Write-Up: Torque APP OBD2 Reader
Discussion in 'Performance and Tuning' started by BrokenTusk, Oct 20, 2011.
  1. Sep 27, 2013 at 2:51 PM
    #361
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I assume since it gives a vacuum reading, its a negative vacuum that is detected and is interpreted as boost. as if left on the metric unit inches of mercury is the unit used (a positive vacuum read). It has a sensor on a vacuum is all I can come up with. I don't understand why newer models don't monitor that but it seems to be the consensus
  2. Sep 27, 2013 at 2:58 PM
    #362
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    But, again, w/o a MAP sensor how is this possible? What sensor is reading vacuum if not a MAP?
  3. Sep 27, 2013 at 3:14 PM
    #363
    yota243
    E.J.
    north Alabama
    The vacuum sensor. I dunno man all I no I plug it in and it works.
  4. Oct 17, 2013 at 11:56 AM
    #364
    jaypp1
    jaypp1 Member
    00 Tacoma Prerunner
    Hello all, Im glad to see that a lot of progress was made determining the PID equation for tarnny temps in 2006-2013 Tacomas. I see there are some people that say they have tranny temp for 1st gen tacomas, but Im having difficulty getting a reading on my 2000 tacoma prerunner (V6).
    Can someone that is getting good transmission temp readings on a 1st Gen Auto please post the PID equation/parameters that they are using?
    Thanks a bunch!
    -Jay
  5. Oct 17, 2013 at 4:19 PM
    #365
    yota243
    E.J.
    north Alabama
    Was the pid for 2nd gen posted in this thread?
  6. Oct 17, 2013 at 9:31 PM
    #366
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    This is for the 05-09
    Did you use the 21D9 PID equation below?
    For sensor 1 (Pan Temp):
    OBD2 Mode and PID:
    21D9
    Long Name:
    Transmission Fluid Temperature 1
    Short Name:
    TFT 1
    Minimum Value:
    0.0
    Maximum value:
    220.0
    Scale factor:
    x1
    Unit Type:
    °F (there is a degree symbol in Torque)
    Equation:
    ((((E*256)+F) * (7/100) – 400)/10)
    OBD Header to use:
    left blank
    For sensor 2 (Converter outlet temp):
    OBD2 Mode and PID:
    21D9
    Long Name:
    Transmission Fluid Temperature 2
    Short Name:
    TFT 2
    Minimum Value:
    0.0
    Maximum value:
    220.0
    Scale factor:
    x1
    Unit Type:
    Equation:
    ((((G*256)+H) * (7/100) – 400)/10)
    OBD Header to use:
    left blank
  7. Oct 17, 2013 at 9:32 PM
    #367
    95 taco
    95 taco Battle Born
    And this is for 10+ trucks
    Ok I think i figured it out for the 2010+ Tacoma
    OBD2 Mode and PID:
    2182
    Long Name:
    Short Name:
    Trans 1
    Minimum Value:
    0.0
    Maximum value:
    300.0
    Scale factor:
    x1
    Unit Type:
    °F
    Equation:
    ((((A*256)+B) * (7/100) – 400)/10)
    OBD Header to use:
    left blank
    OBD2 Mode and PID:
    2182
    Long Name:
    Short Name:
    Trans 2
    Minimum Value:
    0.0
    Maximum value:
    300.0
    Scale factor:
    x1
    Unit Type:
    °F
    Equation:
    ((((C*256)+D) * (7/100) – 400)/10)
    OBD Header to use:
    left blank
    I'm going to set the truck into the Diagnostic Mode to check and see if the numbers match up. If the PID and equation are correct, the A/T Temp light should light up at 115°F and start flashing at 130°F.
  8. Oct 17, 2013 at 10:39 PM
    #368
    skygear
    skygear                    
    I stil need to work on my setup AGAIN>
  9. Oct 17, 2013 at 10:43 PM
    #369
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    How do I add this and make it work on my junk?
    What are your settings for DTE? I can't figure it out and its just way off
  10. Oct 17, 2013 at 10:46 PM
    #370
    95 taco
    95 taco Battle Born
    What's wrong with it?
    Que?
  11. Oct 17, 2013 at 10:50 PM
    #371
    skygear
    skygear                    
    I keep doing custom ROMS. Forget to back up my data for Torque, and when I wipe my device I need to setup the app all over again.
  12. Oct 17, 2013 at 10:52 PM
    #372
    MonkeyProof
    SoCal- SGV
    Thanks for the info..
    What I'm trying to say is the distance to empty is off and not even close. And I'm having a hard time trying to get it right. I Havnt messed with it in a while trying to figure it out.
  13. Oct 17, 2013 at 10:54 PM
    #373
    95 taco
    95 taco Battle Born
    :thumbsup:
    I have no idea what that is :anonymous:
    No problem.
    Ahh, OK.
    I have no idea, i just got my know how from the AZ geek talk thread.
  14. Oct 17, 2013 at 10:57 PM
    #374
    MonkeyProof
    SoCal- SGV
    Mine lasted a month...get what you pay for :p
  15. Oct 17, 2013 at 11:41 PM
    #375
    skygear
    skygear                    
  16. Oct 18, 2013 at 6:01 AM
    #376
    jaypp1
    jaypp1 Member
    00 Tacoma Prerunner
    Anyone have the 1st Gen tranny temp parameters?
  17. Oct 18, 2013 at 10:32 AM
    #377
    95 taco
    95 taco Battle Born
    I didn't go through the whole thread, but I looked some and didn't find any, and I tried the codes for the 2nd gen and they don't work.
  18. Oct 30, 2013 at 9:31 AM
    #378
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    when I try inputting the codes it would not take the equation values and keeps telling me this message; equation: check parentheses. Anybody know what is going on here?
    Do these codes work with the free version copy of Torque?
    I have a 2005 Tacoma 4.0, 6cyl
  19. Jan 15, 2014 at 6:49 AM
    #379
    Robb235
    Robb235 Well-Known Member
    Chattanooga, TN
    1999 Turbo 4Runner
    Turbo 5vz uaEFI Standalone ECU 231mm Tundra Brakes RR Diff Lock Hayden 699 Transmission Cooler
    I have a '99 4Runner (3rd generation) which is very similar to 1st Gen Tacomas... I have the iPhone app "Engine Link" which also allows for custom PIDs. Try this one, it worked for me:
    OBD2 Mode and PID: 01B4
    Long Name: Transmission Fluid Temperature
    Short Name: TFT
    Minimum Value: 0.0
    Maximum value: 300.0
    Scale factor: x1
    Unit Type: °F
    Equation: A*(9/5)-38
    OBD Header to use: 0 (I put in zero for my iPhone's "Engine Link" app. You might need to leave it blank for Torque)
  20. Jan 16, 2014 at 6:40 AM
    #380
    jaypp1
    jaypp1 Member
    00 Tacoma Prerunner
    Thanks, Ill give it a try and post if it works (may be a week or so before I have time to get around to this)
