XPOTRPR Minitruck (1986 Toyota Pickup)
Discussion in 'Other Builds' started by XPOTRPR, Oct 24, 2018.
  1. Nov 20, 2018 at 2:59 PM
    #241
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    Sweet!
    XPOTRPR[QUOTED][OP] likes this.
  2. Nov 20, 2018 at 3:03 PM
    #242
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    I haven't done much research but that is some good info.
    The Fluffer[QUOTED] likes this.
  3. Nov 20, 2018 at 3:07 PM
    #243
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    I have a 1st gen tundra and got rid of the electronic actuator for the manual T case from a '96 4 runner and added twin sticks from frontrange offroad and it's the best mod yet on the truck.
    Brake Weight likes this.
  4. Nov 20, 2018 at 3:24 PM
    #244
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    thanks man! :wave:
  5. Nov 20, 2018 at 5:16 PM
    #245
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    My other Toyota, 1989
  6. Nov 20, 2018 at 6:15 PM
    #246
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Nice! It's funny how many taco guys have another older pickup. Usually dropped too.
    Phessor[QUOTED] likes this.
  7. Nov 20, 2018 at 6:18 PM
    #247
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    This is my old Hilux that I traded my Tacoma for.
  8. Nov 20, 2018 at 6:19 PM
    #248
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Subbed
    :spy:
    XPOTRPR[OP] likes this.
  9. Nov 20, 2018 at 6:21 PM
    #249
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    When my kids are all out of the house I want to rebuild it and lower it as well.
  10. Nov 20, 2018 at 6:47 PM
    #250
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Daaaaaamn. Beautiful truck! What part of Az you in?
    What up dude! :wave:
    Nice. That'll be a fun project!
  11. Nov 20, 2018 at 7:31 PM
    #251
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    I'm in the White Mountains
  12. Nov 21, 2018 at 3:30 PM
    #252
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :bowdown:
  13. Nov 21, 2018 at 3:38 PM
    #253
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Some randomness..
    IMG_20181120_160613.jpg IMG_20181120_160618.jpg IMG_20181120_160641.jpg IMG_20181120_162843.jpg
    Sticker bombed the A Pillars to cover some cracks and broken sections from sun rot. Brakes came in and will be going on Friday with the Blocks and extended studs.
    Chased down a white 92 Toyota minitruck I saw on the way home. Straight found them at O'Reillys and walked in and asked whos it was. Good guys. Talked for about 15 minutes, looked at the trucks.. his was super dope. Definitely knew thwre stuff. Exchanged numbers and they might come by Friday while I'm working on mine to lend a hand and share some info. Super excited to find a connection in the minitruck scene!
  14. Nov 21, 2018 at 4:58 PM
    #254
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    tha a mighty fine yoter you have right there. Want to come hang at my place and party?
  15. Nov 21, 2018 at 5:34 PM
    #255
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I went to work like that the next Monday... lol
    MrCrowntown likes this.
  16. Nov 23, 2018 at 3:41 PM
    #256
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Started digging into the front end. Having to soak the lug nuts/studs for them to break free. letting the brake caliper bolts do the same now.. and started poking around. Found my clunk I've been experiencing. The center link is shot. Going to order a new one from Rock Auto and slap that in while I have it all torn apart. Was thinking of replacing some other things as well. Starting with the sway bar bushings, and upper/lower BJ's.. then doing the BJ flip.
    Man of Steel TRD and loginfailed like this.
  17. Nov 23, 2018 at 5:24 PM
    #257
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Alright, ordered Upper and Lower Balljoints, new Center Link, new shocks front and rear, and an Energy swaybar bushing kit!
    So this next week/weekend as things start showing up I'm replacing:
    Front and Rear Shocks
    Rear 4" block
    Rotors and Pads
    Upper and Lower BJ's + Flip and raising Torsion Bar
    Center Link
    Wheel Studs
    Lug Nuts
  18. Nov 23, 2018 at 5:47 PM
    #258
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    then down the road I can clean it up and do drop leafs and drop spindles.
    4Running Daily and loginfailed like this.
  19. Nov 26, 2018 at 5:58 AM
    #259
    The Fluffer
    Andrew
    Scottsdale, AZ
    boughten
    sexy truck party this weekend then? What shocks did you get? QA1's with adjusters!?!?
  20. Nov 26, 2018 at 7:43 AM
    #260
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    lol. no. QA1's wont fit or work with the Torsion front end. I just ordered a set of Monroe OE struts. the currents ones are pretty beat. bushings are toast, etc. I'm gonna be working on it this week and weekend for sure.
    loginfailed likes this.
