You all changing your radiator/heater hoses?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aficianado, Jul 15, 2019.
  1. Jul 15, 2019 at 5:10 PM
    aficianado
    aficianado [OP] Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    my truck is a 2006 with 165k miles.
    I went truck shopping yesterday, and it’s clear I’m keeping mine :). (Sticker shock)
    I’m thinking of some routine preventative maintenance. My hoses are original. They feel okay. No soft spots or crunchy areas.
    The radiator hoses look like “low hanging fruit”. Up front and center. Easy. Heater hoses look more complicated. It was too hot(the motor) to look closely, but it can’t be that hard.
    I have issues with the coolant. It goes everywhere, despite my best efforts to contain the spill.
    Anyone doing this? There is no clear direction on longevity of the rubber bits.
    Tips? Advice? Hate to kill my cat :D with the impending spill.
  2. Jul 15, 2019 at 5:11 PM
    aficianado
    back to bone stock.
    Oh. For kicks I called a local shop. $500. Haha. (Sticker shock #2)
    eherlihy likes this.
  3. Jul 15, 2019 at 5:13 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    If you think they need replaced, the radiator hoses are a pretty easy job. I'm not sure what access you have for heater hoses though on these engines. Definitely do the radiator hoses yourself if you have time.
  4. Jul 15, 2019 at 9:06 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    $500 to replace the hoses?! Dang, that is insane. At 100K, I replaced the coolant, hoses, hose clamps, thermostat, and belt for less than $100. That being said, the hoses looked in good shape; they could have gone 150K, but they are relatively inexpensive and provided good peace of mind to replace them.
    Edit: to be transparent, my notes indicate I did all this at 1392020 miles. Then, not too long after, at 152K, I replaced all the idler pulley bearings. Note - the belt gets in the way; thus, if replacing the belt, check the pulleys and replace them for they will be much easier to access and torque down with the belt out of the way.
  5. Jul 15, 2019 at 9:20 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    HPS silicone radiator hoses. :thumbsup:
    Look them up.
  6. Jul 15, 2019 at 10:34 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I'm at 171k miles on my 06 with stock hoses...I'll likely keep the original hoses till they fail.
  7. Jul 15, 2019 at 10:54 PM
    Chuy
    Lakeside, CA
    Silver Taco
    This why you sometimes see cars stranded on the side of the road with white steam shooting up into the sky. The don't-fix-it-if-it-aint-broke philosophy contradicts preventive maintenance.
  8. Jul 15, 2019 at 10:59 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Most of that is shop labor rates. You can DIY much cheaper.
  9. Jul 15, 2019 at 11:02 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Inspect/check every oil change and you should be fine.
    kidthatsirish and whatstcp like this.
  10. Jul 15, 2019 at 11:05 PM
    Chuy
    Lakeside, CA
    Silver Taco
  11. Jul 15, 2019 at 11:14 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    If your going to do a full coolant change to protect from corrosion.
    Seems like you mise well do the hoses. Rubber degrades.
    And knowing my luck if I didn't I'd have to replace a hose rite after the new coolant. And coolant isn't cheap.
    Lester Lugnut likes this.
  12. Jul 16, 2019 at 5:15 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I've always been amazed by the don't-worry-about-it attitude you see on this forum when it comes to belts/hoses.
    OP - your truck is 13 yrs. old. It's not just about mileage. Age also plays a factor with belts and hoses.
    If it were my truck I would get busy and start replacing rubbery stuff under the hood..
    Sprig likes this.
  13. Jul 16, 2019 at 5:16 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    It did not occur to me to change the heater hoses, I’ll look into that.
    I did change the radiator hoses, coolant, radiator cap, overflow hose and thermostat at 130k just as preventative maintenance. Was cheap, easy and fun.
    Skyway likes this.
  14. Jul 16, 2019 at 6:15 AM
    kidthatsirish
    Your idea of fail and my idea of fail might not be the same thing...nor might our ideas of preventative maintenance.
  15. Jul 16, 2019 at 8:41 AM
    aficianado
    back to bone stock.
    My belts are done. My wife’s serpentine belt was hanging on by a thread. Still surprisingly robust.
    I changed both our cars that same day.
    I want to dump my coolant anyways. Seems a short line to draw to the point the hoses are right there.
    I take my truck hunting in the boonies.
  16. Jul 16, 2019 at 10:44 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    :eek: million miles .
    I know typo.:thumbsup:
  17. Jul 16, 2019 at 10:57 PM
    05 4x4
    05 4x4 Well-Known Member
    Can’t believe nobody thought or mentioned this:
    Change your coolant lines when you change your water pump.
    I just did the following at 175k. Water pump, tensioner, belt, thermostat, coolant hoses, needle bearing replacement, full suspension replacement including oem upper and lower control arms, all tranny and engine oil/filter changed, new spark plugs, new air and cabin filter.... oh and new front rotors and pads.
  18. Jul 17, 2019 at 8:13 AM
    aficianado
    back to bone stock.
    this is actually what my shop (friend) in my old hometown told me. inspect hoses and do the drain and flush only. (and change the cap)
  19. Jul 17, 2019 at 3:01 PM
    aficianado
    back to bone stock.
    roger that!
    i do most of my own maintenance. and i decided to to this myself as well. of your list..i think my PS fluid is delinquent. the rest i got up to date.
    thanks for the kick in the ass.
  20. Sep 17, 2020 at 3:35 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    Real nice stuff
    Torspd[QUOTED] likes this.
