Winter tire pressure
Discussion in 'Wheels & Tires' started by kiwiyyc, Dec 19, 2020.
  1. Dec 19, 2020 at 12:22 PM
    kiwiyyc
    kiwiyyc [OP] Well-Known Member
    Calgary, AB
    2020 Tacoma TRD Sport Premium 6MT, Cement
    I’m new to the Tacoma world and wondering what tire pressure folk are running with winter tires? I’ve got a 2020 DC TRD Sport with 265/65R17 Blizzak DMV2 tires. Door pillar sticker says 29 PSI but the dealer has put 36 psi (cold) in.
  2. Dec 19, 2020 at 12:26 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I run 30 PSI
  3. Dec 19, 2020 at 1:02 PM
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    I go with 30#, which is the sticker, winter or summer.
  4. Dec 19, 2020 at 1:05 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    Dealers always over inflate
    pay peanuts, get monkeys
    Hooper89 and BalutTaco like this.
  5. Dec 19, 2020 at 1:09 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Chalk test.
    Tires shouldn't fluctuate more than 10% +/- from your chalk test and normal operating speed.
    10 degree in temp change is about 1 psi
  6. Dec 19, 2020 at 1:10 PM
    Mr.Hustler
    Mr.Hustler Well-Known Member
    2018 Magnetic Grey Metallic TRD Off Road 4x4 [AT]
    It's a secret
    28.6983443 psi
    CalcityRenegade and davidstacoma like this.
  7. Dec 19, 2020 at 2:25 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    32 psi - 365 days/year.
    vicali likes this.
  8. Dec 19, 2020 at 2:38 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    30 PSI at 30 degrees F. As previously stated, that translates to higher pressures at higher temps.
    Therefore, in the summer months, I fill to about 35 PSI.
  9. Dec 19, 2020 at 3:07 PM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    If those tires are the stock size and load rating, go with what the door says. If not, here:
  10. Dec 19, 2020 at 3:28 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The numbers on the door jamb are for best ride when unloaded. The number on the tire is for carrying heavy loads. It should be around 44 PSI with P rated tires although it will vary some depending on the exact tire and size. The more weight you have in the truck, or tongue weight from towing, the more air you need. If under inflated when carrying loads the tires overheat and could fail. Although this is more common in summer months.
    I'm using E rated tires now and the the standard rules don't apply. When I had P series tires on my truck I ran somewhere around 35 PSI all the time. I carry loads fairly often and just keeping them on the high side of acceptable was a lot easier than going through the air up, then air down dance every time I needed to carry any weight or tow.
    I didn't find the ride objectionable at 35 PSI and found I got 1-2 mpg advantage at that pressure vs 30 PSI.
    It doesn't matter if it is summer or winter. 35 PSI is 35 PSI at 0 degrees and at 100 degrees. BUT.... if you air up to 35 PSI at 100 degrees, then cool the tire to 0 degrees and check the air pressure it will be a fair bit below 35 PSI. You'll need to add more air to get it back up to 35 PSI. And if you're at 35 PSI at 0 degrees and warm the tire up to 100 degrees it will be significantly over 35 PSI. You'll need to let some air out to keep the pressure at the correct setting.
  11. Dec 19, 2020 at 4:19 PM
    Thatbassguy
    James
    This is incorrect. The number on the door jamb is based on GAWR and tire size and load rating. You should never run the maximum pressure on the tire, unless that is what the vehicle manufacturer recommends.
    I do agree with your last paragraph.
  12. Dec 19, 2020 at 7:35 PM
    Saffa
    Saffa Well-Known Member
    Victoria, British Columbia
    2015 TRD Sport DC 6MT
  13. Dec 19, 2020 at 7:37 PM
    Bishop84
    Bishop84 Well-Known Member
    29 at freezing all day long.
  14. Dec 20, 2020 at 5:25 AM
    jadatis
    jadatis Well-Known Member
    Peter
    NEVER blead air from a warm tyre.
    Not because you could burn your fingers, but because the tire needs the higher pressure to give it lesser deflection so heatproduction, because cooling down is also worse then, because of the lesser temperature-differences between rubber and in- and out-side tyre air.
    Goal is that the no part of tyre, reaches a critical temp, at wich it hardens and cracks are made, wich crack further in time.
    In fact the tyre is lost then, but it can take years, before damage build up that much that it blows.
    When cold, you dont need to highen up to advice pressure for safety, for road handling you may do it.
  15. Dec 20, 2020 at 7:47 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I just changed out the summer air and installed winter air.
    I made sure the summer and winter air was mixed with 80% nitrogen. The 100% nitrogen isn't needed for a daily driver.
    In the summer, I run 30 psi in all 5 tires. In the winter, I run 30 psi in all 5 tires.
    @jadatis.......you have some really bad erroneous information about tire pressure....... :facepalm: o_O :crazy:
    TireFire, vicali and jadatis like this.
  16. Dec 20, 2020 at 7:50 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    I generally try to run my truck tires in the 32-36 range. In the warmer months, they will hold the pressure fine, but in the winter months they will drop down into the 20's if you don't pay attention to them. I haven't checked them in a while and it got down to 9 degrees 2 nights ago so I bet they are down in the 20's now. Time to go out and check them and most likely add some pressure.
    Edit: Yup, all 4 tires were at 26.5 lbs so I brought them back up to 33 for now. I don't drive much so my tires tend to lose more pressure in the cold. If you do a decent amount of driving, the heat from daily driving should keep them closer to spec.
  17. Dec 20, 2020 at 8:35 AM
    Saffa
    I recently fitted Michelin Defender LT265/70/17 tires at Costco.
    The guy insisted inflating it to 40psi
    The ride was hard, bouncy and uncomfortable
    After reading the "what psi should I run" thread I started adjusting the pressure downward.
    Some guys recommend 34-35psi front and 30-32psi rear
    I'm running 36 front and 33 rear, I might still go down some.
    I tried 32psi all round but the front tires felt squishy and wiggly
    It makes sense that the front tires need more pressure carrying the weight of the engine, front differential and most of the cab and transmission.
  18. Dec 20, 2020 at 9:02 AM
    Saffa
    Where do the air leak out? Valves or at the rim
  19. Dec 20, 2020 at 9:55 AM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    It doesn't leak out, the colder weather causes it to lose pressure. I remember in the late spring when it was getting warmer the truck felt more firm so I checked the tire pressure and it was up to 38 so I had to let some air back out.
    SilverBulletII likes this.
  20. Dec 20, 2020 at 10:53 AM
    Knute
    Air will expand and contract with temperature. When the air is in a closed volume, like a tire, the pressure will increase and decrease with temperature as the air tries to expand or contract.
    A tire will have tendency for slow leaks at the bead or valve stem.
    JL8Jeff is correct. You must check your tire pressures every few weeks or at every fuel fill.
    Don't rely on the TPMS to replace maintenance. The TPMS is a warning system for sudden loss of pressure before the rim makes contact with the pavement while running at speed.
