XM Antenna Lead Location
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 95SLE, Aug 7, 2009.
  1. Aug 7, 2009 at 7:36 PM
    95SLE
    95SLE [OP] Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I have an 09 Tacoma that is XM ready. The dealer XM module is $500 so i will try to install my MyFi. The antenna is already installed.
    I am trying to locate the XM antenna Lead. This thread was very informative.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/46211-dash-removal.html
    My question is where is the lead located? I hope it is just flappin in the breeze behind the panel.
  2. Aug 7, 2009 at 7:46 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
  3. Aug 7, 2009 at 7:49 PM
    stormyday
    stormyday Well-Known Member
    Morganton, NC
    14 Taco Double Cab Pre-Runner
  4. Aug 7, 2009 at 10:01 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Stormyday:
    Thank you for the quick response. I will call on Monday to see if the connector is compatable with a MyFi.
  5. Aug 8, 2009 at 9:24 AM
    stormyday
    Morganton, NC
    You have to purchace an adapter. Do a search for SFA12M. I am pretty sure that is the correct part. They are around $60.
  6. Aug 8, 2009 at 1:42 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Stormyday:
    TY for all of your help. I ordered a cable from My Radio Store and a mounting bracket from Pro Fit International.
    I will have a nice clean fit for the MyFi in the new Tacoma. Total cost around $100. This will also allow me to move the MyFi into the garage when working on cars and other projects.:headbang:
    I will post pics and a write up after the install.
  7. Sep 8, 2009 at 4:59 PM
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    Will the SFA12M plug directly into the stock antenna on the roof of my truck, or will I have to do some modding to make that work? Also, how would I run the cable up to the antenna?
  8. Sep 8, 2009 at 10:44 PM
    stormyday
    Morganton, NC
  9. Sep 9, 2009 at 4:39 AM
    Chad
    Chad
    Cary, NC
    Yeah I know that. But will I have to run a wire up to the stock antenna on the roof, or has that already been done? I keep thinking that the plug that the cable plugs into under the kick panel goes to the stock audio system. My question is would I have to run the cable to the antenna on the roof, or would I run it to the stock audio system?
  10. Sep 9, 2009 at 4:43 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    The wire is already run to the kick panel. Just connect up and run the patch cable to your receiver.
    What type of receiver are you installing?
  11. Sep 9, 2009 at 6:34 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I read the entire thread. Has anyone been able to get the XM/Sirius antennae to work for GPS purposes? Most said it wouldn't work but there seemed to be a shred of hope because no one had tried. I'd like to utilize mine and I don't have sat radio.
  12. Sep 9, 2009 at 12:46 PM
    Chad
    Chad
    Cary, NC
    Im just speculating as of now. Is it possible to just run the cable to the headunit and use the built in controls for it, or will I have to buy a receiver as well. So let me see if I can get this right...
    A cable is already ran from the stock roof antenna to the kick panel. You then have to run your own cable from the location in the kick panel to the receiver or whatever you're using. Is that right?
    Also, how would I go about using the stock headunit as my controls? And what type of receiver would you recommend?
  13. Sep 9, 2009 at 12:49 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    you can use the stock Hu but to get better sound out of your system, i would upgrade teh HU to a better one
  14. Sep 9, 2009 at 12:57 PM
    Chad
    Chad
    Cary, NC
    Well I don't necessarily want to go messing around with that stuff. I'm not that experienced at pulling stuff out and what not. Rather pay to have the Geek Squad do it for me.
  15. Sep 9, 2009 at 1:08 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
  16. Sep 9, 2009 at 1:54 PM
    stormyday
    Morganton, NC
    There is a link in my signature of what I did. I originally had a portable XM radio. I decided to replace the entire head unit with a new one. I now have the aftermarket unit and the steering wheel controls it just like the factory. I have XM and iPod connectors also. I would not let Geek Squad touch my vehicle. I have heard horror stories with them, plus I am OCD on radio installs. Crutchfield will send you everything including step by step instructions. If you have a problem, you can give them I call and they are very helpful. There is a Crutchfield Coupon code also on page.
  17. Sep 9, 2009 at 4:25 PM
    mick6
    mick6 Well-Known Member
    New Jersey
    08 Tacoma TRD DC Sport
    None....Yet
