Yeti Roadie Leaking
Discussion in 'Off-Topic Discussion' started by nader2, Jul 27, 2018.
  1. Jul 27, 2018 at 10:48 PM
    nader2
    nader2 [OP] New Member
    Stephen
    20?? Tacoma SR5 likely
    Hope this is the appropriate forum. just wondering if anyone else had purchased a yeti roadie that leaks like a broken faucet. It is ice blue. Not sure if that makes any difference. I’m pretty disappointed that I bought it, filled it with ice and beer and then leaked once some ice melted. I got it at Cabelas. I tried flipping the gasket on the drain plug as I thought it might’ve been installed backwards which shouldn’t make a difference. It seems like what I’ve read is that people have received a replacement from yeti that then had no issues. I know yeti isn’t the end all be all but I had points saved up and needed a smaller sized cooler as the smallest I had was a cabelas polar cap 40. So I got it in a pinch. Thanks in advance for any first hand experience.
  2. Jul 29, 2018 at 4:37 PM
    R490
    R490 Well-Known Member
    Upgrayedd
    VA/PA
    I'd say look into the warranty that came with it, or return it to Cabellas.
    DavesTaco68 likes this.
  3. Jul 30, 2018 at 10:35 AM
    nader2
    Stephen
    I returned it to Cabela's and switched it out with another blue one. I tested it in the parking lot before I left by filling with some water and no leak. So I filled it with and let it cool for a couple hours and out of curiosity poured a few cups of water in it. Sure enough the damn thing started leaking. I flipped the rubber gasket around on the drain plug and then it quit. Kinda puzzling that did the trick. At any rate Yeti is sending out a couple new drain plugs to me. So i'll update once I receive the new one in case anyone is interested or has a similar issue arise.
  4. Aug 2, 2018 at 8:04 PM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    Should have saved your money and bought a Shiti Cooler :spending::cheers:
    lucky13don and BillsSR5 like this.
  5. Jul 7, 2019 at 6:55 AM
    DoRough
    DoRough Member
    Justin
    Denver
    2017 Tacoma DCLB TRD Off Road
    Toyo 255/85/16, Snug top, Bajarack, RCI skid plates, Bed rug
    Any updates on the leak issue? My dad has this cooler and it’s worked great, but I’ve read online about people having the problem with it leaking. Curious if your problem was solved.
  6. Sep 2, 2019 at 11:22 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    I’ve got the 65qt regular style, and the lid leaks like crazy if the ice has melted. Tends to make it look like i pissed myself when i try to move the thing. Can’t imagine it’s airtight if it’s not watertight
