Wiring help ecm swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by pairodice, Sep 11, 2018.
  1. Sep 11, 2018 at 7:03 AM
    pairodice
    pairodice [OP] Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    Does any one know what ecm plug E5 slot #5 on a 2002 3.4 powers. It is supposed to be one of the wires that needs to be unpinned for the auto trans. It is labeled as IGSW in the service manual and the ecm pinout guide @mosk from yota tech put together. Problem is my slot #5 wire is black w/ red stripe. Both fsm and the guide show them as black w/ white stripe. The other confusing part is on the same E5 plug it shows slot #15 as the same function, same wire color??? When I verified the wire #15 it is the correct color on my harness of black w/white stripe. The guide also states the are multiple wires labeled wrong in the fsm. Short of pulling out the entire engine harness and verifying every wire and deleting unused wires not sure how to figure this out, thanks guys
  2. Sep 11, 2018 at 7:04 AM
    pairodice
    Jay
    SF NM
    Mosk guide
  3. Sep 11, 2018 at 8:17 AM
    2JHilux
    2JHilux Level 8 Tinkerer
    Denver, CO
    2001 Tacoma Double Cab 4x4
    manual swap in progress
    New to the tacomas but black/red is switched 12V on alot of toyotas, but I have also seen black/white for the same thing.
    I would probe it unless someone knows for sure.
  4. Sep 11, 2018 at 11:05 AM
    pairodice
    Jay
    SF NM
    I read in the service manual IGSW stands for ignition switch power. You are probly right, I would just like to find out what it powers if it's hot. Rather not be running a random powered wire into my ecm that may not be required for manual trans. I think I found a local guy willing to let me take some pics of an 02 manual ecm in a stock truck
  5. Sep 11, 2018 at 11:19 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Consult your 2002 wiring diagram.
    IGSW includes multiple facets related to your ignition, starting, Engine control, and possibly your alarm & auto transmission circuit. Look at those specific circuits in the 2002 EWD. In my 04 E5pin15 is my one and only IGSW, it's one side of the powered electromagnet for my CoR(fuel pump relay). But I'm sure you're well aware alot of differnces there are between an 02 & an 04...
    Personally. I'd check continuity at pins 5 & 15 of the unconnected E5 harness and see if they have a relationship. If you can't find any info on it I'd unpin #5 and see if your truck starts or not. Stays running, or if you throw any codes. It won't hurt anything.
    When I swapped transmission/ecu at least two wires didn't fit the colors listed, but I was able to figure it out using my EWD.
  6. Oct 15, 2021 at 7:57 AM
    Alwaysdaily
    Alwaysdaily Active Member
    Ty
    97 Tacoma 2.7l DLX
    Where did you get that pin out guide !? I need a hat for a build
  7. Oct 15, 2021 at 8:06 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Myself I have found what works the best is having the Toyota Electrical Wiring Diagrams for all the vehicles involved in the swap. I am used to working from them so for me it is easy .
    I have seen the ECM pin outs in the Factory Service Manuals again you would need the years and models involved .
