Wiring/Connector Pin-out for Cruise Control Actuator 88260-0W010 (Need 96-99 Tacoma Wiring Manual)
Discussion in '1st Gen. Tacomas (1995-2004)' started by RattleTractor, Mar 26, 2021.
  1. Mar 26, 2021 at 7:12 AM
    RattleTractor
    RattleTractor [OP] Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Anyone have the pin-out diagram/key for cruise control actuator 88260-0W010? Looks like it was used in Tacoma/4Runner/T100 vehicles from 96-99.
    I decided that I actually need to tackle the cruise control in my truck- specifically figure out how to make it work again. Here's the situation:
    I have a 2004 Tacoma with a 1KZ-TE swapped into it. When the shop did the swap for the previous owners in 2012, they also replaced the original cruise control actuator with the other, self-contained type (pn 88260-0W010).
    You can see it in the image below, unplugged and hiding behind the intake pipe.
    But the shop connected it to the steering wheel control switch all wonky (up was cancel, down was accelerate, etc.) and wired the on/off to a separate aftermarket push-button switch. When I tore out all the accessory wiring and replaced it with an RTMR & switch panel, I inadvertently also removed the cruise on/off switch & wiring as well.
    Long story there, but basically it worked at one point and I need to make it work again.
    The 2004 factory wiring manual I own isn't useful for troubleshooting this because my truck has a different cruise control actuator and ECU than the factory truck. provides a good, quick-and-dirty explanation for what that cruise actuator is and how to wire it (including the wiring diagram pasted below), but there's no pin-out diagram for the connector accompanying it.
    I think I only need the pin-out diagram so I can troubleshoot & reconnect the cruise actuator to the truck again.
    351916d1578657409-cruise-control-swap-4r_81245feb3bf3f04ceb3f6bba3b6eb5d372b2e49a.jpg
  2. Mar 26, 2021 at 8:40 AM
    RattleTractor
    Harry
    VT
  3. Mar 26, 2021 at 8:50 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I can help when I get home. I have the paper 1998 electrical FSM.
  4. Mar 26, 2021 at 9:55 AM
    RattleTractor
    Harry
    VT
    Amazing. Thank you!
