Wiring 2 relays to 1 switch?
Discussion in 'Lighting' started by spartanhockey6, Jan 22, 2014.
  1. Jan 22, 2014 at 11:27 AM
    spartanhockey6
    spartanhockey6 [OP] My truck rattles, A LOT.
    Trevor
    Talent, OR
    2010 White Trd Sport
    Money Pit
    Hey guys, I have a quick question about my current wiring setup for my 4 55w hella 500's.
    Right now i have 2 lights> 1 relay>1 switch and then the other 2 lights> 1 relay> 1 switch.
    I currently have the two switches unsecured in the coin/ashtray under the factory switches/blanks. (really annoying)
    What I would like is to use one of the factory blank spots for a switch to power on/off all 4 lights instead of finding a place to mount two seperate switches.
    I've tried doing some research but am not 100% confident in my electrical knowledge lol. Would it be as simple as taking the power wire from relay (A) to the switch (A) and splicing it into the power wire from relay (B) to switch (B)? and then just connecting relay (B) to the new switch?
    Any help is much appreciated. Thanks!
  2. Jan 22, 2014 at 12:09 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    Absolutely, that's one of the great things about using relays. You can have 1 switch trip multiple relays
  3. Jan 22, 2014 at 12:16 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    you need to add up your draw of the relays coil and make sure that your new switch will carry the load. If they're small relays this should be a non issue, but when you start adding multiple items, a 5 second check could save you a ton of time and money later.
    If you have only two relays, you "might" be in the neighborhood of an amp. and your switch "should" carry 5
  4. Jan 22, 2014 at 12:19 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If the relay is rated, why not run all 4 lights off the one relay?
    Tie all the positives on the lights together and do the same with the negatives. Run a single pair of wires to the relay. 1 switch, 1 relay and 4 lights.
    Just need to find out how many watts the relay will carry.
  5. Jan 22, 2014 at 4:42 PM
    spartanhockey6
    Trevor
    Talent, OR
    Money Pit
    Thanks for the info guys!
    The two relays i have came with the lights from Hella.
    Both relays are 12V/15A and are probably the size of a 1" cube so they're pretty tiny.
    Since i already have the relays mounted under the hood i'll probably just connect the two power wires from the relays to the one switch.
    What kinda switch do you guys think i should get? 20A? I don't believe my relays are that big and pull enough power so a 20A switch should be good to go?
    Thanks again.
  6. Jan 22, 2014 at 10:26 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Relays require less than one amp of current to activate. I would run whatever switch you have laying around. I don't think you'll find a automotive switch that is rated less than 3 amps.
