Yakima Roof Rack: Anyone install?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by forana, Feb 22, 2022.
  1. Feb 22, 2022 at 3:35 PM
    forana
    forana [OP] Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Ok, looking for anyone that installed Yakima Roof racks in the factory mount holes. I wanted to ask how it went and suggestions.
    Here's what I understand I need:
    Yakima skyline towers
    Landing pad 24
    Whatever bars I choose. Thinking round bars as they are the easiest to use.
    Round bar mount adapters.
    I will silicone the holes as much as I can.
    Is it better to cut holes through the rubber strip seal or cut out the section around the mount holes?
    Thank you!
    DustyMcTaco likes this.
  2. Feb 23, 2022 at 3:35 PM
    forana
    Kaneohe, Hawaii
    bumpy/
  3. Feb 25, 2022 at 2:06 PM
    forana
    Kaneohe, Hawaii
    Ok, does someone at least have experience working with factory bolt holes? Should I mount the mount right over the rubber strip or cut out a section?
  4. Feb 25, 2022 at 2:15 PM
    Gord0
    Gord0 Well-Known Member
    I’ll be installing this set up on my truck tomorrow.
    Yakima has pretty clear instructions on the install, surprising detailed I thought.
    They can be downloaded if you do not have them.
    To answer your question, you modify just the section above the factory holes then mount over the rubber strip.
  5. Feb 25, 2022 at 4:54 PM
    forana
    Kaneohe, Hawaii
    Thanks for the info, please let me know how the install goes!
    BTW: where did you purchase the yakima parts? The landing pads are sold out everywhere online.
    What bars are you using?
  6. Feb 25, 2022 at 4:57 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I cut as little of the rubber strip as possible. PITA but it looks better.
  7. Feb 25, 2022 at 5:16 PM
    Gord0
    Yeah they are tough to find… I’m in Canada so my source will likely not help.
    I think the bars are called Core Bars.
    IF you follow the method in the instructions, you still have an uninterrupted rubber strip (no cutting). Instead you mark out then drill a 3/8 hole through the strip.
  8. Feb 25, 2022 at 5:31 PM
    chazmen
    chazmen Well-Known Member
    JT
    Rack Attack has them in stock
  9. Feb 26, 2022 at 1:16 PM
    Gord0
    Install done this morning, took my time maybe two hours including stopping for breakfast.
    As I said above the Yakima instructions are very good. The only thing I did differently was in the instructions it said to drill a 3/8 hole through the rubber strip. I used a heat gun on a screwdriver & pushed it through the rubber strip, easy to do, nice & clean. Pics of modified rubber strip below.
  10. Feb 27, 2022 at 1:09 AM
    forana
    Kaneohe, Hawaii
    How the end look? Sweet I bet.
    I started adding all the parts to my cart. Damn, it adds up!!
  11. Feb 27, 2022 at 8:30 AM
    Gord0
    I think it looks great, I’ll take a pic when it stops raining here.
    This set up isn’t exactly cheap that’s for sure! While the end result is exactly what I wanted and the fit/quality is excellent, I still feel like it’s overpriced… oh well, on to the next mod.
  12. Feb 27, 2022 at 11:57 PM
    forana
    Kaneohe, Hawaii
    how come you had to cut the molding?
  13. Feb 28, 2022 at 6:38 AM
    Gord0
    There’s a strip of metal that runs the length of the rubber moulding. You have to cut that out so that the Yakima Landing Pad screw can pass through.
  14. Mar 31, 2022 at 11:21 AM
    forana
    Kaneohe, Hawaii
    Finally got all the parts. Will be installing this weekend.
  15. Mar 31, 2022 at 2:09 PM
    chazmen
    JT
    How about a step by step video please
  16. Mar 31, 2022 at 4:35 PM
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    I know you are asking about a Yakima rack, but have you checked out any of the CNC racks? Might be some downsides compared to the Yakima (weight, not quick release), but I think there are a lot of upsides too. I was going to put a Yakima rack on my topper but all the parts add up and for not much more I got a Sherpa rack. It's not quick release like a Yakima, but a whole lot more versatile. Their cab rack also has rubber mounting feet that eliminate the need to silicone the holes. Just a though.
  17. Mar 31, 2022 at 5:31 PM
    Tacoboutkewl
    Tacoboutkewl Well-Known Member
    some people have used a leather punch to cut a hole in the rubber strip
  18. Mar 31, 2022 at 6:34 PM
    Gord0
    Heat up a screwdriver or whatever metal object you want and let it melt through, that’s what I did.
  19. Mar 31, 2022 at 6:36 PM
    Gord0
    The Yakima instructions are literally step by step, there is no second guessing anything throughout the whole install.
    Take 5 minutes and read the instructions, no video required.
  20. Mar 31, 2022 at 6:59 PM
    Tacoboutkewl
    I didn’t read your post carefully, your method came out with great results
