Wireless Android Auto Experiences?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by willconltd, Feb 10, 2023.
  1. Feb 10, 2023 at 8:02 AM
    willconltd
    willconltd [OP] Well-Known Member
    Orlando, Florida
    I have been seeing more and more mentions of products, and I recently saw someone posting about the Motorola options.
    Do you have any recommendations, or is there already a thread that details this that I missed in my searches?
    I've heard that some are battery drains, and some are temperamental on the connection.
    I have a SamsungS22 and a 2020 taco with AA that I have used since day 1 and I'm pretty happy with it. I have never used the radio or the other stuff, its just google maps and spotify for me.
    Let me know what you think, I appreciate the help!
    Motorolla kit:
    https://www.amazon.com/gp/product/B09PQ95GY4
    Aw9d says he has this one and it works pretty good:
    https://www.amazon.com/CARSIFI-Wireless-Android-Adapter-Units/dp/B0BFX9KJ44
    Drivelink unit that someone said worked on a 2022 highlander.
    https://www.amazon.com/gp/product/B0B5ZK4NBZ
    I see the garlin kits: (garmin name ripoff?)
    https://www.amazon.com/Wireless-Android-Adapter-Direct-Factory/dp/B0BGL6HC74
    https://www.amazon.com/CarlinKit-A2A-Android-Auto-Wireless/dp/B0BDRTWMZ5
  2. Feb 10, 2023 at 8:10 AM
    Aw9d
    Aw9d That one guy
    I have the Motorola one and another called carsifi.
    The carsifi one work's better but really both are pretty good.
    willconltd[OP] likes this.
  3. Feb 10, 2023 at 8:16 AM
    willconltd
    Orlando, Florida
    Do you have issues with it disconnecting or draining your phone batteries?
  4. Feb 10, 2023 at 8:50 AM
    Gerberdude
    Gerberdude Well-Known Member
    Alex
    '22 SR5 DCLB
    I have a Pixel 3 and it never connected wired, so I had to buy the Motorola dongle. I like it a lot given the alternative is not having Android Auto. So I can't say how it compares to wired.
    I had some connection issues at the VERY beginning, just trying to get it to connect. I found that the solution for me was having it plugged in before I start the truck and letting the phone connect right away. Then just leave it alone. It doesn't tolerate hot-swapping. If I have an iOS device plugged in and then want to swap in the dongle mid-drive that's a no-go. Other than those caveats it's been rock solid.
    No battery issues but I also have an older phone, so it doesn't have the best battery life to begin with. The phone doesn't get hot or anything like that.
    I know when I bought it, Amazon had none in stock and I found a good deal at Best Buy for less than the amazon price anyway.
  5. Feb 10, 2023 at 9:20 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I have the Carsifi wireless Android auto adapter.
    I really like it. It worked well with my oneplus 7pro works fine with my Galaxy A53 too.
    I ordered it originally from Kickstart on November 2021 didn't get it until April 2022. It was supposed to be delivered in February 2020.
    I really like it and now that I have it I've canceled all the paid music services including XM.
    I rarely use the FM radio no. It connects up in around a minute or less. Not plugging in is really convenient for shorter trips.
    I mostly use Google maps and use Plexamp to stream my music collection from my plex server at home
  6. Feb 13, 2023 at 8:43 AM
    willconltd
    Orlando, Florida
    I purchased the Motorola unit off Amazon as I had a credit. It works pretty good after only a couple days.
    I think the next mod will be to remove the USB plug from the center console and route it to the glove box so I don't have this thing dangling all the time.
    Ryed380 and Gerberdude like this.
  7. Feb 13, 2023 at 8:54 AM
    willconltd
    Orlando, Florida
    Does that run off your existing PLEX server, or is it a different unit. I have never even attempted to set it up.
