Yankum Fairlead
Discussion in 'Recovery' started by Freeheelbillie, Aug 5, 2022.
  1. Aug 5, 2022 at 12:17 PM
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
  2. Aug 5, 2022 at 12:19 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Yes!!!!
    Besure to use "YankumSafely" for 5% off
    I'm a brand ambassador for Yankum Ropes and am planning to put together a complete post of what Yankum offers and the various benefits.
    Thanks for getting the ball rolling @Freeheelbillie !
  3. Aug 5, 2022 at 12:22 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Not sure if Yankum is an approved vendor...if not, it would be a good idea to go through the process.
    Bertw192[QUOTED] likes this.
  4. Aug 5, 2022 at 12:23 PM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    How about UV exposure? Something I probably worry more about than actually matters, but it was one of the reasons I went with the Factor 55 flat splicer. Almost completely shields the synthetic rope.
    SR-71A, Gunshot-6A and Bertw192 like this.
  5. Aug 5, 2022 at 12:29 PM
    mk5
    mk5 Probably wrong about this
    SoCal
    '05 access cab 4x4
    Yeah I wrap all the exposed rope with outdoor tape. I found one that doesn't leave sticky goo. UV does a number on most polymers!
    This setup looks nice. If I ever actually used the winch I would definitely want it. The metal stuff does just fine in the shopping mall parking lot though.
    Bertw192 likes this.
  6. Aug 5, 2022 at 12:30 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    There's pretty minimal rope exposed with this fairlead. It was certainly a consideration for me. Even if it's getting blasted by UV, it's only the extreme end of the rope. If it were to break, it would be a quick and easy repair with a FID.
    You could also look into dipping the end of the rope.
    P8trit and Freeheelbillie[OP] like this.
  7. Aug 5, 2022 at 12:31 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Decent info here https://factor55.com/uncategorized/uv-degradation-of-synthetic-winch-rope/
    I will say that as an avid sailor and long time synthetic line user in that application, I have line that has been beat silly by UV for years and still delivers under insane winch, wind and, snap loads. Will it last forever? Nope. Is it my main concern? Not even close. Off road use (mud) has me more more prone to replacement long before UV "kills" a line. Just my opinion though.
  8. Aug 5, 2022 at 12:33 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Another benefit of ditching the hook, it's one less item to make contact with slopes on extreme approach angles.
    @WrecklessAbandon lost part of his Factor55 hook pad due to this nose dive into dirt.
    Freeheelbillie[OP] likes this.
  9. Aug 5, 2022 at 12:34 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Factor 5, Fast Fid is a cool piece of kit https://www.youtube.com/watch?v=bNPt1riHMJ0
  10. Aug 5, 2022 at 12:35 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Yep, I carry one in my truck. I've used it a bunch of times and it works exactly as advertised.
  11. Aug 5, 2022 at 12:37 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Holy moly, $250? I like the idea of no hook or thimble or anything on the end, but you can easily do that without spending that kind of money on a fairlead. It's common in aus videos I watch, they usually just leave a hard shackle on the end of the winch line.
  12. Aug 5, 2022 at 12:38 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    It certainly seems steep, but after factoring in the cost of a Factor55 hook, fairlead and thimble, it's not as bad as it looks.
  13. Aug 5, 2022 at 12:40 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    True, if that's the alternative being compared against. Nothing wrong with spending money on quality gear, there are just less expensive ways to eliminate anything on the end of your winch line. It's not like this fairlead is the only way to make that happen, that's all I'm getting at.
    P8trit and Bertw192[QUOTED] like this.
  14. Aug 5, 2022 at 12:41 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    No more than a Factor 5 Ultra Hook...to each their own though.
  15. Aug 5, 2022 at 12:41 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    It's also worth checking out their other gear. I picked up a 30' kinetic rope and dipped shackles. High quality ropes, straight out of ID USA. Super fast shipping as well, but I'm pretty close to them.
  16. Aug 5, 2022 at 12:42 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    What exactly did you dip the end of that line in?
  17. Aug 5, 2022 at 12:43 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    There's always a cheaper solution...
    AMOPA 2pcs Red Winch Rope Hook Stand Suitable for 3/8 1/2 Clevis Slip Half-Linked Winch Hook with 10" Bolt Mount Hawse Fairlead https://www.amazon.com/dp/B09NSD4MJ2
    However, I wouldn't want to tension my rope on this... it would probably snap.
  18. Aug 5, 2022 at 12:44 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I stole that photo from the interwebs. But I'll do some research and get back to you...
  19. Aug 5, 2022 at 12:45 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Like I said if that's the alternative being compared against, sure. There's also nothing stopping anyone from just removing whatever is on the end of their winch line and hooking it to something else, like what Bert just shared. I'm just sharing my opinion, that's all. I think it's unnecessary and overpriced for the goal that's trying to be achieved.
  20. Aug 5, 2022 at 12:46 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    I agree...but then again, almost everyting I buy I feel like is a bit "over priced" these days.
