Yakima cross bars mounted to bed rails?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thedude5108, Oct 17, 2009.
  1. Oct 28, 2010 at 10:13 AM
    #41
    dangvick
    dangvick New Member
  2. Oct 29, 2010 at 6:32 PM
    #42
    scmbr549
    scmbr549 Active Member
    It should mount OK if it uses standard Yakima mounts like the one pictured. Just pop the tabs and the mounts will fit a rectangular bar.
  3. Nov 19, 2010 at 9:33 AM
    #43
    black cx
    black cx Well-Known Member
    Bay Area, CA
    2010 Tacoma 4x4
    just ordered the Inno rack..
    people wont steal the rack right? or is there a way to lock it down?
    auskip07 likes this.
  4. Nov 19, 2010 at 9:47 AM
    #44
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Inno rack system with Thule Snowboard/Ski attachments.
  5. Apr 30, 2011 at 5:23 PM
    #45
    KnurledNut
    KnurledNut Cracker in a Taco
    Sonova Beach
    '10 PreRunner SR5
    I'm confused...when I look at fasttracktacks description of the C channel attachment I see a picture of this:
    This will not fit my 2010 Tacoma. I scoured their website but could not find an attachment system that works on my truck.
    I'd like to know the exact part #'s of the attachments that they sold you. I don't want to make the same mistakes.
  6. Apr 30, 2011 at 5:58 PM
    #46
    Tim A
    Tim A Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
  7. Apr 30, 2011 at 6:00 PM
    #47
    Tim A
    Montana
  8. Apr 30, 2011 at 6:04 PM
    #48
    KnurledNut
    Sonova Beach
    '10 PreRunner SR5
    Wow...thanks for the fast reply, link, and photo!
    Which size crossbars would you recommend?
  9. Apr 30, 2011 at 6:08 PM
    #49
    Tim A
    Montana
    Sure, no problem. You want the 65" crossbars
  10. Apr 30, 2011 at 6:15 PM
    #50
    KnurledNut
    Sonova Beach
    '10 PreRunner SR5
    Thanks!
    I ordered everyting from ORS Racks Direct for $167 w/ free shipping.
  11. May 1, 2011 at 9:49 AM
    #51
    scmbr549
    When I bought mine last year I had to call fast track racks to get the correct PN and place the order. They were real helpful and go the orger in for me.
  12. Jan 1, 2012 at 11:20 PM
    #52
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    has anyone seen or done a bed rail mount system for the 1st gen tacomas?
  13. Jan 1, 2012 at 11:29 PM
    #53
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I havent seen any but that would be cool if they had something like that.
  14. Jan 1, 2012 at 11:33 PM
    #54
    tacomaforlife
    Robbie
    AIKEN, SC
    ill be making something that mounts above my bed rails soon cause its getting to be a pain strapping the bike down and its kinda ghetto:D so ill post picks when i gen to it hopefully next week.
  15. Jan 1, 2012 at 11:41 PM
    #55
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah that would be cool that way it will give some other guys ideas on something similar.
  16. Jul 12, 2012 at 2:41 PM
    #56
    wlandrum
    wlandrum Member
    Pasco, WA
    '12 Tacoma DC/LB, Mag Gray, TRD Sport
    Great info here, thanks everyone.
  17. May 13, 2024 at 11:59 AM
    #57
    bbinSF
    bbinSF Well-Known Member
    **EDIT: THE DIMENSIONS DON'T WORK OUT, DON'T USE THIS BELOW ***
    I'm updating the thread with my solution to this problem still in progress. Please see photo and Amazon parts list. I haven't yet mounted this to the bed rails, but will get to it this weekend.
    https://www.amazon.com/dp/B07D5VDFX7
    https://www.amazon.com/dp/B0C81B3BCM
    https://www.amazon.com/dp/B0CD6T8HQY
    https://www.amazon.com/dp/B0CFTJSSM6
    The only unknown is the vertical dimension... When this all gets installed, does the bar sit on top of the bed side? I think it will.
    One consideration is that it would be helpful to add a piece of metal or plastic in before the 1/2" screw is screwed into the 1/2" lifting eye nut as a set to pinch the bar into place. The 1/2" cap end screw doesn't pin down the bar.
  18. May 19, 2024 at 11:02 PM
    #58
    bbinSF
    The above ended up not working and I'm pursuing a custom cut OSH Cut set of 4 brackets 3/8" thick and shaft collars to hold the bars in place. This should be a much cleaner install.
  19. May 28, 2024 at 10:10 AM
    #59
    bbinSF
    Got OSHcut to cut these for me.
    Instead of a set screw thru the soft aluminum, I used shaft collars for additional strength off road. Note, while Yakima states the diameter of their bars is 1 1/8", that's the diameter of the metal, not the included coating (unfortunately). I had to strip the coating from the bars to get the shaft collars to mount. Weight of the bar rests on the side of the bed due to the slotting at the t-nut.
  20. May 28, 2024 at 10:29 AM
    #60
    urbanplanner
    urbanplanner Well-Known Member
    washington state
    Somewhere on here I found a place that makes rain gutter brackets that attach to the bed rail system. This is the best pic I have right now. I have it over a bed cover and pretty much only use it now for ski season.
