Wiring External Button to Unlock Doors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EatSleepTacos, Jun 14, 2015.
  1. Jun 14, 2015 at 10:25 AM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    So here's what I'm thinking. Rather that hiding a non-programmed key on the exterior of the truck in case of accidentally locking the keys inside, I was thinking of wiring an extremely well hidden button that would unlock the door(s). My thought process is that a thief isn't going to be looking for a button, and I'd only use it as a last ditch effort so no one would happen to see it and break into my truck at a later date. I feel like it'd be as simple as running a fused line from battery to hidden switch, and other side to an unknown wire. Any input you have would be appreciated. I know a lot of you might disagree with this method, so I'd prefer only constructive criticism and actual electrical help. Thank you.
    Edit: Picture of Stewie for attention
    Here's a write up on it:
    https://www.tacomaworld.com/threads...rnal-buttons-to-lock-and-unlock-doors.427455/
  2. Jun 14, 2015 at 10:42 AM
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    If your wanted to get REALLY crazy you could try to install a keypad lock like on the Fords, sorry, I cant help with the wiring.
  3. Jun 14, 2015 at 10:46 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That thought crossed my mind, but those don't look as minimal as I'd like and are way more expensive than some wire and connectors. Appreciate the input though!
  4. Jun 14, 2015 at 10:50 AM
    jad3d
    jad3d Well-Known Member
    2010 BSP XR
    Get a monetary switch/button.
    Run a fused +12 to one terminal on the button/switch.
    Run the other terminal from the switch/button to the unlock pulse wire.
    The wires should be able to be found at the fuse block behind the driver side dash panel. I don't know/have the schematics for anything other than a 2010.
  5. Jun 14, 2015 at 11:29 AM
    Clearwater Bill
    Billy
    Largo Florida
    Ever seen a vehicle with shaved door handles? They use something called door poppers. Google that. You'll find a bunch of kits you don't really need for what you are wanting, but I bet a bit of poking around will find replacement parts or wiring.
  6. Jun 14, 2015 at 11:48 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    "Expert Reply:
    According to Pop and Lock, the power lock and unlock wires for your 2013 Toyota Tacoma Access Cab should be located in the same area as the Double Cab models. You will want to look for a blue/black wire (lock) and a blue/red wire (unlock) behind the driver side kick panel. You will see many wires behind the kick panel, so locating these wires can be tricky."
    I found this while digging around. So all I'd have to do is tap into the blue/red wire?
  7. Jun 14, 2015 at 11:53 AM
    B14k3
    B14k3 Member
    Houston
    2014 MGM TRD Sport
  8. Jun 14, 2015 at 11:54 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I can't speak as to the wiring, but on the ambulances we have a hidden switch behind the grille, the switch is a momentary 'on' switch covered in rubber, press it once to unlock the doors. Pressing it again does nothing. It's a useful idea, for sure, and quite doable if you put the legwork into figuring out the wiring.
    The ambulance manufacturer is Horton, maybe some time on their site looking at schematics will give you an idea of what you are looking at. Obviously the final wiring would be different between the Ford chassis and the Toyota but the basic idea would be the same.
  9. Jun 14, 2015 at 12:02 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I didn't even think of hiding the key pad. I'm definitely going to look into that.
    Thanks for the info! That's actually where I got the idea. My girlfriend mentioned it one time as she's a volunteer EMT, and I thought that was a brilliant idea.
  10. Jun 14, 2015 at 1:01 PM
    mcnkl
    mcnkl Active Member
    calgary,alberta
    I would use a switch one side would go to ground and the other to the disarm wire located in the drivers kick panel door harness. The disarm wire uses a negative trigger one pulse opens the drivers door a second pulse unlocks all doors.
  11. Jun 14, 2015 at 2:29 PM
    jad3d
    2010 BSP XR
    Correct. It's been years since I installed my aftermarket system but I use the lock/unlock wires (not the factory arm/disarm).
  12. Jun 14, 2015 at 4:42 PM
    mcnkl
    mcnkl Active Member
    calgary,alberta
    Those wires for the pop and lock blue/blk and blue/red are a five wire set up. Much easier to use a negative trigger.
    Siblue likes this.
  13. Jun 15, 2015 at 3:21 AM
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    I think you mean 1L right now IL? I also need some help with wiring for smart key and swap bench seats to 4runner power seats...sending you a PM.
  14. Jun 15, 2015 at 8:49 AM
    mjackson92rs
    mjackson92rs Well-Known Member
    SE PA
    '15 TRD Sport
    subbed. OP be sure to post if you were successful or not.
    BTW, maybe try a temporary setup to test if the momentary to ground will unlock the doors? Should just be able to jumper the correct pin to ground.
  15. Jun 15, 2015 at 9:22 AM
    owen06
    owen06 Well-Known Member
    Hinesville, GA
    16 DCSB 4x4 Red
    Sub'd
  16. Jun 16, 2015 at 6:04 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    sub'd for interest. Sounds like a great idea
  17. Jun 16, 2015 at 6:16 PM
    Redsyota
    Redsyota Well-Known Member
    Denver
    15' SPORT 6 SPEED ACLB MGM
    Some of the things...
    Unrelated but... Your front plate is awesome!
    EatSleepTacos[OP] likes this.
  18. Jun 16, 2015 at 6:17 PM
    medic2230
    Murph
    Bama! Roll Tide
    Sub'd for the outcome. This is getting interesting. :popcorn:
  19. Jun 16, 2015 at 6:18 PM
    medic2230
    Murph
    Bama! Roll Tide
    I noticed that too. lol
  20. Jun 16, 2015 at 6:22 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Agreed on plate. Lmao
