Wiring diagram for backup camera
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mtnc, Jun 10, 2021.
  1. Jun 10, 2021 at 7:11 AM
    mtnc
    mtnc [OP] Member
    2020 Tacoma Off Road DCSB 4x4
    I know there's a kit I can buy to make the backup camera viewable anytime, but it seems like I could do it with simply supplying or removing a ground (normally done by putting the truck in reverse) to make it happen. I only want to use it temporarily so I can get the dang truck all the way in a parking space without the rear bumper hanging over the line. I may eventually subscribe to TIS but I wondered if I could just get a copy of the wiring diagram here since that's all I really need. So, anyone?
  2. Jun 10, 2021 at 8:17 AM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    Even if you have a wiring diagram, you're still going to have to do some splicing of wiring, plus adding a switch. I installed the simple Anytime Backup Camera harness ($46.63 delivered), plus the switch. That seems to be the practical way of doing it.
  3. Jun 10, 2021 at 12:01 PM
    caribe makaira
    Caribbean, Puerto Rico
    The camera has juice with head unit ON. Head Unit controls the camera Feed/video when reverse is selected.
    Placing a switch to supply the "reverse" signal to the Head Unit would be a solution.
    stftaco likes this.
  4. Jun 10, 2021 at 12:02 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    If that's all you want to do with it, why not just put the truck in reverse to check? That's what I do.
    suaveflooder likes this.
  5. Jun 10, 2021 at 12:38 PM
    mtnc
    mtnc [OP] Member
    That's what I do now. Just looking for a little better option.
  6. Jun 10, 2021 at 12:48 PM
    RedWings44
    Michigan
    Personally, I wouldn't screw with modding the wiring or anything unless I was installing the front camera as well. Too easy to screw something up and void any warranties or cause other issues.
  7. Jun 10, 2021 at 12:57 PM
    YouKnowNB
    YouKnowNB Well-Known Member
    Nick
    Black TRD Offroad 4x4
    Dont fix it if it isnt broken. If you want some help possibly breaking it then run a switch inline between the reverse wire at the shifter may activate the camera input and display, if not you may be able to activate it at the radio. I dont advise it but here is your “easier” option
  8. Jun 10, 2021 at 12:57 PM
    caribe makaira
    Reverse input (+) to pin 28 on connector R48 on Head Unit
    Pin 15 is fused IGN to Head Unit.
    Tlaloc1916 likes this.
  9. Jun 10, 2021 at 1:13 PM
    caribe makaira
  10. Mar 15, 2023 at 1:32 PM
    Tlaloc1916
    Tlaloc1916 Well-Known Member
    Magnolia Tejas
    2021 SRish 4x4
    What pins are for the backup camera?
    Davix581 likes this.
  11. Mar 15, 2023 at 1:34 PM
    caribe makaira
    Different connector (R49):
    Tlaloc1916[QUOTED] likes this.
  12. Mar 15, 2023 at 1:37 PM
    Tlaloc1916
    Magnolia Tejas
    2021 SRish 4x4
    Thank you brother!:thumbsup:
  13. Jun 9, 2023 at 2:26 PM
    Davix581
    Davix581 New Member
    Davix
    I have problems installing steering wheel in the TACOMA 2020 plug its diferent, change the radio to an Androit , someone help me
