Windshield washer fluid frozen. What to do?
Discussion in 'General Automotive' started by 45acp, Dec 18, 2013.
  1. Dec 18, 2013 at 9:27 AM
    45acp
    45acp [OP] Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    The reservoir is a PITA to get to (Honda Fit) and the fluid is completely frozen. I tried using a portable forced air propane heater, but it only thawed the lines. Is there any effective options other than completely removing it and bringing it inside?
  2. Dec 18, 2013 at 9:34 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    where is the resivoir located? if its in the vehicle, try running the heater for a little while. if its in the engine bay, eventually the engine heat will thaw it out. same goes for the lines. once you get it to thaw, try to find some fluid rated for cold temps
  3. Dec 18, 2013 at 9:35 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Jon if its cold enough for that to freeze wouldn't it just freeze on the windshield? :p
  4. Dec 18, 2013 at 9:40 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This. Put some alcohol (methanol) in the reservior also, it'll help the melting process.
  5. Dec 18, 2013 at 10:09 AM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Thanks, I'll look for some methanol. Won't damage anything, will it? I just want to thaw and drain this stuff (whatever it is the dealership put in) and put in the winter rated stuff.
  6. Dec 18, 2013 at 10:11 AM
    Pugga
    Massachusetts
    Methanol is the alcohol that is in windshield washer fluid anyways, that's what makes it so it doesn't freeze. It's also what trucks with air brakes use so their lines don't freeze so it shouldn't be overly difficult to find. If you mix it really rich, I wouldn't use it because straight alcohol on paint will just strip all the protective wax but it should help thaw it out quicker combined with the engine heat.
  7. Dec 18, 2013 at 10:13 AM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Thanks
    I should just run straight up methanol! :D
  8. Dec 18, 2013 at 10:40 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Nope, for the same reason you don't want to use a lot of the super-duper cold weather stuff..damage to wax and/or paint. In my experience it also helps to keep it topped off in the winter. Never had a problem with mine doing that in New England.
  9. Dec 18, 2013 at 10:43 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    could just use vodka
  10. Dec 18, 2013 at 10:44 AM
    Pugga
    Massachusetts
    I've been running that Rain-X De-Icer stuff and it's worked well so far. Hasn't frozen yet and does a nice job keeping the windshield from icing up also.
  11. Dec 18, 2013 at 10:45 AM
    Pugga
    Massachusetts
    Simple, yet effective! Any alcohol will do if you're draining it anyways. Higher proof, the better.
  12. Dec 18, 2013 at 10:46 AM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    fact. thats what james may used for his expedition to the live volcano in the north pole hilux to cool his tires
  13. Dec 19, 2013 at 11:10 PM
    ABA180
    East Bridgewater MA
    Is that the orange stuff? And do you cut it or just straight up?
  14. Dec 20, 2013 at 8:47 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    to thaw it out..you need to borrow a warm garage.
    or maybe run a cheapo hair dryer on it for a long time?
  15. Dec 20, 2013 at 8:52 AM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Tried a propane heater already. I bought some of that "Heet" stuff the other day but it didn't do jack.
  16. Dec 20, 2013 at 8:54 AM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    hot water in to resi
