Wrenching on gravel/dirt/grass tips and tricks
Discussion in 'Garage / Workshop' started by truckbeans, Mar 22, 2019.
  1. Mar 22, 2019 at 5:36 AM
    truckbeans
    truckbeans [OP] Well-Known Member
    Kent
    Sylva, NC
    2018 DCSB OR
    OME 887s, nitrochargers all around, Headstrong progressive add-a-leaf, 255/85-R16 Yokohama Geolandar M/T, Full set RCI skids, RCI sliders, SOS Slimline w/ Smitty 10k winch
    I can't quite afford to pour that slab yet, so I'm doing everything on slightly uneven gravel which means:
    • Some sort of wood stacked under jacks and stands
    • Laying on scrap cardboard
    What else have you got to make my life easier? :)
    DrFunker, wilcam47 and CygnusX191 like this.
  2. Mar 22, 2019 at 5:41 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    A tarp for a lean-to for when it's raining
    Maybe one of these?
  3. Mar 22, 2019 at 5:42 AM
    truckbeans
    Kent
    Sylva, NC
    2018 DCSB OR
    Hell yeah! Did not know those jacks existed.
    wilcam47 likes this.
  4. Mar 22, 2019 at 5:42 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    1 1/8 plywood, 2 sheets
  5. Mar 22, 2019 at 5:48 AM
    Gus87
    Gus87 Well-Known Member
    Chicagoland
    16 trd sport
    I like that quick adjustment but I wouldn't trust that little pin holding it up.
  6. Mar 22, 2019 at 6:10 AM
    zimmmtaco
    zimmmtaco Better than it was before it got like it is
    Northwestern PA
    15 DCSB Blue Ribbon Met 4x4 OR, 6MT
    TRD Pro susp kit 265/75R16 BFG K02's Husky Floormats Vent visors Hella 500 on custom mount
    When ground is cold and/or wet, 1/2" Insulation board(stuff with foil/plastic lamination) works great instead of cardboard
    also have one of these which is great for uneven floors & gravel
    http://www.bonecreeper.com/roughrider.html
    wilcam47 and truckbeans[OP] like this.
  7. Mar 22, 2019 at 9:28 AM
    truckbeans
    Kent
    Sylva, NC
    2018 DCSB OR
    More things I didn't know I needed, goodbye money!
  8. Mar 22, 2019 at 9:31 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Creepers are a godsend, but they need one with rubber wheels and a bit heavier duty.
  9. Mar 22, 2019 at 9:33 AM
    truckbeans
    Kent
    Sylva, NC
    2018 DCSB OR
    Agreed! That rough rider looks nice but I can't imagine it rolls very well over loose gravel.
    CygnusX191[QUOTED] likes this.
  10. Mar 22, 2019 at 10:18 AM
    Oregon Mike
    Oregon Mike Well-Known Member
    Eugene OR
    18 AC OR
    I've had a few different creepers over the years and none of them ever seemed to work very well on my rough driveways I guess. A big piece of cardboard is easy to slide around on so that's what I use :cheers:
  11. Mar 22, 2019 at 12:10 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Until it gets wet
    Oregon Mike[QUOTED] likes this.
  12. Mar 22, 2019 at 12:43 PM
    Oregon Mike
    Eugene OR
    18 AC OR
    ^fair, but I tend to not work in the rain. Fair weather shade tree mechanic here :cheers: I also recycle the cardboard after every project so long as I didn't ruin it with oils.
  13. Mar 22, 2019 at 1:21 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Oils, fluids, spilled beverages, kids up the street get their hands on a hose...
  14. Mar 22, 2019 at 2:15 PM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    Wrap any internal parts that are temporarily exposed in plastic. A little breeze and dirt gets in your oily smooth parts and makes them not oily and smooth.
    truckbeans[OP] and CygnusX191 like this.
  15. Mar 23, 2019 at 6:01 AM
    ralfnjan
    ralfnjan Well-Known Member
    Buy yourself a new refrigerator, throw it away (new might be crap anyway), now you have a nice, big, body sized piece of cardboard to work on. Store it indoors when not in use. I have one that's 10 years old at least.
  16. Mar 23, 2019 at 6:05 AM
    VirusCage
    VirusCage Well in the secondary immune response
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 1995 Landcruiser 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Magnets magnets, magnetic trays, magnetic extensions, free magnetic trays from harbor freight, and possibly some more magnets. Seriously before paving my driveway, I lost many bolts and screws in the grass and gravel, but with a few magnetic helpers, found most.
  17. Mar 23, 2019 at 8:33 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I used a tarp to lay on when my plow truck broke and I had to change out the Transmission...in my driveway out in the snow. Helped to have some scrap pieces of plywood to lay on also. I try not to work on vehicles in the elements but sometimes you have to get it done...
    truckbeans[QUOTED][OP] and Hobbs like this.
  18. Mar 23, 2019 at 8:41 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Sometimes ya' gotta work out in crappy weather.
  19. Mar 23, 2019 at 8:46 AM
    VirusCage
    Bruce
    Allison Park, PA
    I have used my Sam's club pop up canopy on multiple occasions. Definitely worth it
  20. Mar 23, 2019 at 8:48 AM
    wilcam47
    Will
    Bourbon state
    what would have been nice to have was one of those big blower heaters....
    truckbeans[OP] and Hobbs[QUOTED] like this.
