Yeti Coolers group buy - CANCELED
Discussion in 'Group Buys' started by LoadedTaco, Feb 3, 2014.
Thread Status:
Not open for further replies.
  1. Feb 5, 2014 at 8:36 AM
    #61
    LoadedTaco
    LoadedTaco [OP] Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Probably going official next week and then open for at least a couple weeks. All those details are being worked out this weekend.
    Absolutely. There might be additional charges to get it to Hawaii, but 100% doable.
  2. Feb 5, 2014 at 8:43 AM
    #62
    jc1980
    jc1980 Well-Known Member
    MGM 4x4 TRD Off-Road (Extra Value Package II)
    See build link in signature or public profile.
    Sub'd
  3. Feb 5, 2014 at 9:32 AM
    #63
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    They look really durable.
  4. Feb 5, 2014 at 9:33 AM
    #64
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    :eek: Holy $H!+!
  5. Feb 5, 2014 at 9:34 AM
    #65
    Brinner
    Brinner Well-Known Member
    Nicholas
    North Bay, California
    2014 MGM DCSB Tacoma TRD Sport
    ^^ That's impressive, interested to see the discount you get on these OP. Thanks TW take more of my money!
  6. Feb 5, 2014 at 9:53 AM
    #66
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Don't think I "NEED" one, but I'll sub for more reviews and to find out the discount and possibly get in on this
  7. Feb 5, 2014 at 11:52 AM
    #67
    Coast2Coast
    Coast2Coast Well-Known Member
    Northern Alberta
    2009 TRDOR
    Black Sand Pearl factory paint - flattened "au natural" by tree branches.
    A lot of people wonder why in ^%* you would pay so much for a cooler. I was picking up a Yeti cooler at a bass pro shops once and the guy in line behind me nearly keeled over when he saw the price. I told him they were good coolers, they keep stuff cold for a week and they're grizzly certified (we were going into the mountains that day). He said "I just use a styrofoam cooler and carry a shotgun, hyuk hyuk!". Well, a lot of good that shotguns going to do when your asleep dummy! I personally like to use these new tough coolers because there's a good chance that after a few years they won't be destroyed like all the other coolers I've wasted money on! I can count on them to hold their cargo even if they do shift sideways or fall over in the box of the truck. I can count on them to keep my ice frozen and my food cold for the duration of the trip, period.
    I own/owned a few different brand coolers including Yeti and Pelican so here are some comparisons.
    The Yeti is thinner walled, less insulation, larger space for stuff inside for the size of the cooler. The Pelican is thicker, heavier, and uglier if that matters. The Pelican's plastic is "more yellow" and I think after a few years it will look pretty gnarly once dirt and sun gets to it. The Yeti's finish looks like it will stay attractive for longer.
    I prefer the Pelican's beefy latches, the Yeti's rubber ones are more awkward to work with at times because you have to pull downward and stretch them every time. I'm talking one handed use here, cause usually you've got a glass or a bottle in the other hand, right? On the other hand, if you're at camp and you like to leave the latches open all the time, the solid Pelican latches stick straight out from the cooler and can catch your pant legs and shins as you walk past, which can be a bitch at times.
    Both coolers can be strapped down to your deck/bed without hindering the operation of the lid. However Yeti tried to design their system so that you have to use their $50 tie down kit, while with the Pelican you can just use any old strap or bungee cord easily.
    The Yeti lock hasps are cast in the plastic of the cooler and lid, the Pelican lock hasp is stainless steel on top and cast plastic on the bottom. If your neighborhood grizzly bears have a hacksaw they can easily get into the Yeti, but the Pelican will make them work for it. :notsure:
    The Yeti coolers, and most other premium coolers perform about on par with the coleman extreme 5 coolers found here:
    http://www.coleman.com/Products/8581/xtremereg-coolers
    I still use my 100QT coleman when I need to carry a ton of food or the moose just won't fit in the other coolers. It was cheap compared to the other ones and it does the job just fine so why not?
    I've found that the Pelican insulates better and therefore performs better than any other cooler, but it comes at a cost. I still use my Yeti more often than I use the Pelican. Why? Because the Pelican is freakin huge, and most of the time I only need to keep things cold for a few days. I've used the coolers for 2 week long trips and found that the Pelican was better suited to this type of use than the Yeti. It just consumed less ice than the others.
    My favorite cooler is the little Yeti Roadie cooler. It's only big enough to hold 2 bags of ice, but sometimes that's all I take with me for a cooler on weekender or 3 day trips to pack light and all I need is a few steaks and some ice for whiskey. :D
    I would definitely be in on this group buy if I thought I needed another cooler, they are great units!
  8. Feb 5, 2014 at 5:40 PM
    #68
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    My buddy shot the Grizzly commercial for yeti. He vouches first hand for these coolers.
  9. Feb 5, 2014 at 5:45 PM
    #69
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
    I'd be interested in this group buy
  10. Feb 5, 2014 at 5:52 PM
    #70
    inmyiroc
    inmyiroc Active Member
    Chesapeake, VA
    2017 4WD Blazin blue double cab
    Ill vouch for these also. Every coast guard ship ive been on uses these to keep drinks and ice cold in the carribean heat for 4 to 6 days at a time
  11. Feb 5, 2014 at 5:54 PM
    #71
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    Fuck.. I'll take that one please :D
  12. Feb 5, 2014 at 7:00 PM
    #72
    warrpath4x4
    warrpath4x4 Well-Known Member
    shawn
    Prosser, WA
    2015 Tacoma TRD PRO
    2" OME lift, wildtops soft top, other odds and ends
    interested in pricing on a roadie 20
  13. Feb 5, 2014 at 7:09 PM
    #73
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Just checked out there site and some of their vids. Hmm that Tundra 65 might be the perfect one for me :D haha
  14. Feb 5, 2014 at 7:27 PM
    #74
    Mike90
    Mike90 Well-Known Member
    Black Hills, SD
    '07 DCSB, '79 FJ40, '18 Subaru Crosstrek, ‘23 DCSB
    Sub'd interested in a 65 if we can get a good $$$
  15. Feb 5, 2014 at 7:32 PM
    #75
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    I'd also want the Tundra 65
  16. Feb 5, 2014 at 7:48 PM
    #76
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    the 35 fits PERFECT on one of the back access cab seat folded down
  17. Feb 5, 2014 at 8:05 PM
    #77
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
    subd for pricing
  18. Feb 5, 2014 at 8:12 PM
    #78
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    I'd be in for a roadie, or a tundra 35 or 45 if the price is right
  19. Feb 6, 2014 at 2:03 AM
    #79
    sgl
    sgl Active Member
    modesto,ca
    11 Sport DCLB S/C MG
    I'd be in for a YT65, depending on price. Is this GB gonna happen soon?
  20. Feb 6, 2014 at 7:39 AM
    #80
    Jrahn0822
    Jrahn0822 Well-Known Member
    Jake
    Iowa
    07 DCLB
    Interested in either a roadie 20 or a tundra 35 in ice blue if possible.
Thread Status:
