yitamotor tonneu covers good/bad
Discussion in '3rd Gen. Tacomas (2016-2023)' started by patos tacoma, Mar 6, 2023.
  1. Mar 6, 2023 at 9:30 PM
    patos tacoma
    patos tacoma [OP] Well-Known Member
    2010 Silver Tacoma TRD Sport
    Anybody out in TW put a Yitamotor Tonneu cover on their 3rd gen
    Any info appreciated
  2. Mar 7, 2023 at 8:36 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Ive only had mine for a little bit, but overall it seems pretty good. The mounting is a little crappy, but its been holding well.
    Tacospike likes this.
  3. Mar 7, 2023 at 8:46 AM
    Tacospike
    Two Trucks
    I really like their floor mats.
  4. Mar 7, 2023 at 8:58 AM
    patos tacoma
    What didn’t you like about the mounting?……it goes in your rails right?
    Sorry, details please…..
  5. Mar 7, 2023 at 9:01 AM
    5nahalf
    Erik
    Minnesota
    The mounts just feel cheap. Its a thin aluminum part that goes in the track, then the plastic latch on a threaded rod, the plastic feels like it would be pretty brittle. The threaded part is maxed out and its really tight getting them on there.
  6. Mar 7, 2023 at 9:05 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Not what I would call a glowing endorsement!
    LeakyAC likes this.
  7. Mar 7, 2023 at 9:06 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Imo those vinyl / fabric tonneau covers are all kinda sketchy doesn't matter the brand
    5nahalf likes this.
  8. Mar 7, 2023 at 9:13 AM
    5nahalf
    Erik
    Minnesota
    Oh yeah, its a shitty cover, but for so cheap I was not expecting it to be great. Its actually better than I was expecting. The top and frame are fantastic, its just the clips.
  9. Mar 7, 2023 at 9:42 AM
    patos tacoma
    I’m curious how the top of the cover attaches to the bed……the front of the cover, under the back window, because there’s no rail, and seems to not have clips
    oR is it just 4 bed clips attached to the rails and then some foam on the top to make the seal?
  10. Mar 7, 2023 at 9:46 AM
    5nahalf
    Erik
    Minnesota
    It clips there the same way it clips in the back. There is nothing on the header rails that hold these down.
  11. Mar 7, 2023 at 11:17 AM
    patos tacoma
    Ok, so the enclosed foam is to put on the head rails to make a seal,
    The wind on the freeway doesn’t lift the front of the cover?
  12. Mar 7, 2023 at 11:24 AM
    5nahalf
    Erik
    Minnesota
    I didnt use any of the foam it came with, I think it is for other models that this cover fits, but there is a rubber seal around the whole cover that seals to the bed. Install took about 5 minutes. Slide in the rail clips, tighten set screws, put on cover and secure latches.
  13. Mar 7, 2023 at 11:42 AM
    patos tacoma
    Thanks…….I’m counting on your 5 minute estimate
    one last question
    So it’s closed with tailgate up…..no lock on cover
    And have to unlock and lower tailgate to open
  14. Mar 7, 2023 at 11:44 AM
    5nahalf
    Erik
    Minnesota
    Yep, so when its closed, you need to open the tailgate to open it up. Its a soft cover though, so if someone wants in they can just cut a hole and unlock it.
