Wiring identification on front turn signals.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thebeardedbeerguy, Aug 7, 2021.
  1. Aug 7, 2021 at 1:38 PM
    thebeardedbeerguy
    thebeardedbeerguy [OP] Well-Known Member
    Newnan, GA
    2015 Tacoma PreRunner SR5 with towing package
    Dealer installed (running boards - part of purchase deal) Weather Tech (floor liners, headlight guards, bug shield); Vent Shade (rain guards, door sill protectors); Color matched body side molding; ARE color matched rear hatch; rubber bed and tailgate liner; Ranch Hand brush guard; SteelCraft Elevation rear bumper; 4" auxiliary running/stop/turn for place in bumper; led light to light up "SteelCraft" logo in bumper.
    Does anyone have the color code for a 2015 front turn signal? I have yellow, green and white/black stripe. I want to run additional turn signals on my bruh guard so the idiots can see me. Not that they would pay attention to it. Thanks in advance.
  2. Aug 7, 2021 at 1:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Aug 7, 2021 at 1:59 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Those colors are at the turn signal switch.
    Do you want to tap into the front lights or the turn signal switch?
    The switch just grounds either the yellow or green wire, the flasher then sends power to the bulbs.
  4. Aug 7, 2021 at 2:03 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    TnShooter[QUOTED] likes this.
  5. Aug 7, 2021 at 6:12 PM
    caribe makaira
    Caribbean, Puerto Rico
  6. Aug 10, 2021 at 10:32 AM
    thebeardedbeerguy
    Newnan, GA
    Yes. Turn signal. People can’t see my regular turn signal with the brush guard from the front sides.
  7. Aug 10, 2021 at 10:34 AM
    thebeardedbeerguy
    Newnan, GA
  8. Aug 10, 2021 at 2:36 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I’m saying, where do you want to make the connection, in the truck or under the hood?
  9. Aug 10, 2021 at 2:39 PM
    thebeardedbeerguy
    Newnan, GA
    Under the hood splice to the turn signal wires. LED so low current draw.
  10. Aug 10, 2021 at 4:49 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Use the 4 wires I circled in red.
    TnShooter likes this.
  11. Aug 10, 2021 at 5:22 PM
    TnShooter
    Deogee
    STOCK
    Those should work fine.
    I’d probably tie the grounds together and ground them separately from my OEM wiring.
    That way I don’t have to tap into my factory ground wires. I don’t like splicing into any more wires than I have too.
    Dm93 and super_white[QUOTED] like this.
  12. Aug 10, 2021 at 5:23 PM
    caribe makaira
    That's why I posted the T harness.:burp:
  13. Aug 10, 2021 at 5:37 PM
    TnShooter
    Deogee
    STOCK
    Indeed you did, I was just stating the fact again. Especially if OP is using scotchlok taps. I don’t care for them myself.
    Like these, I try not to use them.
  14. Aug 10, 2021 at 7:16 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yea please don't use those or the "twist n tape", either solder and heat shrink (sealant type) or heat seal butt connectors for any wiring splices on the exterior unless you wana be redoing it in a year or two (especially if your in the rust belt).
    GilbertOz and TnShooter[QUOTED] like this.