  8. Feb 13, 2023 at 1:50 PM
    oldsoldier181
    oldsoldier181 Well-Known Member
    Bill
    2021 TRD Sport Wind Chill Pearl
    None yet
    I have AA wireless and a Pixel 5. Yes, it does drain the battery, and it can get warm (the phone). I dont plug mine in if I am driving to/from work, as its not really necessary (45 minutes each way). I have no issues with it losing connectivity. Sometimes, it takes a little longer to connect though.
  9. Feb 13, 2023 at 2:02 PM
    Firn
    Firn Well-Known Member
    White OR
    I have the Motorola unit and like it.
    Generally short-ish drives (~30min) for me and no issues, on the one longer (4hr) drive I recently took it did disconnect twice. I can't say if that is normal or not.
  10. Feb 13, 2023 at 2:21 PM
    NoodleNinja
    NoodleNinja Member
    I have the motorola unit since October 2022. Never had any issues with it disconnecting. I will say that android auto wired or wireless does have the random hiccups when playing music where it'll pause for a millisecond so that doesn't going away once you have the wireless. After looking through forums and android auto issues.. appears to be an android auto thing?
    Anyhow I velcroed the back and just stick the unit right above the charging pad so it's not dangling in the way. I don't notice any huge battery drain when using it. I can put my phone on the wireless charger and it'll slowly still charge. I have Galaxy fold 4 as reference.
    Obviously only downside is that if you ever switch to apple, you're outa luck with the motorola one.
  11. Feb 13, 2023 at 7:41 PM
    Waterloo Wonder
    Waterloo Wonder Waterloo Wonder -
    Forrest
    New Hampshire
    21 Access Cab - Army Green,
  12. Feb 13, 2023 at 8:26 PM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Firn likes this.
  13. Feb 15, 2023 at 12:51 PM
    Taco_mike73
    York, PA
    Yeah it's pulling music off my plex server at home. I have a lot of mp3 files, ripped cd, dvds, and even recorded TV on it. We used plex at home as an OTA dvr.
    I've never tried to play video on the radio screen. I mostly use the plexamp app which requires a plex pass subscription to get access to. Of course I got a lifetime plex pass way Back in 2018 for like $90. It's well paid for itself. It's what I use to most to watch TV and listen to music.
    Here are a few screen shots of what the app looks like on phone and the truck. Screenshot_20230215_153741_Plexamp.jpg 20230215_154403.jpg[/QUOTE]
  14. Feb 15, 2023 at 1:22 PM
    Omegastu
    Omegastu Well-Known Member
    Mid Tenn
    2021 Cement TRD Sport DCSB
    I have this one....
    https://www.amazon.com/AAWireless-2...mzn1.fos.18ed3cb5-28d5-4975-8bc7-93deae8f9840
    Haven't noticed any crazy battery drain. Takes about 30 seconds or less to start up and works great.
    I do have one question. Maybe others are facing this, even when I just plugged my phone in my screen just lights up at random times and stays lit up. Anyone have this issue and know how to fix it?
  15. Feb 15, 2023 at 1:42 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I sold my Taco, and have an19' Ram. It has AA, but requires being plugged in to work. I got annoyed and bought the Motorola dongle.
    Was a tad hard to get hooked up but works great. It's connected within 30 seconds of starting the truck, and no battery drain other then what would happen if playing music and using waze on just the phone.
  16. Feb 15, 2023 at 1:44 PM
    WhiteTaco20
    WhiteTaco20 Well-Known Member
    Perkasie, PA
    SW 2020 TRD Sport DCSB
    I have the carlinkit one for sale
  17. Feb 15, 2023 at 3:19 PM
    Ryed380
    Ryed380 Member
    2020 Tacoma OR Smurf Blue
    I'm looking at the CarlinKit 4.0 for android auto and Carplay for the wife's phone.
  18. Feb 15, 2023 at 7:29 PM
    RicerRabbit
    RicerRabbit Well-Known Ricer
    '22 White TRD Off-Road DCSB Manual | '03 Lancer Evolution
    Itz JDM tyte, yo!
    I have the MA1.
    It disconnects at certain spots. Otherwise it works fine.
