Winterizing Truck for 0 to -30 degrees
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cbengineer, Nov 4, 2012.
  1. Nov 4, 2012 at 10:34 PM
    cbengineer
    cbengineer [OP] Active Member
    Jeremy
    Vernal, UT
    2012 Tacoma TX Pro
    Old man emu 885's w/dakar leaf packs, Weathertech Floor Liners and Window Deflectors, Wet Okole Seat Covers, AFE Pro Dry S air filter, Fujimoto Drain Valve, Plasti Dipped Chrome Ring on TRD rims
    Recently moved to Vernal UT and apparently it gets 0 to -30 degrees here during the winter months and was wondering what i should do for my truck in the extreme cold. Only have about 5,000 miles on my truck and just changed the oil to Full Syn mobile1 5w30 as well. This is my first post (Long time stalker first time poster):D
  2. Nov 4, 2012 at 10:39 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    Change your wiper fluids. I just put in some RainX 2in1 -25F wiper fluids.
    Whatever the dealership uses always freezes up on me during the winter. Local O Rielly's had a sale for 2/$5
  3. Nov 4, 2012 at 10:41 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Block heater will be nice, put it on a timer for a few hours before you leave in the morning.
  4. Nov 4, 2012 at 10:41 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    block heater, battery blanket, and yeah the washer fluid. Otherwise you should be good.
  5. Nov 4, 2012 at 10:43 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Get heated mirrors
    oh right , Fuck you Toyota
  6. Nov 4, 2012 at 10:45 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Oh and they make arctic extension cords that stay flexible, they're usually blue. Most places should have em there.
    IIRC Vernal is pretty similar to Rock Springs and it doesn't often get that cold there. -30 is like record low kinda stuff. You'll be good!
  7. Nov 4, 2012 at 10:55 PM
    cbengineer
    Jeremy
    Vernal, UT
    2012 Tacoma TX Pro
    Thanks for the ideas everyone. I was definitely planning on the washer fluid but probably not the block heater since i work nights and the truck doesnt get started till after 1 pm which will be warm enough. I will however look into the battery blanket.
  8. Nov 5, 2012 at 8:32 AM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    Snow tires is another good thing to have because at those temps the rubber on regular tires gets hard and you have no traction
  9. Nov 5, 2012 at 10:31 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Strongly suggest the "factory" block heater, not an after-market. Fairly reasonably priced. Also a couple of bags of sand placed over rear axle. Another idea is to silicone spray all door seals.
  10. Nov 5, 2012 at 11:19 AM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    if its a garage queen, i wouldnt worry about it to much. if it stays outside, just get a factory block heater and plug it in during the night. make sure you get an outlet adapter with a light in it to make sure the outlet actually has power.
    wiper fluid, heet (for the gas), ensure anti freeze is 50/50 or 60/40 mix.
    run a/c at least once a month during the winter (i do every paycheck as a simple reminder, but use android app to do that now)
    during extreme cold you can use zip tie some cardboard to the grille to reduce the cold air hitting the radiator so the truck can actually warm up, but i never had to on the v6 models.
  11. Nov 5, 2012 at 11:20 AM
    cgs2k2
    cgs2k2 old man
    lol
  12. Nov 5, 2012 at 11:56 AM
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    I bought my truck in AZ and drove it to my home in AK.
    The first problem I had was the wiper fluid. It had water in it and if froze and caused me all sorts of problems. The coolant should be fine so long as it is the factory coolant still. That was the second thing I checked.
    Otherwise, my "Alaskanizing" of my truck included adding an engine block heater (really easy to do yourself) and getting an Autostarter. That is the set up most people use in Anchorage. The coldest we usually get is -30 or so. However, it stays below freezing for 5 or 6 months straight.
    And oil pan heater and battery heater won't hurt anything but I really don't think it will be necessary. I know very few people who have them here. I have never had one on any of my rigs. I have owned two toyota trucks up here that have had 200,000+ miles on them and only had the block heater.
    I plug my truck in when it gets under 20 F and then auto start it 5 to 15 minutes before I leave in the morning (depending on how cold it is). Looking at my scan gauge, I have noticed a significant difference between the operating temperature when plugged in. It warms up much faster.
    Personally, I never use Heet. I just try to keep the tank above half a tank. Never had any problems.
    As to covering the grill, you probably won't need to worry about that. If you are going on a long road trip and expecting -30 the whole way, maybe a good idea. Running around town and such, it should be ok.
  13. Nov 5, 2012 at 12:12 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    What people are suggesting are great ideas.
    Block heater(OEM not aftermarket), colder tempature anti freeze and washer fluid. Carry a spare blanket in the back for emergencies. Shovel, ice scraper. A tire gauge to check your tire pressure regularly. You'll lose more air in the colder temps then in the warmer. Keep your gas tank at least above a quarter. Carrying road salt or kitty litter is a good thing to have.
  14. Nov 5, 2012 at 12:16 PM
    cbengineer
    Jeremy
    Vernal, UT
    2012 Tacoma TX Pro
    Haha definitely not a garage queen i wish though. What temps would a block heater be recommended for? 2 years ago the temps were down to -20 to -30 but last year barely got under 0. Also how much does toyota charge for install of a block heater?
  15. Nov 5, 2012 at 12:18 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    This. Is going to be my next investment. We'll see how this winter goes, living on the east coast.
  16. Nov 5, 2012 at 12:24 PM
    jw1983
    Alberta
    If we have a winter this year like we did last, you won't need a block heater. I only plugged my truck in twice. OP, get one anyways just to be safe.
  17. Nov 5, 2012 at 12:26 PM
    OZ-T
    Peter North
    British Columbia
    Did you see what Jerez did to his with the heated 2010 4Runner mirrors ?
    I like that a lot
  18. Nov 5, 2012 at 12:43 PM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
    Yup, been following that. I won't have the time or funds until after this winter anyways.
  19. Nov 5, 2012 at 12:44 PM
    NoDak
    JR
    Minot, ND
    prior to being a garage queen, i would only plug it in if it was below 0F. since i drive 20 miles one way to work each day highway, not that much of an issue since everything gets warmed up, recharged and condensation is dried out of the exhaust system. if it sits for days between start/errands/long drives i would plug it in. batteries can freeze up if they sit to long between starts.
    we can go weeks at times here where it wont get up above 0 or 10F.
    big killer of exhaust systems up here is the 5-10 min drive that doesnt get the moisture out.
  20. Nov 5, 2012 at 12:45 PM
    OZ-T
    Peter North
    British Columbia
    I won't have time or the skill :)
