Woolwax removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Capespencer68, Nov 7, 2020.
  1. Nov 7, 2020 at 5:03 AM
    Capespencer68
    Capespencer68 [OP] Well-Known Member
    Scott
    Massachusetts
    2021 DCSB AG Trail edition
    Im slated to have Woolwax put on today. I will be painting Eastwood rust encapsulated paint next summer, I don’t have the time before winter to do it. So will the Woolwax power wash off when I’m ready to paint for proper paint prep?
    GQ7227 likes this.
  2. Nov 7, 2020 at 5:13 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    That's going to be tough IMO
    Capespencer68[OP] likes this.
  3. Nov 7, 2020 at 5:15 AM
    Clearwater Bill
    Billy
    Largo Florida
    o_O
    Guessing it will quadruple your project time......... if you can even get it cleaned enough to paint.
  4. Nov 7, 2020 at 5:20 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Hot water, and a degreasing soap. Faq sheet they sent me with my order:
  5. Nov 7, 2020 at 5:21 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    It will, but not as easy as fluid film.
  6. Nov 7, 2020 at 5:23 AM
    Capespencer68
    Scott
    Massachusetts
    E
    Excellent info thanks
    MikefromCT[QUOTED] likes this.
  7. Nov 7, 2020 at 5:27 AM
    tathambenjamin
    tathambenjamin Well-Known Member
    ben
    2008 4Runner SR5
    -2.5/1.5 spacer lift -270/65/17 Cooper AT3
    Even fluid film is a challenge to get off. I painted then fluid filmed, then tried to clean it off to do some touch up paint and cleaning the frame by hand takes some serious time...
  8. Nov 7, 2020 at 5:28 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    I’ve done a bit of painting on cars and I’m sure you already know this but it’s extremely sensitive to contamination. If you know for a fact your painting next season I would really suggest you look for an alternative cause you are going to create one hell of a job for yourself. That’s the stuff nightmares are made of
  9. Nov 7, 2020 at 5:33 AM
    Shellshock
    Iowa
    @GQ7227 has done all these things and can give you some info
    Capespencer68[OP] and GQ7227 like this.
  10. Nov 7, 2020 at 5:38 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i did not get one of these sheets!, and i have placed two orders so far with kellsports in MA
  11. Nov 7, 2020 at 5:44 AM
    Capespencer68
    Scott
    Massachusetts
    Thanks everyone. I’m going to try to tackle the frame paint first then Woolwax after with Jason in Taunton MA.
  12. Nov 7, 2020 at 5:55 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i put it on thick with the WW spray can, then tried to see what happens after a direct shot with the garden hose on power shower setting,
    then rubbed the finger to see what was left near the top
  13. Nov 7, 2020 at 5:55 AM
    MikefromCT
    CT
    2013 TRD OR DCSB
    I must have been lucky to get the sheet. Checked the faq on their website and it didnt include anything about washing/painting, and I knew that I read it somewhere. Glad I was able to find it.
  14. Nov 7, 2020 at 6:44 AM
    Plain Jane Taco
    USA
    Smart plan :thumbsup:
  15. Nov 7, 2020 at 9:55 AM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    alcohol
  16. Nov 8, 2020 at 6:31 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    this or something similar may be useful for better removal
    https://www.eastwood.com/eastwood-pre-painting-prep.html
  17. Nov 8, 2020 at 9:18 AM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    I use simple green heavy duty , it’s purple in color and is safe on aluminum (doesn’t react with it or corrode it) and I put it in a cheap 1 gallon sprayer to apply it . I usually use a half gallon and then pressure wash the underbody and then the second half gallon and do it again
    Capespencer68[OP] and Pablo8 like this.
  18. Nov 8, 2020 at 9:35 AM
    soggyBottom
    soggyBottom Well-Known Member
    I think the hot water is key here. To harvest the oil from wool when it's being manufacturered, they would traditionally boil the wool in water. Eventually the wax/oil would float to the top. There may be more modern methods.
    GQ7227 likes this.
