engine oil sprayed everywhere and sounded weird. I shut off the engine after maybe 30 seconds?. I pretty much did the whole oil change over. Didn't have any long term affects that I know of. I had the Bronco another five years or so with no engine problems. It took a little while for the oil to burn off the engine though.....
    I'd say if you didn't drive it or only let it run for a few seconds then it's probably ok.
  5. Oct 20, 2008 at 7:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Excactily!
    I had this same thing happen to me in my old truck. The gasket from the previous filter remained in place, and I installed a new filter not paying enough attention. FORTUNATELY, I noticed it leaking when warming the engine and doing some other work on it.
    OP, You should be OK as long as it wasnt driven with no oil.
  6. Oct 20, 2008 at 7:42 PM
    markwnc
    It was obvious when it happened it made a loud spraying noise and smoke came out from under the hood then the engine shut off.
    I put it in neutral and coasted to a safe spot to the side of the road.
    I just bought this truck used about three months ago and dont drive it much
    maybe once a week then started on a trip and this happened.
    So the oil filter change was done by someone else before the puchase.
    I had to drive a screwdriver through the filter to get it off.
    It pretty much destroyed the filter but when I got it off I noticed the extra gasket
    on the filter mount and I had to cut it with my pocket knife to get it off.
    I just need to know if the whining is something to be worried about.
  7. Feb 22, 2009 at 3:25 PM
    markwnc
    76000 miles
    btt
  8. Feb 23, 2009 at 7:31 PM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Toytec ultimate lift kit, light racing UCAs, ARB bumper and full skid plates underneath. Looking into redoing the suspension and maybe repainting the ol' Taco.
    I'd venture to say that you have lubed up one of the belts and it is slipping a bit. I'd guess the alternator belt if it is a fairly constant whine.
  9. Feb 23, 2009 at 7:47 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    ive had it happen(not in my truck, on a customers car) and as long as its not ran long with no oil in it, you should be ok
  10. Feb 23, 2009 at 8:09 PM
    WildcatRider
    WildcatRider Well-Known Member
    Lexington, KY
    2008 AC TRD-OR 4x4 SOLD
    In high school I worked at an quick oil change station and this was one of the #1 major issues they stressed. The guy below always had to show the old filter to the guy up top and confirm no double gasket. I learned at a young aged how bad this can be ;)
    From the sound of it you are probably ok, just make sure everything is clean of oil especially the belts.
