Wiring Diagram for AC System
Discussion in '2nd Gen. Tacomas (2005-2015)' started by connor016, Sep 6, 2016.
  1. Sep 6, 2016 at 5:18 PM
    connor016
    connor016 [OP] Well-Known Member
    Goleta, CA
    2013 Tacoma TRD Off-Road Double Cab
    Does anyone have the wiring diagram for the AC system? Specifically I need to know the connection to the ac compressor. A mechanic butchered my AC repair and I am out of the state so basically they cut the wiring from the plug that goes to the compressor pick up sensor and magnetic clutch and lost the other end that bolts to the top of the compressor. Now I need to determine the wiring from the plug that goes to the compressor with black, orange, and green wires that goes to the plug going to the wiring harness that has a white, red/white, and purple wire. I attached a pic of the connector that is missing with a red arrow and another pic of what is remaining of my plug.
  2. Sep 6, 2016 at 5:27 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
  3. Sep 6, 2016 at 5:32 PM
    Drivesector
    TRD sport
  4. Sep 6, 2016 at 5:37 PM
    Drivesector
    TRD sport
  5. Sep 7, 2016 at 2:25 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This what the wiring diagram shows for the 2012 and your should be the same.
    Purple is the magnetic clutch.
    Red with white stripe is from the rotation sensor.
    White is the common.
  6. Sep 7, 2016 at 5:13 AM
    connor016
    Goleta, CA
    Thanks you guys are a life saver! Looks like the connections will be purple to orange, red/white to green, and white to black. Now time to try to rig up a temporary plug to go to the harness.
  7. Sep 7, 2016 at 3:50 PM
    connor016
    Goleta, CA
    Got everything installed, wired up, and charged and AC is back on and working. Thanks for all the help!
  8. Sep 7, 2016 at 3:59 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    :thumbsup: Good job glad you got it.
