Wiring a single led pod for reverse light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GreyDongle, Mar 19, 2020.
  1. Mar 19, 2020 at 4:27 PM
    GreyDongle
    GreyDongle [OP] Active Member
    2008 Indigo Ink PreRunner SR5
    I have a single 15watt pod I'd like to add as a reverse light as the tint on the windows and my camper make it hard to see. Im wondering if 15 watts is too much to splice into the stock reverse lights, or if it is if it's possible to take it to the 7pin trailer harness thanks for any help
  2. Mar 19, 2020 at 5:04 PM
    redtaco2007
    redtaco2007 Well-Known Member
    2007 Red Tacoma - TRD Off Road DCSB
    not much yet!
    We bought a trailer harness and wired them up on my buddies truck to the reverse pin output. Worked great. Has them mounted on his Salter for when he is out blowing and backing up across lots
  3. Mar 19, 2020 at 5:29 PM
    GreyDongle
    Im thinking of splicing into the wire behind the trailer connector rather than plugging into it, I'm just curious how much amperage that harness can handle
  4. Mar 19, 2020 at 5:37 PM
    Muddinfun
    Muddinfun Well-Known Member
    Put some decent bulbs in it and see if you still need more light. Deauto LEDs or HIRs.
  5. Mar 19, 2020 at 5:39 PM
    redtaco2007
    not much yet!
    It would be a bit of a pain, but, you could get a water proof relay and mount it back there. Use the reverse from the trailer harness as a trigger wire and run a new lead (with inline fuse) from the battery and use that to power the light
    deanosaurus and Shaggs like this.
  6. Mar 19, 2020 at 5:47 PM
    GreyDongle
    Ive got led tail lights already way too dim at night
  7. Mar 19, 2020 at 5:59 PM
    Muddinfun
    You mean reverse lights? What brand?
  8. Mar 19, 2020 at 6:02 PM
    GreyDongle
    I meant tail light assembly, it's a sealed unit, not sure the brand
  9. Mar 19, 2020 at 6:05 PM
    Muddinfun
    So, it's some aftermarket light with non replaceable reverse light bulbs?
    FWIW, I have OEM tail lights with Deauto LED reverse lights and there's plenty of light when in reverse.
  10. Mar 19, 2020 at 6:20 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I'd go this route. Really simple to wire and no need to worry about overloading the existing wires since the draw will be on the new wire from the battery.
    Shaggs likes this.
  11. Mar 19, 2020 at 6:23 PM
    caribe makaira
    Caribbean, Puerto Rico
    Hardscrabble likes this.
  12. Mar 19, 2020 at 6:29 PM
    Muddinfun
    Assuming the 7 way trailer connector is made to power 2 whatever reverse lights on a trailer, 15 watts is nothing, and if you already have LED reverse lights in the tail lights, a 15 watt pod is really nothing.
  13. Mar 20, 2020 at 1:30 PM
    Slum Lord
    Slum Lord Well-Known Member
    My vote...wire it right to the stock circuit. No relay needed for that small of draw. You are hovering at 1 amp more.
    Best place is to unplug the trailer connector and tap in on the short harness between the trailer plug and where it goes to the frame rail connector location.
    You can put it on the bench, solder or splice it, then dress it with tape and jam it back in there without F'n with the vehicle harness itself.
    Muddinfun likes this.
  14. Mar 20, 2020 at 1:37 PM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Tapped mine right into the reverse light wiring
    Killawhalegun, Dr.Lou and Skyway like this.
  15. Mar 20, 2020 at 3:02 PM
    caribe makaira
    Just because you could doesn't mean you should...
    deanosaurus, Larzzzz and 08TacoTrD like this.
  16. Mar 20, 2020 at 3:40 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    That's quite a list.
    As for the light, it's just over an amp load on the circuit. As @caribe makaira pointed out, the circuit feeding the back up lights already has a lot of stuff on it.
  17. Mar 21, 2020 at 9:00 AM
    Sxottie
    Sxottie Wrenching is therapy, right??
    Scott
    Mystic, CT
    2021 TRD Sport Double Cab
    Tonneau hard cover, mud guards, yellow fog light tint, redline hood lift kit, remote tailgate lock, bed lights, window tint, invisible bra, TRD wheel cap decals, tailgate letters, blackout badge kit, LED cab lighting kit, bed hooks, red caliper paint.
    I installed these backup bulbs. Problem solved.
    https://www.amazon.com/dp/B073PZ86GR/ref=cm_sw_r_other_taa_BMJDEbVCYBHBE
  18. Mar 26, 2020 at 4:13 PM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    Details?
  19. Mar 26, 2020 at 4:14 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
  20. Mar 26, 2020 at 4:26 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This really eliminates the need to hack up a bumper to mount pods:
    https://www.tacomaworld.com/threads/gy6-35-hir-921-reverse-light-upgrade-vs-high-power-leds.474996/
    But in short an additional 15w is fine on the stock circuit. The stock reverse lights draw 38w (18w x 2), my HIRs are drawing 70w (35w x 2). Note that the circuit is shared with the tow circuit, so anything you add reduces the capacity of what is available to the trailer should you tow one.
