Write-Up: Torque APP OBD2 Reader
Discussion in 'Performance and Tuning' started by BrokenTusk, Oct 20, 2011.
  1. Jan 6, 2012 at 2:13 PM
    #161
    Aw9d
    Aw9d That one guy
  2. Jan 6, 2012 at 2:27 PM
    #162
    psychohamster
    psychohamster Active Member
    San Diego
    09 4x4 SR5
    IVD remote res coil-overs, Total Chaos UCAs, ARB Deluxe Bull-Bar, Warn 9.5XP, Luna Dual-Battery Controller
  3. Jan 6, 2012 at 2:41 PM
    #163
    psychohamster
    San Diego
    09 4x4 SR5
    Getting some good info from one of the admins on the torque forums:
    Seems like the second param is not useful, and that A and B are packed into the first param. I think with my latest reading he may be able to nail this down for us :)
  4. Jan 6, 2012 at 2:47 PM
    #164
    Aw9d
    Aw9d That one guy
    You can unroot to just so you know.
  5. Jan 6, 2012 at 2:55 PM
    #165
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    that does look good but how did he derive the value?? now whats the scaling value than 4608 needs to be a part of a scale for the temperature or is that the resistive value??
  6. Jan 6, 2012 at 3:19 PM
    #166
    psychohamster
    San Diego
    09 4x4 SR5
  7. Jan 6, 2012 at 9:02 PM
    #167
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Fuuuuu!!! What the shit are you talking about on that other thread?? I freaking Derp'd Out Loud! Shheeeeshhh!! :laugh: and thanks guys for trying to finger out the tranny temps!
  8. Jan 7, 2012 at 12:41 PM
    #168
    psychohamster
    San Diego
    09 4x4 SR5
    Hehehe, sure thing! Been driving us nuts which only makes the need for an answer even stronger! I think the fellow there may have gotten the magic to work. Out running some tests now, looks promising.
  9. Jan 7, 2012 at 1:16 PM
    #169
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    got any calc or code i can look at??
    been busy the past couple days to even think about this :p
  10. Jan 7, 2012 at 7:30 PM
    #170
    psychohamster
    San Diego
    09 4x4 SR5
    Here's the equation that I tried out all day today and think looked good:
    (I used the farenheit one)
  11. Jan 7, 2012 at 11:58 PM
    #171
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    Man does this look promising! Can hardly wait to test it out!
  12. Jan 8, 2012 at 12:51 AM
    #172
    LGE RAW
    Rob
    Dothan
  13. Jan 8, 2012 at 12:55 AM
    #173
    LGE RAW
    Rob
    Dothan
  14. Jan 8, 2012 at 9:42 AM
    #174
    psychohamster
    San Diego
    09 4x4 SR5
    Good point - the PID/EQ combo we're working on I've been testing on an 09. Based on the thread you linked, the 10+ peeps need to use PID 2182 not 21D9. Can someone with a '10 or '11 try sending each PID using the Test button and post back what the response is (mainly interested in the two long hex strings)?
  15. Jan 8, 2012 at 11:20 AM
    #175
    LGE RAW
    Rob
    Dothan
    This code appears to work with the 05 to 09 for each of the two Transmission fluid temp. sensors:
    Here is how I entered in Torque:
    For sensor 1 (Pan Temp):
    OBD2 Mode and PID:
    21D9
    Long Name:
    Transmission Fluid Temperature 1
    Short Name:
    TFT 1
    Minimum Value:
    0.0
    Maximum value:
    220.0
    Scale factor:
    x1
    Unit Type:
    *F (there is a degree symbol in Torque to use in place of the *)
    Equation:
    ((((E*256)+F) * (7/100) – 400)/10)
    OBD Header to use:
    left blank
    For sensor 2 (Converter outlet temp):
    OBD2 Mode and PID:
    21D9
    Long Name:
    Transmission Fluid Temperature 2
    Short Name:
    TFT 2
    Minimum Value:
    0.0
    Maximum value:
    220.0
    Scale factor:
    x1
    Unit Type:
    Equation:
    ((((G*256)+H) * (7/100) – 400)/10)
    OBD Header to use:
    left blank
    Let me know if this works!
    eddjaure likes this.
  16. Jan 8, 2012 at 12:03 PM
    #176
    biborado
    biborado Well-Known Member
    Stephen
    San Diego, CA
    2010 TRD Off-Road 4x4
    My 2010 results using the 2182 PID:
    Sensor 1:
    Result for equation: 0.0
    Commmand: 2182
    Response: 618248804880
    Sensor 2:
    Commmand: 2182
    Doesn't seem to be working on the 2010 with the 2182 PID.
  17. Jan 8, 2012 at 12:18 PM
    #177
    psychohamster
    San Diego
    09 4x4 SR5
    Interesting... you get some response, just not what I expected. In my 09, the command doesn't even get a response.
  18. Jan 8, 2012 at 12:37 PM
    #178
    biborado
    Stephen
    San Diego, CA
    Ok I think i figured it out for the 2010+ Tacoma
    OBD2 Mode and PID:
    2182
    Long Name:
    Short Name:
    Trans 1
    Minimum Value:
    0.0
    Maximum value:
    300.0
    Scale factor:
    x1
    Unit Type:
    °F
    Equation:
    ((((A*256)+B) * (7/100) – 400)/10)
    OBD Header to use:
    left blank
    OBD2 Mode and PID:
    2182
    Long Name:
    Short Name:
    Trans 2
    Minimum Value:
    0.0
    Maximum value:
    300.0
    Scale factor:
    x1
    Unit Type:
    °F
    Equation:
    ((((C*256)+D) * (7/100) – 400)/10)
    OBD Header to use:
    left blank
    I'm going to set the truck into the Diagnostic Mode to check and see if the numbers match up. If the PID and equation are correct, the A/T Temp light should light up at 115°F and start flashing at 130°F.
  19. Jan 8, 2012 at 1:22 PM
    #179
    LGE RAW
    Rob
    Dothan
    Sweet! Hope this will work for all now. Here is a screen shot of mine at about 50 mph.
  20. Jan 8, 2012 at 6:40 PM
    #180
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    You guys rock, thanks for the help on the torque forums
