Windshield tint
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 1bad2k, May 19, 2018.
  1. May 21, 2018 at 8:45 PM
    #61
    1bad2k
    1bad2k [OP] Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Is there any way you could post a pic from the inside of the taco looking out the windshield? I am between crystalline 70 and llumar air 80 on the windshield, leaning toward the crystalline.
  2. May 21, 2018 at 9:21 PM
    #62
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    11E42665-DF83-4967-8751-CE6E15D225C4.jpg 5C1369F2-AFD3-4E43-AEDC-EDA2CCF15530.jpg
    Llumar air 80. All windows and windshield. I have fast track on velcro tabs stuck to window. Doubt ill ever remove the velcro so didnt care it was on tint.
    DubfromGA and 1bad2k[QUOTED][OP] like this.
  3. May 21, 2018 at 10:23 PM
    #63
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Fasttrack? Is that like a toll tag?
  4. May 21, 2018 at 11:08 PM
    #64
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Sorry off topic but how hard is it to remove or put that shell on? What does it weigh and I’m assuming two able bodied people or can it be done by your self?
  5. May 21, 2018 at 11:10 PM
    #65
    Friedtacolover
    Travis
    Ontario, Ca
    Ya
  6. May 22, 2018 at 12:25 AM
    #66
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    As posted from Jeff Lange, that is incorrect:
    2018 Tacoma Factory Tint
    Windshield: 70% Tint, 100% UV Reduction, 55% Heat Reduction
    Front Door: 70% Tint, 55% UV Reduction, 45% Heat Reduction
    Rear Door (Access Cab, w/o Privacy): 70% Tint, 58% UV Reduction, 62% Heat Reduction
    Rear Door (Access Cab, with Privacy): 20% Tint, 18% UV Reduction, 25% Heat Reduction
    Rear Door (Double Cab, w/o Privacy): 70% Tint, 55% UV Reduction, 45% Heat Reduction
    Rear Door (Double Cab, with Privacy): 20% Tint, 80% UV Reduction, 75% Heat Reduction
    Back Window (w/o Privacy): 70% Tint, 44% UV Reduction, 53% Heat Reduction
    Back Window (with Privacy): 20% Tint, 18% UV Reduction, 25% Heat Reduction
    So, looking at the windshield: factory is 55% heat reduction, 3M Crystalline CR70 is 50% heat reduction (TSER). So, the factory windshield is actually better. What happens when you put CR70 on the windshield? Not a lot... it's already blocking 100% UV, 30% visible, and probably over 90% infrared... you wouldn't gain any more than an additional 10% heat reduction. (70% vis makes it through, CR70 blocks 31% of that, visible is 44% of TSE.)
    There is, however, room for significant improvement in UV everywhere else and some specific rear privacy heat reduction.
    DCtodave714 and MrBrooks like this.
  7. May 22, 2018 at 2:15 AM
    #67
    Dmwood1984
    Dmwood1984 Well-Known Member
    New Jersey
    2018 Cement TRD Off-Road Double Cab Long Bed Premium Package with Options
    20% all around
    SandyTaco4x4 and 1bad2k[OP] like this.
  8. May 22, 2018 at 4:50 AM
    #68
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Dealer install. Used a forklift. Snugtop HQ says it is 230 lbs. It would be hard to remove it by myself. I made sure to get roof tracks to get roof rack mount and crossbars later. Lazily researching ways for a garage pulley lift for future removal. But right now more focused on using it.
  9. May 22, 2018 at 5:07 AM
    #69
    GoGoGadget
    GoGoGadget Well-Known Member
    2017 DCLB OR
    I will look at the law in the state it is registered in. If you are violating your home state law, then I will write it for also violating ours. While technically may be illegal here but legal where you are from, it is a dick move to cite someone passing through, so I never did.
    snickers[QUOTED] likes this.
  10. May 22, 2018 at 9:39 AM
    #70
    dot_tom
    dot_tom It's a 4Runner
    Tom
    2017 4Runner TRD OR
    I don't have any interior photos. Crystalline 70 on the windshield isn't very noticeable when looking out. I wear sunglasses still in the Tacoma with the 70.
  11. May 22, 2018 at 4:00 PM
    #71
    Tharris242
    Houston, TX
    Does the 3M Crystalline film look okay through polarized sun glasses?
  12. May 22, 2018 at 4:04 PM
    #72
    JimmySport
    JimmySport Well-Known Member
    I always find manufacturers specs funny actually. they claim 55% heat reduction from their stock windshield. get in a truck without tint on a hot summer day, above 90 degrees. put your hand on the inside of the windshield. it will probably burn you. then, put your hand on the inside of windshield that has been tinted with any form of ceramic film. you will definitely feel the difference. while I am not arguing with Toyota's specs, there is always room for improvement. I do not feel hardly any heat coming in my windshield on me, and mine is tinted with SunTek CIR70. same thing will probably be said about guys with Crystalline, or Llumar Air, or Wyncose, etc...its actually more funny that Toyota's "clear" glass has more heat rejection and UV reduction than their privacy glass. that seem completely backwards.
    1bad2k[OP] likes this.
  13. May 22, 2018 at 4:04 PM
    #73
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Got a quote from a pretty reputable place this morning for 3M crystalline 70% windshield and 40% front doors for $395. Not bad! I really wish they offered it in 80% because inspection shops here pass it. The crystalline 90% is a little lighter than I wanna go unfortunately.
  14. May 22, 2018 at 4:10 PM
    #74
    Friedtacolover
    Travis
    Ontario, Ca
    Yes
  15. May 22, 2018 at 4:11 PM
    #75
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    air 80 in my video
    https://youtu.be/O_boy0lGocU
    1bad2k[QUOTED][OP] likes this.
  16. May 22, 2018 at 4:31 PM
    #76
    JimmySport
    man, I wish we could get those prices here in NC. we wouldn't get any business if we charged that. we charge $215 plus tax for 2 front doors and full windshield.
  17. May 22, 2018 at 4:39 PM
    #77
    jepjon
    jepjon New Member
    just curious what are you guys paying to get this done?
  18. May 22, 2018 at 4:49 PM
    #78
    JimmySport
    we charge $125 for full windshields in our shop. we are in NC.
  19. May 22, 2018 at 4:58 PM
    #79
    blewis
    blewis Well-Known Member
    B
    Lakewood Ranch, Fl.
    17 DCSB 4X4
    $120 for all 7 windows (the back window is 3) & $100 for the windshield. $220 total.
  20. May 22, 2018 at 5:18 PM
    #80
    JimmySport
    what kind of film are they using that they can only charge $120 for the full truck? that is really inexpensive. I see you're in FL, so there are tint shops everywhere down there.
