Wiper Blade Motor / Wiring Diagram
Discussion in '1st Gen. Tacomas (1995-2004)' started by xitsjacob, Feb 1, 2024.
  1. Feb 1, 2024 at 11:23 AM
    xitsjacob
    xitsjacob [OP] 98 2.4 Taco
    HTX
    so i had good connection on the connector pads at the motor pin out.
  2. Feb 1, 2024 at 11:25 AM
    xitsjacob
    HTX
    replaced a good portion of all the fuses too while i was there working on taking off the whole dash and see if there is anything else im not seeing
  3. Feb 1, 2024 at 11:53 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    To clarify, you have 12V at the motor connector pins across all wires? So 12V for low 12V for high and 12V for return?
  4. Feb 1, 2024 at 11:56 AM
    xitsjacob
    HTX
  5. Feb 1, 2024 at 12:02 PM
    time623
    James
    AZ
    So thats the wiper return or 'park' pin, if you set the wipers to high do you get power on the pin above the one you tested? Its the top-left pin referencing your photo.
  6. Feb 1, 2024 at 12:08 PM
    time623
    James
    AZ
    I might have that flipped, bottom right pin?
    You want to try the wire connector side of the pin that plugs into #3 on the motor:
  7. Feb 1, 2024 at 12:23 PM
    xitsjacob
    HTX
    When I get off @ 5 ill test them all on hi
  8. Feb 1, 2024 at 12:23 PM
    xitsjacob
    HTX
    2.5 hrs from now
    time623 likes this.
  9. Feb 1, 2024 at 3:04 PM
    xitsjacob
    HTX
    middle and right pin are getting power
  10. Feb 1, 2024 at 3:17 PM
    time623
    James
    AZ
    Did not expect that..
    So you have power to pins #3 and #2 when the wiper switch is on High, referencing the FSM numbering system from my post #12 on the 1st page of this thread. Those two pins should mean your wiper motor will operate on high, and will properly return to the 'park' position.
    If you replaced the motor, and confirm the motor is functioning by applying power directly from the battery to the motor, then my understanding of the situation leaves two possibilities..
    Either the connector is not making proper electrical contact to the pins on the motor, or the last thing we haven't checked is the ground wire.
    I don't know exactly what the best way to test the ground would be, my first idea would be to splice into the ground wire of the wiring harness just before the motor connector and ground it in your engine bay and see if it makes everything work.
  11. Feb 1, 2024 at 3:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    On LOW you should have power to the Blue/Black wire
    On High it should have power on the Yellow/Blue wire
  12. Feb 1, 2024 at 3:20 PM
    TnShooter
    Deogee
    STOCK
    Solid blue should have power at all times Key ON.
  13. Feb 1, 2024 at 3:40 PM
    xitsjacob
    HTX
    is there a relay I’m missing
  14. Feb 1, 2024 at 3:42 PM
    xitsjacob
    HTX
    could I just do the reverse operation, set the ground to the ground pinned and send power through the voltmeter through the battery terminal
  15. Feb 1, 2024 at 4:08 PM
    #35
    TnShooter
    Deogee
    STOCK
    Yes, the relay is built into the wiper switch.
  16. Feb 1, 2024 at 4:24 PM
    #36
    xitsjacob
    HTX
    both good high and low two power pins as you said and the solid blue constant power
  17. Feb 1, 2024 at 10:37 PM
    #37
    time623
    James
    AZ
    Yeah that would be a lot easier than what I said, just put the positive on the battery and the negative on the ground pin on the connector. If it reads 12-14 that should mean the ground is good.
    I’m pretty stumped on where to go next if the grounds good
  18. Feb 1, 2024 at 10:42 PM
    #38
    xitsjacob
    HTX
    which is the ground pin hahah?
    Could be the switch not home yet to test it?
  19. Feb 2, 2024 at 12:46 AM
    #39
    TnShooter
    Deogee
    STOCK
    White and black wires.
    One is for the washer motor the other is for the wiper motor.
  20. Feb 2, 2024 at 1:06 AM
    #40
    xitsjacob
    HTX
    ground is good
    new / used switch
    no action
