Wiring harness for brake controller in 2020 Tacoma?
Discussion in 'Towing' started by tkeener, Feb 22, 2020.
  1. Feb 22, 2020 at 2:43 PM
    tkeener
    tkeener [OP] Member
    Todd
    2012 Toyota Tacoma Trail Teams TRD Sport
    Hello.
    I'm installing the Redarc Tow-Pro Elite in 2020 Tacoma. I think I have found the connector under the dash, but it doesn't look like the picture in the manual or like the connector in my 2012 Tacoma. In short, the Tekonsha 3040-P Brake Controller Wiring Adaptor does not seem to fit connector end in the tacoma.
    To connect the Redarc Tow-Pro controller unit to the Tacoma connector, what is the correct adaptor?
  2. Feb 22, 2020 at 9:46 PM
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
  3. Feb 23, 2020 at 2:22 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    I used a pigtail from Etrailer. It was plug n play, about 10 minute install. Plugged into connector behind plastic drivers side footwell panel. Other end plugged into my Prodigy P2. Hardest part was getting plastic footwell panel off. No splicing connectors.
    Gay Focker likes this.
  4. Feb 24, 2020 at 2:50 PM
    tkeener
    tkeener [OP] Member
    Todd
    Pickupman2007[QUOTED] likes this.
  5. Mar 2, 2020 at 3:04 PM
    Crooked Beat
    Crooked Beat Well-Known Member
    GTA
    2021 Tacoma DCLB SR
    Where do you place the controller on the dash/ The 2020 I saw at the dealership did not have the opening/change pocket to the left of the steering wheel on the dash.
  6. Mar 2, 2020 at 5:46 PM
    Pickupman2007
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    That’s why I used the RedArc, it has a box that can be mounted behind the dash and the control knob can be installed in a switch blank.
    Gay Focker, doc76, jgrider16 and 2 others like this.
  7. Mar 2, 2020 at 7:11 PM
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
    Perfect! But I would like to use the Tekonsha P3 that I already have. I guess I am not going to be able to make a neat install. It seems poor planning on Toyota's part that they pre wire for the controller, but don't have a place to put it.
  8. Mar 2, 2020 at 7:15 PM
    Pickupman2007
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
  9. Mar 2, 2020 at 7:19 PM
    Pickupman2007
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    Unfortunately. That seems to be a common problem with many new vehicles.
  10. Mar 3, 2020 at 10:37 AM
    jayrome
    jayrome Well-Known Member
    2020 Tacoma TRD Off Road - DCLB
    King 2.5 Front Ext Travel Coilovers with Adjusters and SPC UCAs King 2.5 Rear Ext Travel with Adjusters 17" Method NV Wheels BF Goodrich K02 275/70/17 RCI Steel 3 Pc. Skids and Diff Cover All Pro Rock Sliders Victory Strike Front Winch Bumper with Warn Evo 10K Twin ARB Compressor with Rago Mount Wifey Air System
    Having trouble finding the connector on my 2020. I’ve fished around a bit and no luck. Is it still to the left (drivers side) behind the kick plate?
  11. Mar 3, 2020 at 11:27 AM
    Pickupman2007
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    yes it is
  12. Mar 3, 2020 at 5:35 PM
    Aquatic Tacoma
    Odessa, Fl.
    This is about the closest to "clean" install you can get with a Prodigy.
    https://www.amazon.com/ESP-Truck-Accessories-Controller-Compatible/dp/B07L7MRC79
  13. Mar 3, 2020 at 6:15 PM
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
  14. Mar 3, 2020 at 7:03 PM
    Pickupman2007
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    Yep, the trac off button used to be on the overhead console but now the S.O.S button took it's place and they moved the trac off button to where the pocket used to be. Also the blank I used for my RedArc is where the view button is if you get the 360 camera option.
  15. Mar 4, 2020 at 7:11 AM
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
    I think I will end up putting my controller in the middle console. I hate to put holes in a new truck though :-(
  16. Mar 10, 2020 at 10:04 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    It's back there, all the way up against the firewall.
    Taco_mike73 likes this.
  17. Mar 12, 2020 at 2:42 PM
    Aquatic Tacoma
    Odessa, Fl.
    I screwed mine into plastic under dash near left shin. If I remove it you won’t see the screw holes unless you lay on floor and look up.
    mountainjoe1968 and Crooked Beat like this.
  18. Mar 28, 2020 at 6:54 PM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
  19. Mar 30, 2020 at 10:48 AM
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
  20. Mar 30, 2020 at 4:03 PM
    Canadianguy91
    Sean
    2016 Limited
    Thanks!
