worth cleaning intake plenum?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JustADriver, Nov 29, 2022.
  1. Nov 29, 2022 at 5:24 PM
    JustADriver
    JustADriver [OP] Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    I'm doing the driver side valve cover gasket. The upper and middle intake plenums are carbon caked. Is it worth trying to clean them with throttle body & air intake cleaner? I'll try to find a round long-handled flexible brush locally in the morning (holes are 1.5"), but that's going to be tough, and without one I'm concerned I'll just be loosening the carbon and cause it to flush into the engine. The lower plenum, which I'm leaving on the engine because the valve cover is accessible now, looks the same as these, and I don't know how much good cleaning these alone would do.
  2. Nov 29, 2022 at 5:25 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
  3. Nov 29, 2022 at 5:31 PM
    1997tacomav6
    Denver
    plenum Probably not but,
    What do the actual valves look like?
    From the top looking down into
  4. Nov 29, 2022 at 5:37 PM
    JustADriver
    Inside the valve cover right? I haven't opened that up yet. Have to resume in the morning. Here's my best pic of what the passenger side looked like.
    1997tacomav6[QUOTED] likes this.
  5. Nov 29, 2022 at 5:43 PM
    1997tacomav6
    Denver
    No, under the blue tape on this photo you will see the valves.
    I run methanol on my supercharger so mine are extra clean
  6. Nov 29, 2022 at 5:44 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    For what it's worth, when I did my valve cover gaskets, I used a foaming engine degreaser and a small brush and just went to town on the upper and lower intake manifolds. Mine were not as caked as yours though. It's probably not hurting anything to leave them dirty, but they weren't hard to clean.
    TWJLee likes this.
  7. Nov 29, 2022 at 5:56 PM
    JustADriver
    Ok, I learned something new! All of them look like this one. A mess all the way in, but fairly clean valves?IMG_1975.jpg
  8. Nov 29, 2022 at 5:57 PM
    Bishop84
    Bishop84 Well-Known Member
    I'd call that fairly normal. You really cant clean them with any chemical and you risk deposits falling in. I'd just leave that personally.
    JustADriver[OP] likes this.
  9. Nov 29, 2022 at 7:14 PM
    1997tacomav6
    Denver
    They look fine, a little bit of build up but I would not worry about it.
  10. Nov 29, 2022 at 8:03 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I have the 4 banger.....but did same thing....
    left lower intake on......and cleaned the heck out of the upper...
    thats where the vac passages, egr passage and its sensor all get carboned out....
    Couple cans of oven cleaner.....giant bottle brush.....
  11. Nov 29, 2022 at 8:25 PM
    1997tacomav6
    Denver
    marvel mystery oil will completely dissolve carbon too if you let it sit on the carbon overnight, FYI
  12. Nov 30, 2022 at 5:16 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    No, the carbon/oil gunk is actually filling the porosity making your plenum smoother for air anyway. Valves are clean.
