Wrinkle in hood with scoop. Worth $150?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mcm808, Aug 19, 2019.
  1. Aug 19, 2019 at 7:57 PM
    mcm808
    mcm808 [OP] Well-Known Member
    Micah
    Kane’ohe, O’ahu
    3rd gen
    Finally found a hood near me with a scoop for sale. Its $150 but has a wrinkle in it. Paint is matched to my truck but is this repairable for a reasonable price or should I pass?
  2. Aug 19, 2019 at 7:59 PM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    100% worth it if you can fix yourself. If not it’s going to cost 400+ for body shop to fix dent and sand/repaint. Then you have a $550+ used hood.
  3. Aug 19, 2019 at 8:01 PM
    mcm808
    Micah
    Kane’ohe, O’ahu
    3rd gen
    Yah I definitely can't do it myself...
  4. Aug 19, 2019 at 8:01 PM
    tacomattack
    tacomattack Well-Known Member
    I say no. You got yourself a 2019 perfect truck...then add a part that is banged up? I’d pass.
  5. Aug 19, 2019 at 8:01 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Ehhh... I think $400 would be on the "cheap" end (in Seattle). Certainly fixable, but you'll pay.
  6. Aug 19, 2019 at 8:03 PM
    djgynee
    djgynee Well-Known Member
    Southern California
    2018 Magnetic Grey Metallic Tacoma DCLB TRD Sport
    Pass. That’s the freaking front stage pic of your truck. The first thing everybody see when you pull up
    gurneyeagle likes this.
  7. Aug 19, 2019 at 8:05 PM
    newdles
    Achmed
    Yes very cheap end. Used crackhead in need minimum :). Then on top of that he’s got a used hood on a new Tacoma. Personally I wouldn’t swap hoods period unless I was swapping a hood with a truck just as new as mine and even then would be very hard pressed to do so.
    auskip07 and Bertw192 like this.
  8. Aug 19, 2019 at 8:08 PM
    djgynee
    Southern California
    And if you have the same metallic gunmetal gray I have you be surprised how the spray pattern of the metal flakes varies along with the “perfect” match. Chances are in the direct sunlight it’s either a little more blue or green than yours. Maybe even red. The tones are very subtle but trust me unless you don’t have OCD. If you do it’ll drive you nuts.
  9. Aug 19, 2019 at 8:09 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    For 150$ I'd get it. Just to have a spare. I wouldn't even fix it.
    RabidRotty and birdieking33 like this.
  10. Aug 19, 2019 at 8:10 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Pass as they would have to repaint the entire hood.
  11. Aug 19, 2019 at 8:11 PM
    djgynee
    Southern California
    Repaint hood and MATCH! o_O
    Your in for a headache
    booted likes this.
  12. Aug 19, 2019 at 8:15 PM
    Frsh2df
    Frsh2df Well-Known Member
    2017 MGM TRD Off Road 4x4
    I’d get it , try to straighten it out some and throw a bug deflector on it and hope it’s not noticeable.
  13. Aug 19, 2019 at 8:17 PM
    TX_Taco88
    TX_Taco88 IG: 4lo_taco
    Jeremy
    WA
    '18 4x4 TRD-OR DCLB
    KINGS, Bruteforce armor, Falcon wheels
    Spend 150 to reduce your visibility on trails. Makes sense to someone I guess.
    Burns, Chew and Atreyu like this.
  14. Aug 19, 2019 at 8:17 PM
    Dawdaw808
    Dawdaw808 Well-Known Member
    Dean
    Oroville, Ca
    06 Silver Tacoma
    3" pro comp
  15. Aug 19, 2019 at 8:24 PM
    Frsh2df
    Or just have both
    RabidRotty and asuchemist like this.
  16. Aug 19, 2019 at 8:24 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Yes, hide it under a bug deflector. Out of sight, out of mind, right?
    mcm808[OP] likes this.
  17. Aug 19, 2019 at 8:26 PM
    mcm808
    Micah
    Kane’ohe, O’ahu
    3rd gen
    thanks for the input guys...im still on the fence. Im super ocd so I'm leaning towards a pass.
    tcjacado likes this.
  18. Aug 19, 2019 at 8:26 PM
    ICU1
    ICU1 Well-Known Member
    It’s like ABC gum.
  19. Aug 19, 2019 at 8:27 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    If you're OCD, pass. If you're me, you get it. My trucks dirty enough for it to blend in.
    tcjacado and Frsh2df like this.
  20. Aug 19, 2019 at 8:28 PM
    Trah
    Trah Licensed Class C Driver...
    San Diego
    2017 Barcelona Red TRD Sport ACLB
    stuff and things...
    if $150 isn't that much to you, go get it and if you decide not to use it, resell it...
    Bertw192, mcm808[OP] and Frsh2df like this.
