Won't Start Until Battery Disconnect/Reconnect
Discussion in '1st Gen. Tacomas (1995-2004)' started by HuckleSmothered, Sep 4, 2020.
  1. Sep 4, 2020 at 4:14 PM
    HuckleSmothered
    HuckleSmothered [OP] Active Member
    95 Tacoma Ext Cab
    PROBLEM
    The truck will intermittently not start. No attempt to turn over.
    When this happens, all the lights dim; interior, dash, radio, as if the battery were weak.
    Right before cranking everything is perfectly fine, all lights come on, everything looks normal.
    There's an ugly sounding and sad click right at turning the key to crank and then nuthin'.
    After "fixing", it will work for about a week. Consistently. It's been 6-7 days in between almost exactly each item.
    RECENT WORK
    • New maintenance-free battery 9 months ago.
    • New starter 3 months ago.
    • New electronic ignition igniter 3 months ago.
    • New crankshaft position sensor 3 months ago.
    • New distributor 2 months ago.
    • New ignition coil 2 months ago.
    • New alternator <1 week ago.
    TROUBLESHOOTING
    Started happening about 3 weeks ago. I got it jumped the 1st two times it happened. Got home, tested the battery. Nearly a full charge. So it can't be the battery. After a jump, if I turn it off again, it will not start by itself. Can't find any bad fuses (visibly).
    I figured given the other newish parts, I was left with the alternator. Took my existing 10+ year old alternator to get tested. Tested fine. Replaced it, truck started. Weird. Happened a week ago again, though. Figured my alternator was intermittently bad. So I replaced it regardless of testing just last week. Worked for almost a week. Just happened again today.
    So, figured out today that if I disconnect the battery, then reconnect it (just a hot minute before reconnecting, not leaving it off for any significant time), it works. Not the battery itself. The connections are tight. And very clean.
    The only interweb suggestions I saw about this are either alarm related, or alternator. My truck doesn't have an alarm. In fact, if it were stolen, I'd be pretty damn grateful. And I just replaced the alternator in addition to my old one testing fine.
    So ... thoughts?
  2. Sep 4, 2020 at 4:19 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    It is possible to have under insulation corrosion on battery cables. Most of the time you can see it right where the cable connects to the lug. But sometimes a pinhole in the insulation anywhere along the length can allow moisture in and corrosion to begin. I'd just replace the cables and give it a try before digging deeper.
  3. Sep 4, 2020 at 7:06 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Most here rebuild starters with the brush and plunger kit because the aftermarket new and remanned SUK
    Rebuild the OEM $
    Buy new OEM $$$
    Replace failed aftermarket starters more often because they SUK
    Rachelsdaddy and Taco critter like this.
  4. Sep 4, 2020 at 7:42 PM
    Glamisman
    Glamisman Well-Known Member
    more than likely your battery cables, both positive and negative are in need of replacing. There are a few posts here showing what to do.
    Black DOG Lila and Taco critter like this.
  5. Sep 4, 2020 at 7:46 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I had a similar issue with my 4runner. There was hidden corrosion under the batter cable insulation.
    The corrosion would "shift" allowing the truck to start when connecting and disconnecting the battery cables.
    Truck would start fine for a few weeks then the same issue would happen again.
    The cable that was the culprit was the battery ground cable to the fender wall.
    That guy looked really clean visually, but under the insulation it was CORROSION EVERYWHERE.
    Black DOG Lila likes this.
  6. Sep 4, 2020 at 9:06 PM
    HuckleSmothered
    95 Tacoma Ext Cab
    I thought the battery cables, other than the ground, was part of the wiring harness, in general. Just those are replaceable? Recommendations on where to start? I don't see any readily apparent posts here on that.
  7. Sep 4, 2020 at 9:16 PM
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    this is going to turn out to be real simple, you got a loose or corroded connector somewhere. stop throwing money at it. you have already been given the right advice.
    JudoJohn likes this.
  8. Sep 5, 2020 at 2:12 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If this is a 95 with the original battery cables long after time to have replaced them .
    The extra added Current when jumped can push through the added resistance of the corroded cables.
