Wiring for dashcam from the overhead console
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CheemsMcGoober88, Nov 27, 2022.
  1. Nov 27, 2022 at 12:17 PM
    CheemsMcGoober88
    CheemsMcGoober88 [OP] Well-Known Member
    2021 TRD Offroad
    I'm trying to wire a 5v power supply inside the tss box as well as install a switch on it for my dash cam. Does anyone know which wires I should pull the power from?
    (edit, I decided to wire it from the overhead console. Any info on which wires to use from the wiring harness would be appreciated.)
  2. Nov 27, 2022 at 1:36 PM
    Sinagua
    Sinagua Beerdom Brewing - brewing in the shadows
    Rob
    Harrisburg, NC
    2019 OR DCSB, 2022 Accord Sport Hybrid
    Dobinsons Suspension, SOS sliders and slimline bumper, Smittybilt winch, Skinny Geolanders and a tune
    My4thTacoma, Boatman12 and cryptolime like this.
  3. Nov 27, 2022 at 1:40 PM
    CheemsMcGoober88
    2021 TRD Offroad
  4. Nov 27, 2022 at 1:57 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    might be easier to just buy the adapter and install a switch onto it
  5. Nov 27, 2022 at 2:08 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Curious, why would you want to turn it off?
    DES2009 and Tocamo like this.
  6. Nov 27, 2022 at 3:51 PM
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
  7. Nov 27, 2022 at 4:34 PM
    CheemsMcGoober88
    2021 TRD Offroad
    I want it wired to constant power so it can run while I'm parked but also want it on a switch so it's not on for extended periods of time draining the battery.
    Fatback17[QUOTED] likes this.
  8. Nov 27, 2022 at 4:42 PM
    CheemsMcGoober88
    2021 TRD Offroad
    stftaco[QUOTED] likes this.
  9. Nov 27, 2022 at 4:58 PM
    CheemsMcGoober88
    2021 TRD Offroad
    Now to find a wiring diagram for the overhear console
  10. Nov 27, 2022 at 4:59 PM
    kona61
    kona61 Well-Known Member
    J
    LR 2022 Tacoma TRD OR
    RCI Skids
    I was going to say that I'd avoid messing wit the TSS box. It seems like quite a high risk system to try and pull power from.
  11. Nov 27, 2022 at 5:07 PM
    CheemsMcGoober88
    2021 TRD Offroad
    Indeed, doesn't seem to be much room in there either.
    Overhead console it is.
    kona61[QUOTED] likes this.
  12. Nov 27, 2022 at 8:14 PM
    stftaco
    CheemsMcGoober88[OP] likes this.
  13. Dec 3, 2022 at 1:10 PM
    CheemsMcGoober88
    2021 TRD Offroad
    Ok so I tested the wires assuming the upper right hand wire with the black stripe is the ground. The two pins marked in red are when I'm getting constant 12v with the vehicle off.
  14. Dec 4, 2022 at 1:38 PM
    CheemsMcGoober88
    2021 TRD Offroad
    I wired it to the overhead console harness and added a switch. Everything works fine so far. I also have a rear camera that I'll wire in the future. I'm thinking of pulling the wire straight back in the headliner instead of along the threshold.
    https://youtu.be/igsOmzw6YO8
