Windshield washers won't spray?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by snowman555, Feb 16, 2019.
  1. Feb 16, 2019 at 7:47 PM
    snowman555
    snowman555 [OP] Member
    Hey guys! Just joined the forum and about a week deep into being a taco owner! Have a small issue that im not sure where to begin to see whats up with it. My windshield washers wont spray the fluid at all. I have a 2016 SR5 tacoma double cap v6 with 25k miles.
    I'm going to check the fuse and the line running from the resovoir tomorrow.. But im stumped as to what it could be thats causing it not to shoot liquid.
    I've searched on google for the past 3 hours and only things popping up are a few 2nd gen threads where the motor blew for the washer motor. I can't imagine that being the case at 25k miles though?
    Edit- Update. She's spraying again. Pulled the fuse and it was indeed blown. For anyone in the future, it's not a standard micro 10 amp fuse. It's a "Slim profile micro 10 amp fuse" my Napa around me was confused for a bit and we eventually found the fuses.
  2. Feb 16, 2019 at 7:48 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Subbed for outcome. Just started experiencing this at 40k miles. May have blown a fuse doing some other electrical work, but haven’t had time to Check fuses yet
  3. Feb 16, 2019 at 7:57 PM
    snowman555
    That'll be my first check. Just have a hard time believing that a totally stock truck would burn a fuse that quick.
    My though process is either fuse is blown or the line is kinked somewhere from the motor to the jets on the hood... But I think im being wishful since I can't hear the motor run at all.
    uhplifted[QUOTED] likes this.
  4. Feb 16, 2019 at 8:01 PM
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    When the reservoir freezes it blows a fuse when you attempt to use it. Judging from your name maybe that?
  5. Feb 16, 2019 at 8:03 PM
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    Did you check the fluid level? Might be out ya know
    Boghog1 and sumorus like this.
  6. Feb 16, 2019 at 8:08 PM
    Totall4285
    Totall4285 Well-Known Member
    Palm Harbor, Fl.
    2017 Tacoma TRD Sport
    My 2015 4runner had same issue... pin connectors were corroded and broken. Had to replace wire harness.
  7. Feb 16, 2019 at 8:22 PM
    Jak1
    Jak1 New Member
    Jeff
    2013 Dbcb TRD OR
    My 2013 stopped working and was frozen at the bottom of the reservoir. Removed it and ran hot water to thaw out the pump. Works fine now.
    Good luck
    doc1187 likes this.
  8. Feb 16, 2019 at 9:08 PM
    uhplifted
    Brian
    16 DCLB OR
    Ya I may have done that. I was installing some shit and I accidentally installed my ARB switch wires backwards and somehow it triggered my wipers when turning on the pump. And then I switched some wires around and then it worked. I’m definitely not out of fluid, that was the first thing I checked. My scenario seems more likely that I blew a fuse with my tinkering, but yours is odd. Hopefully you get it figured out
  9. Feb 16, 2019 at 9:16 PM
    TetonBuck
    TetonBuck Well-Known Member
    2016 Black TRD OR
    Stock
    Mine just clogged up , got advice on TW to stick a pin in the ports and works fine now
    trekker and uhplifted like this.
  10. Feb 17, 2019 at 4:54 AM
    gdb85
    gdb85 Well-Known Member
    Pgh, Pa
    2016 SR5 DCLB 4x4
    Just happened to me two weeks ago. Thought it was frozen so thru warm water on it, checked fluid and it was half full. Wound up being a fuse...pretty strange but maybe like post #5 suggest, froze somewhere and blew when trying to use it. IDK never happened in all my years with any vehicle.
    doc1187 likes this.
  11. Feb 17, 2019 at 5:53 AM
    snowman555
    Haha.. That's what I assumed and picked up a gallon of the Rainx orange stuff.. popped the hood to fill her up.. and she was filled. Going to check the fuses in a bit. I'll post an update
    Thank you everyone for the replies. Appreciate the help.
  12. Feb 17, 2019 at 6:07 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    As stated, the cheap factory stuff will freeze.
    G.
    friendlywithbears likes this.
  13. Feb 17, 2019 at 6:15 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    I would return the Rainx orange stuff as you call it. That stuff clogs up the washer system bad, destroys wash system. I have had it happen, along with many others. Google it, you will see many complaints.
    tirediron likes this.
  14. Feb 17, 2019 at 6:22 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    If the pump isn't making noise, there's your problem. Most likely a fuse but could be the pump
  15. Feb 17, 2019 at 8:49 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Agree... used it once. The windshield smeared so badly I had to pull over and wipe it off with kleenex and puddle water to continue driving.
  16. Feb 17, 2019 at 8:54 AM
    GravityAddict69
    GravityAddict69 Well-Known Member
    Ron
    2016 TRD off-road
    Mine clogged up too but antibiotics took care of it
    Mozart and DIRTT_Fish like this.
  17. Feb 17, 2019 at 8:56 AM
    11WoodChuck
    11WoodChuck New Member
    2017 TRD Off-Road
    Falken A/T3W
    Had the same problem in Wisconsin in mid 20's low 30's degree weather. Had to physically wipe of the nozzles with my finger and run the sprayers for about a minute then add low temp fluid. No fuse blown as of now.
  18. Feb 17, 2019 at 9:58 AM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Is this legit? I just started using this stuff. Can anyone confirm there is a problem with the RainX Orange and our Tacomas?
  19. Feb 17, 2019 at 10:08 AM
    1taco2motos
    1taco2motos Well-Known Member
    Colorado
    19 DCSB mgm TRD OR 6MT
    Just a tip: try adding a little rubbing alcohol next time you fill up the bug juice reservoir. It helps prevent freezing & works rather well cleaning the bug guts off the glass as well.
    z00mer and 11WoodChuck like this.
  20. Feb 17, 2019 at 11:18 AM
    snowman555
    uhplifted and bulalo like this.