    I would also look real close at the terminals is one coming loose after a few days causing problems.
    I really hope you bought the Alternator at a Toyota Dealer if not you traded down .
    JudoJohn and HuckleSmothered[OP] like this.
  9. Sep 5, 2020 at 3:25 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Have you looked at the ignition switch itself?
  10. Sep 5, 2020 at 4:52 AM
    ramonortiz55
    Ramon
    Texas
    stock
    Yes, they are replaceable and not part of the wiring harness
  11. Sep 5, 2020 at 5:21 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Here is an example of what is being said about possible internal corrosion in your battery cables. When my wipers came on (switch off) and I couldn't get them to shutoff, I found the damage in the first pic. When I shaved some insulation off, I found the internal corrosion.
  12. Sep 5, 2020 at 6:29 AM
    HuckleSmothered
    95 Tacoma Ext Cab
    Thank you, everyone! I'll take a hard look at these wires and probably just replace them anyway since they're probably original (although I've only had it for 10 years) and report back.
    The ignition switch was looked at a few months ago since there was some other starting issues that a shop was investigating. They said there weren't any indications (at the time) that it was a problem.
  13. Sep 5, 2020 at 6:56 AM
    JEEPNIK
    If you had it in a shop and They they didn’t replace 10+ year old cables first find another shop.
    Sounds like they replaced some expensive bits without looking at the most probable cause.
    JudoJohn and Wyoming09 like this.
  14. Sep 5, 2020 at 3:10 PM
    HuckleSmothered
    95 Tacoma Ext Cab
    A shop hasn't looked at the truck since this specific problem started happening. There was a different problem with starting that they got worked out. 2020 has been the year of my truck not starting for various reasons. Luckily, there's not a whole lot of places to go down here in Florida in 2020. So just a minor inconvenience.
  15. Sep 6, 2020 at 5:29 PM
    kctmet
    kctmet Well-Known Member
    Orange County, California
    02 DC V6 4x4 TRD
    Check your ground cable connected to chassis. It happened to me long time ago. I made a bigger ground cable and replaced it, resolved!
  16. Sep 7, 2020 at 1:54 PM
    HuckleSmothered
    95 Tacoma Ext Cab
    I replaced the positive and negative battery cables today (cables came with terminal connectors already attached, too). While replacing them, I didn't notice any loose connections. Looking at the cables while they are out and easily inspectable, I do not see any noticable concerns. The negative cable seems fairly new. The positive was obviously older. No damage to the wires or insulation. No visible corrosion.
    They're new now, though. And everything is definitely tight and snug, ground included.
    Since it's been happening almost weekly, I figure if it doesn't occur in two weeks then the cables were the issue. I've got my fingers crossed. I'll check back in then. Fingers crossed. Jumper cables at the ready.
  17. Sep 7, 2020 at 1:59 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Did you check all the ground posts and make sure theres no corrosion?
    Cut all the insulation from cables off and check if they were corroded.
  18. Sep 7, 2020 at 2:27 PM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    With a voltmeter you could have easily found the connection issue (if that’s what fixed it) by performing voltage drop tests between every point on both the positive and negative cables, but only when it would not start. If your interior lights and everything was going dead when it made the click noise, that definitely sounds like a connection issue, whether inside the cable or wherever.
    BTW if any of you see some half assed mechanic stabbing wire insulation on your truck with a test light, rip it out of his hands and stab that bastard with it. It’s ok to do if you know you’re going to have to open the circuit anyway, you can fix it with adhesive heat shrink tubing. Countless times this is the cause of the internal corrosion of wires, some jackass stabbing the wire, then leaving it like that to slowly corrode, and end up at my shop. Smh... rant over
  19. Sep 7, 2020 at 2:55 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    How long has the problem occurred? Trying to get an idea of if it started before or after you put all those new parts on it.
  20. Sep 7, 2020 at 3:08 PM
    JEEPNIK
    True words. Heck the OP’s problem could have started during earlier “repairs”.
    Testing as mentioned can take time and you need to know how. It’s often easier to just replace the cables, especially if they are older.
    Replacing cables is a PM that’s rarely done.
