Wiper arm alignment?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zink_91, Dec 14, 2023.
  1. Dec 14, 2023 at 12:07 PM
    Zink_91
    Zink_91 [OP] Well-Known Member
    Kevin
    Mississippi
    2004 Double Cab PreRunner V6 TRD
    Hey folks, 2004 owner here.
    So I just got my windshield replaced at dealership and noticed when getting in my truck that the wipers were sitting higher on the shield than before. When I hit the switch, the drivers side hit the frame. I asked them to address it and they did in about 15 minutes but it isn't quite were they were originally.
    Was wondering if this is an easy adjustment I could do myself to fine tune these things?
  2. Dec 14, 2023 at 12:14 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Sorta yes. Under the cap at the base of the wiper arm is the mount there is a nut. Take it off then watch a few youtube videos on arm removal (easier than trying to explain via words)
    my tips are don't over torque that mounting nut and be careful with arm removal. I've seen windshields get broken or wiper transmissions getting broken trying to remove wiper arms
  3. Dec 14, 2023 at 12:26 PM
    Madjik_Man
    Colorado Front Range
    Yup easy.
    Remove cap covering the wiper arm nut.
    Remove nut.
    Pull wiper arm off bolt. Rotate to proper alignment, insert arm back on bolt, tighten nut, replace cap.
    voodoomaster33 and drizzoh like this.
  4. Dec 14, 2023 at 12:38 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    This.
  5. Dec 14, 2023 at 5:19 PM
    Zink_91
    Kevin
    Mississippi
    Thanks guys, I have never been let down on Tacoma world!!
    Squirt likes this.
  6. Dec 14, 2023 at 7:18 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Dealerships.
    Sorry for the issue
    Glad easy fix
