Wireless Carplay and GPS antenna clarification
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MillbrookMike, Feb 26, 2021.
  1. Feb 26, 2021 at 2:43 PM
    MillbrookMike
    MillbrookMike [OP] Well-Known Member
    New York State's Hudson Valley region
    2018 Tacoma TRD Sport
    Hi all,
    I'm getting ready to install a Kenwood Excelon Reference HU that has wireless Carplay. Can anyone who's done a similar install clarify something for me? I've read that with the iDatalink ACC-SAT-TO2 Adapter, I can retain the use of the factory GPS antenna. Other comments I've read say that in order to use wireless Carplay, I can't do that - I must use the supplied GPS antenna provided by Kenwood with the HU. Which is true?
    Thanks!
  2. Feb 26, 2021 at 2:52 PM
    tacovagon
    tacovagon Well-Known Member
    Dan
    Oceanside CA
    2016 SW SR5 DCLB 4x4
    ARB Locker 5100s w OME 887s OME EL095R Camburg BJ UCAs
    I can't comment on your Kenwood but my Pioneer which has wireless CarPlay required a GPS antenna to be installed under the dash. I didn't understand what it was for as the Pioneer didn't have navigation. I was told it was required though and it was stuck to the inside of the dash. Maybe it functions as the WiFi antenna?
  3. Feb 26, 2021 at 3:01 PM
    MillbrookMike
    Thanks. That’s part of what has me confused. They’re both GPS antennas and whether or not I use the factory GPS antenna or the one supplied with the HU, they both plug into the same spot on the back of the unit. I don’t understand why CarPlay would need the HU antenna installed in order to function wirelessly.
  4. Feb 26, 2021 at 3:45 PM
    tacovagon
    Dan
    Oceanside CA
    Unless it's a WiFi antenna???
  5. Feb 26, 2021 at 3:46 PM
    erikarthur
    erikarthur Well-Known Member
    Erik
    WI
    I also have a pioneer unit and I used the iDatalink adapter to connect to the factory gps antenna. Wireless carplay works fine for me with that adapter. I have a WC6600NEX.
    Sofasloth likes this.
  6. Feb 26, 2021 at 3:54 PM
    MillbrookMike
    Thanks. That's encouraging. The user manual for the Kenwood HU says to use the supplied antenna and that using other antennas can cause a drop in positioning accuracy. I wonder why the factory GPS wouldn't be accurate. Maybe I'll go ahead and install the factory GPS given that I already have the adapter, and see how that goes. If I notice any problems, I'll switch to the Kenwood antenna.
    Has anyone tried this with a Kenwood unit?
  7. Feb 26, 2021 at 4:04 PM
    mjc251
    mjc251 Well-Known Member
    Mark
    2022 TRD Off-Road DCSB
    I used an adapter for the factory GPS antenna from maestro on my Kenwood. No issues.
    However, you might get slightly better (more accurate) signal with the white banded kenwood GPS antenna.
  8. Feb 26, 2021 at 5:37 PM
    MillbrookMike
    Great! Thanks. Did you try the Kenwood, or have you just stayed with the factory antenna?
  9. Feb 26, 2021 at 6:12 PM
    Shellshock
    Iowa
    I’ve got a kenwood dnx997xr and i used the iDatalink ACC-SAT-TO2 adapter. Wireless CarPlay just requires GPS (either factory or aftermarket)
    Originally used the supplied antenna with the unit until I found out about the adapter to use the factory one.
  10. Feb 26, 2021 at 6:14 PM
    MillbrookMike
  11. Feb 26, 2021 at 6:16 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I'm really debating going aftermarket. Are you all happy with your choices?
  12. Feb 26, 2021 at 6:18 PM
    Shellshock
    Iowa
    Yep. Just be sure to get one with the maestro so that you dont lose any functionality like the in cluster display
    OMGitsme[QUOTED] likes this.
  13. Feb 26, 2021 at 6:21 PM
    tacovagon
    Dan
    Oceanside CA
    My Pioneer w/ Maestro is miles ahead of the Entune garbage it replaced.
    Sofasloth and OMGitsme[QUOTED] like this.
  14. Feb 26, 2021 at 6:42 PM
    OMGitsme
    Sold
    Which Pioneer did you install?
  15. Feb 26, 2021 at 6:51 PM
    tacovagon
    Dan
    Oceanside CA
    W4500NEX
  16. Feb 26, 2021 at 6:57 PM
    cosmic65charlie
    cosmic65charlie Consumer of good times.
    Colorado
    2019 TRD OR AC
    Offroad stuff, Audio stuff, Cooler full of beer
    I have a Kenwood DMX906S and am using the factory antenna with wireless carplay. No issues and no need for the Kenwood antenna.
  17. Feb 26, 2021 at 7:10 PM
    mjc251
    Mark
    I just stuck with it. I haven’t any issues and it seems accurate enough for me so I never went back in to swap out.
  18. Feb 26, 2021 at 7:13 PM
    mjc251
    Mark
    Kenwood Excelon all the way.
    Excelon DDX-9907XR in my commuter car. And an Excelon DNR-1007XR in the tacoma. Both are awesome!
  19. Feb 26, 2021 at 7:14 PM
    soggyBottom
    soggyBottom Well-Known Member
    Can someone post a picture of this Kenwood antenna? Preferably next to a ruler. It doesn't make sense that they would have the antenna under the dash. GPS is 1.5GHz so it will go through the dash but I still find it odd.
    Another possibility is synchronization signal from cell towers. Without this, GPS usually takes about a min to get good accuracy. Using the external timing signal brings it down to something like 100nS.
  20. Feb 26, 2021 at 8:50 PM
    Mortimer
    Mortimer Active Member
    ‘19 Off Road
    I used the Kenwood antenna as per instructions. Once you go CarPlay you're using your phone for GPS anyway so I haven't been concerned about GPS reception. I think I may have never even used the native nav on the Kenwood. The thing is basically a screen for your phone at that point, other than tuning into a game on the radio now and again.
    Regarding quality my dmx906s reboots itself about once an hour, so it's an annoyance only on long trips. You can tell it's about to do it when the audio from your phone gets choppy.
