Would getting rear-ended possibly damage an axle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 464201, Apr 29, 2019.
  1. Apr 29, 2019 at 9:56 AM
    464201 [OP] Well-Known Member
    Debbie
    201 Toyota Tacoma Prerunner
    My son was rear ended in his 2010 Tacoma on his left rear side a while back (2017). The impact was from the white car’s front right corner into my son’s left rear corner and, pushed my son into the car in front of him while they sat at a stop light. Everything was repaired by insurance.
    Question:
    Could this collision have bent the left rear axle and the axle still be functional for 60,000 plus miles afterwards, once the car was fully repaired by St. Farm?
    Wondering if the left rear axle could have been damaged in this accident and caused, or contributed to, the current rear differential blowing out, as it has. Just trying to consider everything before we repair.
    Thank you sincerely for sharing your opinion.
  2. Apr 29, 2019 at 11:27 AM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    From the red paint on the car's bumper it looks like his bumper might have impacted the LR tire. Axle might be bent. An alignment will confirm this (thrust angle).
  3. Apr 30, 2019 at 8:05 AM
    Debbie
  4. Apr 30, 2019 at 8:53 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I just don't see how. If there was any damage I would think you'd either bend the axle shaft (big time shaking), or bend the housing (major tire wear and alignment issues). Damage to the diff would only be from either of the above, which you couldn't ignore for 60K.
    I got hit in the left rear wheel about 50K ago. Needed a wheel, but no apparent damage to axle. No shakes, alignment or tire wear issues. Diff works the same as it always did.
    464201[OP] likes this.
  5. Apr 30, 2019 at 9:39 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I got T boned super hard almost perfectly perpendicular into my driver rear wheel. Wrote off the other drivers corolla, I needed a new wheel and fender flare. No apparent issues for 30 000 miles afterwards.
  6. Apr 30, 2019 at 9:51 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    The fact that he put 60k and more miles on it afterward suggests...no...
    No way insurance is going to cover that.
    I'd be looking at:
    A) How many miles are on the truck total?
    B) When was the diff fluid last changed?
    C) Does your son need tires often? (Burnouts, drag racing, etc)
  7. May 1, 2019 at 6:50 AM
    Debbie
    Thanks for your input. It helps. I just wanted to consider axle damage as a possible contributor to his RD going out, again. He has no abnormal tire wear or shaking. I have since learned from my son that, at some point after the repairs were done, the rear diff lock wouldn't unlock. He drove it like this on pavement not knowing it is a huge no-no. Ugh. I now believe that this is why the RD has gone out. Our mechanic is pulling the RD out today to see what he can see. I'm hoping to only have to replace the RD and not the entire rear assembly, as we had originally planned to do. All the info and advice from my three posts on this TW site about this RD issue have been tremendously helpful! Thanks to all who contributed!
    Muddinfun likes this.
  8. May 1, 2019 at 6:50 AM
    Debbie
  9. May 1, 2019 at 6:52 AM
    Debbie
  10. May 1, 2019 at 6:52 AM
    Debbie
    Thanks for your input. It helps. I just wanted to consider axle damage as a possible contributor to his RD going out, again. I have since learned from my son that, at some point after the repairs were done, the rear diff lock wouldn't unlock. He drove it like this on pavement not knowing it is a huge no-no. Ugh. I now believe that this is why the RD has gone out. Our mechanic is pulling the RD out today to see what he can see. I'm hoping to only have to replace the RD and not the entire rear assembly, as we had originally planned to do. All the info and advice from my three posts on this TW site about this RD issue have been tremendously helpful! Thanks to all who contributed!
  11. Jul 13, 2019 at 1:07 PM
    pepperhead71
    pepperhead71 Well-Known Member
    Cajun County Mire,La
    2015 Tacoma Double Cab SR5,2007 Tacoma Double Cab SR5
    I got t-boned but at a slight angle.She ran a red light trying to make a right turn.Impact was on passenger side and spun me around in the road.After spending a week in a frame shop they said the frame was straight.But it still looked like I was drifting when driving lol.Well finally figured out the rear differential/axle will need to be changed.Anyone have any idea approximately how much it'll cost.
  12. Jul 13, 2019 at 1:30 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Mercury is in Gatorade.... :der:
  13. Jul 13, 2019 at 1:34 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    You said again. Had it gone out before?
    Seems easier and cheaper to try and source a complete used rear assembly and just eliminate and concerns.
    Skyway likes this.
