Wire harness replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by K00kie, Oct 25, 2023.
  1. Oct 25, 2023 at 12:36 PM
    K00kie
    K00kie [OP] Member
    Central Ohio
    2008 Tacoma
    The dealer said this 82164-04780
    * wire harness needs to be replaced
    * it will be $$$ to do the job.
    * The bed must come off to do the job.
    ? Has anyone done this
    ? A task of unplugging then plugging the new one in
    ? Other than swapping out the wires is there any other things like a computer to do the job
    ? Never seeing the bottom of a toy, instead of taking the bed all the way off, might the bolts be loosened and the bed lifted up to get to the connections
    ? Any pics of the bottom of a tacoma that shows the locations of the wires
    2008 Tacoma Vin 5TEPX42N38Z566384
    Thanks
  2. Oct 25, 2023 at 1:14 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    As someone who has replaced a few frame harnesses, pulling the bed makes life much easier.
  3. Oct 25, 2023 at 1:42 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What kind of issue are you having that they want to replace the harness for?
    Most wiring harnesses can be repaired pretty easily.
  4. Oct 25, 2023 at 2:02 PM
    K00kie
    K00kie [OP] Member
    Central Ohio
    2008 Tacoma
    Toy story
    MISC. DIAGNOSIS (SEE STORY)
    MISC. DIAGNOSIS (SEE STORY) ~|~ABS LIGHT ON. ~|~TOYOTA DIAGNOSTIC TEST ALL SYSTEMS. SEE PRINT OUT. STARTED TO TEST SYSTEMS AND FOUND WIRING UNDER FRONT SEAT IS EAT UP. TO START WITH AND ONLY TO START WIRING HARNESS WILL NEED REPLACE. THE BED AND REAR BUMPER WILL NEED REMOVE. BUT MAY HAVE MORE PROBLEM ~|~TOYOTA DIAGNOSTIC TEST ALL SYSTEMS. SEE PRINT OUT. STARTED TO TEST SYSTEMS AND FOUND WIRING UNDER FRONT SEAT IS EAT UP. TO START WITH AND ONLY TO START WIRING HARNESS WILL NEED REPLACE. THE BED AND REAR BUMPER WILL NEED REMOVE. BUT MAY HAVE MORE PROBLEM
    Removing bed link
    https://www.google.com/search?q=rem...ate=ive&vld=cid:3adb02f8,vid:9N2UKtoDBf4,st:0
  5. Oct 25, 2023 at 3:38 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'd just find and repair the broken wires, I'd never replace an entire harness for a few broken wires. Not to mention $500+ just for the harness :eek:
    Dealerships usually refuse to repair harnesses, they will only replace them so you would need to go to an independent shop or do it yourself to go that route.
  6. Oct 25, 2023 at 7:32 PM
    K00kie
    K00kie [OP] Member
    Central Ohio
    2008 Tacoma
    Guessing to find and repair any wires there would be a need for a circuit tester then you would need to find a way to test wires one by one from front to back .. hmmm
    Then if the bad spot was under the bed it would still have to come off to get to it.
    I found some pics of toys with the bed off to get an idea what is there
    https://jkpuptop.blogspot.com/2023/10/wire-harnass.html
    My notes
    The video of how to take the bed off is step by step perfect.. I know I could do that..
    I have the info I need now, thanks u guys :)
  7. Oct 25, 2023 at 7:39 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Well according to the notes you posted what the dealer gave you the issue is under the front seat so it would make sense to start looking in that area (that is if they aren't BSing you).
  8. Oct 25, 2023 at 7:55 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Definitely start with that front seat area that they mentioned. You don't need to replace the whole wire per se.
    Long ago in college I bought an Oldsmobile that turned out to get awful fuel mileage. Turned out a section of wiring got melted together and it had a ton of open circuits, false readings, etc.
    Found another car at the boneyard and cut out the section I needed, since the spot was so close to the end connections under the hood I just spliced one at a time and used the spliced wire's connector to the engine sensors etc. Ran me about $40 tops and a little time.
    Oh, lend me your comb?
  9. Oct 25, 2023 at 8:27 PM
    caribe makaira
    Caribbean, Puerto Rico
    Towing (if)
    Rear Turn/Stop/Reverse Lamps
    Tail (tags & Rear Lamps)
    Locking Diff (if)
    Fuel Pump/Meter
    ABS
    K00kie[QUOTED][OP] likes this.
  10. Oct 26, 2023 at 8:14 AM
    K00kie
    K00kie [OP] Member
    Central Ohio
    2008 Tacoma
    Is this the wiring diagram for my 2008 Tacoma?
    One last thought
    Had the frame replaced at 159,530 miles last check 164,715 miles .. about 5000 miles since the frame was replaced and I do not drive on salted or snowy roads if my liberty is working.. Should be very little rust to deal with they replaced clips .. n connections as well as the frame.
  11. Oct 26, 2023 at 8:23 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I’d start with a visual inspection and photos of anything that looks suspect. That will help others opine on the scope.
    I don’t trust the dealership on this one based on the language. Sounds like they only want to help if it’s a big enough job to make sense for them. Which is fair but doesn’t mean it’s for sure a big job. It could be one or two small spots to patch and easier to leave the rest intact as-is.
    depends on the extent and severity of any damage. Rodents are one thing, flood / corrosion is another and abrasion damage is a third. One spot vs many spots vs no visible spots is also part of it.
    it’s tough to know without doing a full replacement whether or not it’s worthwhile to do a full replacement.
    Also, $500 is a lot to spend. But this isn’t an easy part to find clean in a junk yard or online.
    I definitely wouldn’t immediately give this to the dealer. I’d at least try to get a better understanding of the scope and try some DIY first.
  12. Oct 26, 2023 at 11:05 AM
    K00kie
    K00kie [OP] Member
    Central Ohio
    2008 Tacoma
  13. Oct 27, 2023 at 9:59 AM
    K00kie
    K00kie [OP] Member
    Central Ohio
    2008 Tacoma
    The dealer said there is a problem with the wires under the seat I could see nothing so next advice remove the seat.. 4 bolts and unplug the wires
    IF a wire replacement happens
    Looking on line
    https://www.toyotapartsdeal.com/oem/toyota~wire~frame~82164-04780.html?vin=&make=Toyota&model=Tacoma&year=2008&submodel=&extra1=&extra2=&filter=(1=2TRFE;6=5F;7=RCB;0=TRN220L-TRMDKA)
    If the wire is needed this says Manufacturer Toyota This genuine Toyota part is guaranteed by Toyota's factory warranty. $518
    Other places well over $700 -$800
    Why wouldnt I buy it at $300 less?
  14. Oct 27, 2023 at 11:21 AM
    daveeasa
    David
    PNW
    If the damage is all in the cab, I wouldn't pay a dime for an OEM part to replace it b/c you don't have any concerns about waterproofing. Just splice in new wire and cover with loom and forgetaboutit. Use heat shrink butt connectors and a heat gun or solder or butt splice or however you need to. It'll be totally fine, electrons and copper don't have part numbers on them.
    I'd be more tempted to consider an OEM part if it involved exterior connectors, especially in the engine bay or near the exhaust system.
    RockfordTaco2006 likes this.
